Home > Message Board > Home Video > HDTV Reception > HDMI Connection Problems
Author Thread: HDMI Connection Problems
Username: Vincecor
Montgomeryville, PA
I have a Toshiba 46" HDTV connected to a Motorola HD Ccble box(Verizon).When I connected them with several different grades of HDMI cables every 10-20 mins. I would get 1-2 seconds audio drop out-video not affected.Contacted both Verizon & Toshiba and both passed the "Buck".
I corrected the problem by using RCA cables to and from the TV & Box, switched my HDM! to Analog.No more audio drop out.
I feel the problem is with my cable box or cable signal from Verizon not either strong enough or that it varies in strength to be acceptable for audio HDMI connection
Username: Vincecor
Montgomeryville, PA
Further contact with a Verizon tech solved my HDMI audio connection problem.Box setting audio(Dynamic) from Heavy to NONE.
I resetted my Tv's HDMI back to AUTO.
HDMI audio & video working fine-no audio drop out.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > HDTV Reception > HDMI Connection Problems [ « Previous ] [ Next » ]
