Thread: How to hook up an Lcd tv with you computer? |
Bronze Member Username: Sher
St anne de bellevue,
Quebec
Post Number: 21 Registered: Apr-07
| Posted on Wednesday, January 21, 2009 - 09:55 pm: |
Just wondering how one can hook up a computer with an lcd television, what are the various cable connections possible and where one can buy cheap and efficient cables online? Thanks |
Bronze Member Username: Onecall
Spokane,
WA
Post Number: 53 Registered: Dec-08
| Posted on Thursday, January 22, 2009 - 12:32 pm: |
Hi Sher, Do you already own the LCD TV, if so, what model do you have? Many LCD TVs have PC Monitor (DB15) connections so you can connect a computer using the standard computer monitor connection. If you already own the TV you'll want to check and see if your TV has that connection, then reference the owner's manual for the PC/Computer resolutions the TV can display. Matt |
