Thread: Archive through January 17, 2009 |
Gold Member Username: Javy_gza
MONTERREY ,
NUEVO LEON
MEXICO
Post Number: 2062 Registered: Oct-06
| Posted on Thursday, January 15, 2009 - 05:27 pm: |
WENO RAZA IA LLEGE JEJEJE TARDE PERO SIN SUEÑO NEO X 1A NORMALMENTE CUANDO NO SE LE RESPONDE A UNA PERSONA ES XQ NO AI NADIE O NO SABEN LA SOLUCION 2DA CUANDO SE PIDE AYUDA SE PIDE CON RESPETO . 3A IO E APRENDIDO MOVIENDOLE A MI APARATO UNA Y OTRA VEZ ASTA Q SOLUCIONAMOS NUESTROS PROBLEMAS. 4A IO PARA BAJARLE LA EPG AMI APARATO SO0LAMENTE CAMBIO DE CANAL Y ME ESPERO 45 SEGUNDOS Y SE CARGA NOTA IO TENGO UN PANSAT 2700 A .TU RECIBER NO LO E TESTEADO . PERO ALGUIEN AL RATO TE SOLUCIONA TU PROBLEMA .SALUDOS |
Silver Member Username: Neox
Tijuana,
Baja California
Mexico
Post Number: 319 Registered: Aug-06
| Posted on Thursday, January 15, 2009 - 07:30 pm: |
gracias por todo |
Silver Member Username: Sergio_verdugo
Hermosillo,
Sonora
Mexico
Post Number: 776 Registered: Nov-07
| Posted on Thursday, January 15, 2009 - 08:09 pm: |
JAVY KE ONDA NO SUPISTE SI REXIO SOLUCIONO SU PROBLEMA ??? COMENTO QUE EN ALGUNA OCASION TU LE HABIAS DADO LA SOLUCION, AL IGUAL ME HECHASTE LA MANO, CON MI PANSAT CUANDO LLEGE A ESTE FORO, LO CUAL TE SIGO AGRADECIENDO |
New member Username: Ferher
Riverside,
Ca
Usa
Post Number: 1 Registered: Jul-06
| Posted on Thursday, January 15, 2009 - 09:42 pm: |
alguien podria ayudarme para convertir pansat 2500 to 2700 tengo algunos pasos pero no se como hacerlo |
MONTERREY ,
NUEVO LEON
MEXICO
Post Number: 2063 Registered: Oct-06
| Posted on Thursday, January 15, 2009 - 10:56 pm: |
SERGIO VERDUGO LO Q PASA Q ME DESCONECTE DE LOS CONVERTIDOS A 2700 PERO AI MUCHA INFO EN ARCHIVOS ANTERIORES . POR LO DE LA AYUDA Q TE DI NO ES NADA LO HICE DE CORAZON . SALUDOS. |
MONTERREY ,
NUEVO LEON
MEXICO
Post Number: 2064 Registered: Oct-06
| Posted on Thursday, January 15, 2009 - 11:15 pm: |
FERNANDO HDZ AQI VA ALGO DE CONVERTIR PANSAT 2500 A 2700 |
MONTERREY ,
NUEVO LEON
MEXICO
Post Number: 2065 Registered: Oct-06
| Posted on Thursday, January 15, 2009 - 11:22 pm: |
FERNANDO HDZ LOS ARCHIVOS LOS ENCUENTRAS EN http://www.ftabins.net tienes q registrarte . saludos ahora si voi a ser la meme (dormir)jejeje. |
MONTERREY ,
NUEVO LEON
MEXICO
Post Number: 2066 Registered: Oct-06
| Posted on Thursday, January 15, 2009 - 11:24 pm: |
Silver Member Username: Carolinajvc
Post Number: 140 Registered: Sep-06
| Posted on Friday, January 16, 2009 - 12:07 am: |
javy muchas gracias , te cuento que despues de tratar todas las formas y ver que nada dio resultado , recurri al metodo de las cavernas , le di 4 trastazos al swicht y todo volvio a la normalidad , gracias por ayudar , por cierto , no recomiendo a que pierdan la ternura pero en algunos casos (como este ) da resultados , gracias de nuevo |
Silver Member Username: Mty
Post Number: 702 Registered: Jun-05
| Posted on Friday, January 16, 2009 - 01:15 am: |
HOLA BUENAS NOCHES A TODOS. ALGUIEN DE MONTERREY, N.L. QUE PUEDA DECIR QUE OTRO SATELITE SE PUEDE CAPTAR APARTE DEL ECHO 7 DEL 8.10 Y DE BEV. Y HACIA DONDE SE TIENE QUE APUNTAR LA ANTENA. GRACIAS |
MONTERREY ,
NUEVO LEON
MEXICO
Post Number: 2067 Registered: Oct-06
| Posted on Friday, January 16, 2009 - 01:52 pm: |
JAJAJA TAMARA DIEGUEZ Q WENO ARREGLASTE TU PROBLEMA ES LO Q LE DECIA A NEO X Q MOVIENDOLE A SU RECIBER A VECES PUEDES ARREGLAR TUS PROBLAMAS . SALUDOS PATRICIA IO TENGO EL 97 W Q ES EL JAPONES NO SE SI TE SIRVA PERO DE ALGO A NADA CUANDO SE CAE DIS ES MUCHO MEJOR JAJAJA LAS CORDENADAS EXACTAS SON 174 GRADOS AZIMUT Y 59 GRADOS DE ELEVACION POL 10.5 NEGATIVO WENO ESTAS CORDENADAS LAS PUEDES LEER CON UNA BRUJULA DE CARA TULA DE AJUSTE . SALUDOS NOTA EL 97 W TIENE 230 CANALES DE VIDEO Y 150 DE AUDIO |
Silver Member Username: Elparrandero
Los angeles,
Ca
Los angeles
Post Number: 209 Registered: Dec-07
| Posted on Friday, January 16, 2009 - 02:05 pm: |
hola ,atodos y buen saludo,,de parte de su amigo el ,,solouno,,aqui reportando que alfin pude echar andar mi nfusion nuvenio sd ,,,y travajando bien asta ahorita,,claro yeva pocos dias pero bueno espero que asi siga ,,y mis captives work,,yasaven derepente como que seles va la luz ,pero ahi estamos ,,,bueno ,,quiero dar las gracias a todos lo que me apoyaron para que pudiera echar andar mis cajitas ,,gracias a todos ,, |
MONTERREY ,
NUEVO LEON
MEXICO
Post Number: 2068 Registered: Oct-06
| Posted on Friday, January 16, 2009 - 02:17 pm: |
WENO RAZA ANTERIORMENTE IO TENIA AL BEV APUNTANDOLE PERO CUANDO SE CAE DIS SE CAIA TMBN BEV Y MEJOR OPTE POR APUNTAR AL 97W Y TMBN QERIA AGARRAR EL HISPASAT PERO TENGO UN ARBOLOTE MARCA CHAMUCO JAJAJA Y NO ME DEJA BAJARLO . NOTA AUN LADITO DEL 97 W ESTA EL 93 W Q ESTA EN LA MISMA ELEVACION NOMAS ES DE MOVER UN POCO LA ANTENA AL LADO IZQ Y LO AGARRAS TMBN EL 93 TRAE AZTECA MEX CANAL 40 CANAL 7 CANAL 13 |
MONTERREY ,
NUEVO LEON
MEXICO
Post Number: 2069 Registered: Oct-06
| Posted on Friday, January 16, 2009 - 02:24 pm: |
Q WENO SOLO UNO Q SOLUCIONASTE TU PROBLEMA .SALUDOS WENO RAZA AL RATO NOS LEEMOS XQ VOI A COMER . NOS VEMOS |
Bronze Member Username: Luispansat
Irapuato,
Guanajuato
Mexico
Post Number: 76 Registered: Aug-06
| Posted on Friday, January 16, 2009 - 03:23 pm: |
  que tal. alguien me podria decir en donde cosigo un cable componente HDMI. es que tengo una pantalla. { 1080 ¡ solo con el cable componente. a un a v1 de un quemador dvd pero solo me da una { res de 480p o 576p por eso lo del cable. el satelite 93 y 97 lo puedo tomar con una antena de { SKY y un lnb de 10500 me podrian decir hacia que punto lo tengo que mover es que tenia 110 pero dicen que se nesecita una antena + grande. seria hacia bajo o arriba izq o der. bien gracias y saludos. desde la capital de las fresas. Pd = pansat 2700 a { original } game over }}} |
Bronze Member Username: Colarillo
Xxxxxxxxxxxxxxxxxx,
Xxxxxxxxxxxx...
Xxxxxxxxxxxx...
Post Number: 61 Registered: Nov-07
| Posted on Friday, January 16, 2009 - 05:39 pm: |
STUNT NROCK== yo he leido tus posts con esa pregunta y nadie tencontesta por eso boy a meter mimcucharota esto es lo que yo se=== no porque le pongas el cable HDMI te va a dar la resolucon de 1080i o 1080p te va a dar esa resolucion solo que trengas canales de HD o quetengas un DVDplayer BLU-RAY que son los que mandan la senal con esaS RESOLUCIONES ojala salgas de la duda SUERTE |
Bronze Member Username: Mexdss
Monterrey,
N.L.
Mexico
Post Number: 94 Registered: Sep-06
| Posted on Friday, January 16, 2009 - 05:59 pm: |
Alguien sabe donde van a pasar mañana el juego de Rayados? Saludos y gracias. |
Post Number: 703 Registered: Jun-05
| Posted on Friday, January 16, 2009 - 06:11 pm: |
QUE BIN ESTAN USANDO PARA PANSAT 2700 QUE NO SEA EL 301, PORQUE ESE PIERDE LA IMAGEN CADA 2 MINUTOS. |
Bronze Member Username: Fpeflo
Juarez Mexico
Post Number: 65 Registered: Mar-08
| Posted on Friday, January 16, 2009 - 06:14 pm: |
pansat 2800 congelandose. |
Bronze Member Username: Crimaso
Post Number: 35 Registered: Jan-07
| Posted on Friday, January 16, 2009 - 06:19 pm: |
hola que bin esta funcionando en el pansat 3500? |
Bronze Member Username: Mabe
Post Number: 72 Registered: Mar-08
| Posted on Friday, January 16, 2009 - 06:20 pm: |
HOLA, A TODOS TAMBEN SE ESTAN SE ESTAN FLUCTUANDO CADA MINUTO LOS CW600S |
Gold Member Username: Vianche
Montreal,
Quebec
Post Number: 1016 Registered: Sep-06
| Posted on Friday, January 16, 2009 - 06:29 pm: |
hola ami tambien me esta pasando no hay nada para arreglar el problema |
Juarez Mexico
Post Number: 66 Registered: Mar-08
| Posted on Friday, January 16, 2009 - 06:36 pm: |
no hay nada apenas empeso. |
Silver Member Username: Joel_eduardo
Tamaulipas
Mexico
Post Number: 170 Registered: Nov-06
| Posted on Friday, January 16, 2009 - 06:40 pm: |
Patricia: pARA EL PANSAT 2700A se esta usando el bin X_87BL_081215_B75_V203_API_FEMU , AUNQUE HACE UNOS MOMENTOS SE ESTABA CONGELANDO LA IMAGEN PERO PUEDE SER POR EL MAL TIEMPO,(YO ESTOY EN TAMAULIPAS Y ESTA PESIMO EL CLIMA) |
Tamaulipas
Mexico
Post Number: 171 Registered: Nov-06
| Posted on Friday, January 16, 2009 - 06:43 pm: |
El bin ese que menciono lineas arriba es un bin pasado y esta disponible en ftabins.net |
Bronze Member Username: Help12
Post Number: 19 Registered: Oct-05
| Posted on Friday, January 16, 2009 - 06:49 pm: |
Ni modo hay que esperar por nuevos arreglos ya el 203 empezo a frizarce |
Tamaulipas
Mexico
Post Number: 172 Registered: Nov-06
| Posted on Friday, January 16, 2009 - 06:53 pm: |
EL BIN APARECE ASI EN FTABINS.NET |
New member Username: Nolin61
Post Number: 1 Registered: Nov-08
| Posted on Friday, January 16, 2009 - 08:01 pm: |
Buenas noches a todos , por favor alguien me puede explicar , como puedo llevar mi viewsat 2000 platinium a cero , y cuales son los programas que tengo que entrarle para subirla de nuevo. por favor alguna alma que apiade de mi. |
Silver Member Username: Rossyjess
Post Number: 595 Registered: Oct-05
| Posted on Friday, January 16, 2009 - 08:14 pm: |
La fiesta empezo otra vez a esperar |
Juarez Mexico
Post Number: 67 Registered: Mar-08
Jesus en esta direccion encuentras todo lo que necesitas. http://www.ftatalk.com/forum.php? |
Juarez Mexico
Post Number: 68 Registered: Mar-08
| Posted on Friday, January 16, 2009 - 08:18 pm: |
tambien aqui www.ftabins.net www.ftaup.com WWW.FTAUP.COM |
Juarez Mexico
Post Number: 69 Registered: Mar-08
| Posted on Friday, January 16, 2009 - 08:21 pm: |
Jesus encuentra tu modelo y revisa lo que nececitas solo registrate es gratis |
Post Number: 2 Registered: Nov-08
| Posted on Friday, January 16, 2009 - 08:32 pm: |
MUCHAS gRACIAS AMIGOS LO INTENTARE PUES ESTOY DE APRENDIZ, PERO MUY AGRADECIDO, |
Bronze Member Username: Arrollador_de_perras
Post Number: 88 Registered: Apr-08
| Posted on Friday, January 16, 2009 - 08:33 pm: |
ALGUN BIN KE TRABAJE BIEN CON EL PAN'SAT350 |
Silver Member Username: Juancho
CANADA
Xx
Post Number: 391 Registered: Jun-08
| Posted on Friday, January 16, 2009 - 08:34 pm: |
si su reciver se congela, entonces a esperar por nuevos fixes, ningun viejo bin trabaja |
Post Number: 704 Registered: Jun-05
| Posted on Friday, January 16, 2009 - 08:47 pm: |
GRACIAS JOEL, |
Silver Member Username: Amigo
PUERTORICO
Post Number: 173 Registered: Aug-06
| Posted on Friday, January 16, 2009 - 09:30 pm: |
buenas noches a todos se fue todo pansat 3500 coolsat6000 nada funciona a cojerlo suave y a dormir temprano jejeje saludos a todos |
Tijuana,
Baja California
Mexico
Post Number: 320 Registered: Aug-06
| Posted on Friday, January 16, 2009 - 09:48 pm: |
alguien sabe como intalar una camara a mi computadora podrian decirme como intalarla por favor garcias |
CANADA
Xx
Post Number: 392 Registered: Jun-08
| Posted on Friday, January 16, 2009 - 09:58 pm: |
primero de todo tienes que postear el modelo y marca de camara,segundo el sistema operativo de tu pc, para que busques los drivers , si es que no tienes el cd para instalarlo, usualmente windows xp professioinal 2 o 3, reconocen e instala la camara automaticamente al solo conectar la camara al usb port, y si el sistema no puede instalarlo te dice que lo que conectastes no funcionara correctamente, si tienes el cd , primero . |
Bronze Member Username: Mayra
Chihuahua,
Chihuahua
Chihuahua
Post Number: 19 Registered: Feb-08
| Posted on Friday, January 16, 2009 - 11:02 pm: |
hola buenas noches a todos hay algun bin para los convertidos puff |
Chihuahua,
Chihuahua
Chihuahua
Post Number: 20 Registered: Feb-08
| Posted on Friday, January 16, 2009 - 11:05 pm: |
Gold Member Username: Juancholagarto
Mexico City,
D.F.
Mexico
Post Number: 1082 Registered: Oct-07
| Posted on Friday, January 16, 2009 - 11:47 pm: |
Buenas noches: Al menos la Captive 600 Premium parece que aguantó. Funcionando al 100%. Saludos |
Silver Member Username: Albertome2
Post Number: 129 Registered: Nov-08
| Posted on Saturday, January 17, 2009 - 12:26 am: |
al parecer el provedor no quierrre que veamos el super bowl lea porque http://rabbitslair.net/forums/index.php |
Gold Member Username: Cavelar
WOODBRIDGE,
ONTARIO
CANADA
Post Number: 1489 Registered: Jul-06
| Posted on Saturday, January 17, 2009 - 12:31 am: |
Alberrto//// "SIGUES ENGAñANDO A LA GENTE".... ///////NO DEN CLIK A ESE LINK//////// |
WOODBRIDGE,
ONTARIO
CANADA
Post Number: 1490 Registered: Jul-06
| Posted on Saturday, January 17, 2009 - 12:34 am: |
LOS CODER DE C00LSAT 4/5/6K SE ADELANTARON Y YA ESTA EL BIN 190 TRABAJANDO AL 100% BAJENLO DE LOS SITIOS ACOSTUNBRADOS... |
Silver Member Username: Miguel3000
Post Number: 326 Registered: Jan-08
En el pansat 3500..prueben el V307 FULL eSTA TRABAJANDO PERFECTO!! |
Riverside,
Ca
Usa
Post Number: 2 Registered: Jul-06
| Posted on Saturday, January 17, 2009 - 12:50 am: |
gracias javy por tu informacion |
Post Number: 705 Registered: Jun-05
| Posted on Saturday, January 17, 2009 - 01:01 am: |
hay algo para los puff? |
Silver Member Username: Vikosolis
Monclova Mexico
Post Number: 256 Registered: Nov-06
| Posted on Saturday, January 17, 2009 - 02:05 am: |
ignoren a alberto, es un idiota |
Post Number: 89 Registered: Apr-08
| Posted on Saturday, January 17, 2009 - 02:28 am: |
VAN DOS BIN 307 KE LE DESCARGO A MI CAJITA PANSAT3500 Y SE SIGUE FRIZEANDO CADA 10 SEGUNDOS |
Los angeles,
Ca
Los angeles
Post Number: 210 Registered: Dec-07
| Posted on Saturday, January 17, 2009 - 02:44 am: |
hola buenas noches atodos espero que la esten pasando bien por que to si ,, |
Bronze Member Username: Pao_meche
Post Number: 29 Registered: Sep-08
| Posted on Saturday, January 17, 2009 - 08:56 am: |
ya subio el puff esta en dssfeedback.com/index2.php hay que registrarse pero no es dificil. |
Bronze Member Username: Irvingoruiz
Post Number: 70 Registered: Feb-08
| Posted on Saturday, January 17, 2009 - 09:15 am: |
Hola a todos...Alguien ha tenido problemas cargando el bin fwank7-team 204 a mi se me congela en la letra F despues de cargarlo.......??????? |
Montreal,
Quebec
Post Number: 1017 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 09:22 am: |
buenos dias ami tambien me sucede se queda parado en la f y no anda mas |
Post Number: 71 Registered: Feb-08
| Posted on Saturday, January 17, 2009 - 09:28 am: |
Entonces esperemos por otro fix..Gracias Vivian |
Gold Member Username: Canada_havana
Post Number: 1695 Registered: Sep-07
| Posted on Saturday, January 17, 2009 - 09:37 am: |
BUENOS DIAS Y BENDICIONES AL FORUM,,,, |
Post Number: 72 Registered: Feb-08
| Posted on Saturday, January 17, 2009 - 09:42 am: |
Aparte de Vivian, alguien mas ha tenido problemas con el nuevo Bin 204?? Hay alguna manera de hacerlo funcionar>?? Gracias de antemano |
Post Number: 73 Registered: Feb-08
| Posted on Saturday, January 17, 2009 - 10:26 am: |
Encontre esto en ftabins: A working solution: The best known way of clearing all the junk for the memory is to reconvert to PUFF. Therefore, after my box got stuck of "F" a couple of times, I ran the PUFF 1.0.1 conversion once again to clear the memory as best as I could and then reloaded the new 204PUFF Bin and the box rebooted all the way to "ON". |
Post Number: 30 Registered: Sep-08
| Posted on Saturday, January 17, 2009 - 10:27 am: |
LE ACABO DE METER EL PUFF Y AUN ESTA EN LA F |
Post Number: 31 Registered: Sep-08
| Posted on Saturday, January 17, 2009 - 10:49 am: |
IRVING Y ESO EN ESPAñOL QUIERE DECIR???? |
Montreal,
Quebec
Post Number: 1019 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 11:30 am: |
lei aqui en satelites que la caja se queda en f por falta de memoria, y que hay que reocnvertirla apuff con el 101, y alli no entende nada podrian alguien aclararme eso |
Silver Member Username: A_morgan
Mty.,
N.L.
Mex.
Post Number: 264 Registered: Nov-05
| Posted on Saturday, January 17, 2009 - 11:34 am: |
Alhondra..... A mi me pasa igual!!! Saludos A_Morgan |
Bronze Member Username: Castromty
NL
Mexico
Post Number: 88 Registered: Jan-07
| Posted on Saturday, January 17, 2009 - 11:52 am: |
Buenos días a todos, Cargue el BIN V204 a mi Lava y se quedó en la última "F" de PUFF y ya no quiso pasar de ahí, no se que pasó. Le puse el V202 y ya funcionó de nuevo pero se vá cada 2 minutos, se me va el tiempo en puros corajes....jajajajaja. Esperemos que haya solución. Saludos |
New member Username: 674
Post Number: 10 Registered: Jan-09
| Posted on Saturday, January 17, 2009 - 12:09 pm: |
buenas a todos aqui estamos con mucho frio ! y con esto dañado no es justo! alguien que nos pueda ayudar el puff 204 no funciona |
Montreal,
Quebec
Post Number: 1020 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 12:13 pm: |
muchachos y muchachas por fin me trabajo el 204 , pero solo lo logre instalando la boot 101y con el loader fwnak logre ponerle el 204 y hasta ahora recien termine y esta funcionando todo eso lo encontre en dssfedback |
Post Number: 141 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 12:47 pm: |
buenos dias , vivian y de donde descargo el 204??? y el boot 101 ,gracias |
Montreal,
Quebec
Post Number: 1021 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 12:53 pm: |
yo lo encontre en dssfeedback, pero voy a tratar de mandarte los files |
Post Number: 74 Registered: Feb-08
| Posted on Saturday, January 17, 2009 - 12:55 pm: |
Este es el Link donde encontraran todo lo necesario para poder utiliza el bin 204 http://www.dssfeedback.com/forums/showthread.php?t=92263 |
Montreal,
Quebec
Post Number: 1022 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 12:58 pm: |
los loaders no te los puedo mandar dice que son mu grandes y yo no se como hacerlo tamara pero te mande la boot 101 y el bin 204 |
Bronze Member Username: Fletes
Montreal,
Quebec
Post Number: 11 Registered: Aug-08
| Posted on Saturday, January 17, 2009 - 01:01 pm: |
hola a todos yo tengo el mismo problema instale en primera instancia el v204 puff bin pero se quedo en F... luego puse el boot 101 y despues recarge el bin v204 puff y sigue congelado alguin puede decirme que metodo utilizo para realizar la conversion al boot 101 talvez yo segui mal el procedimiento. Gracias de ante mano a cualquir ayuda! |
Post Number: 75 Registered: Feb-08
| Posted on Saturday, January 17, 2009 - 01:04 pm: |
traten de bajar de aqui las herramientas para poner a funcionar el bin 204 Copien la direccion de aqui abajo y peguenla en la barra de direcciones de tu browser(I.explorer etc) Espero funcione http://rapidshare.com/files/185001844/ISO-8859-1__Pansat_2500_Fix_1-17-09.zip |
Montreal,
Quebec
Post Number: 1023 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 01:15 pm: |
Necesita el loader el Fwank7 Team-PUFF Loader 2500 Conversion Loader FW7 para carger el bin 204 |
CANADA
Xx
Post Number: 393 Registered: Jun-08
| Posted on Saturday, January 17, 2009 - 01:26 pm: |
aqui les posteo el paquete del fix para la F http://www.ftaraza.com/showthread.php?t=7767 |
Post Number: 706 Registered: Jun-05
| Posted on Saturday, January 17, 2009 - 01:37 pm: |
vivian como estas? oye no quiere agarar el boot 101 como le hiciste porque me pone error |
Bronze Member Username: Omygonzalez
Monterrey
Post Number: 87 Registered: Oct-06
| Posted on Saturday, January 17, 2009 - 01:47 pm: |
hola... hace un tiempo que no hechaba a andar mi equipo y veo que esta pasando algo con los puff... tengo un pansat 2500A y el ultimo bin que tiene es un puff... hay alguna actualización reciente para estos equipos??? |
Montreal,
Quebec
Post Number: 1024 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 02:22 pm: |
necesitas el loader que esta en el post 1023 y tienes que dejar que la caja diga on y de ahi download el boot 101 |
Silver Member Username: Elmoxp
Ottawa,
Ontario
Post Number: 255 Registered: Jun-06
| Posted on Saturday, January 17, 2009 - 02:26 pm: |
bueno le cuento como es la historia ahora con los convertidos tiene que limpiarlos ya que se han bajando demasiados bins y estan saturados de informacion recuerden qeu el nuevo bin esta un poquito mas grandesito entonces necesita mas memoria que hay que ha cer? pues bajar Ukr_-PUFF-ConversionFlashFix.bin, eso lo limpia cuando lo tengan instalado se va aver PUFF PUFF muchas veces dejelo por dos minutos y despues bajan el nuevo Bin 204 y listo a ver futbol recuerden hay que bajar los canales otra vez por que esto deja las cajitas sin nada |
Post Number: 33 Registered: Sep-08
| Posted on Saturday, January 17, 2009 - 03:06 pm: |
Elmo donde consigo eso |
Post Number: 76 Registered: Feb-08
El nuevo bin 204 se congela siempre???? Por lo menos a mi me pasa y a Uds.??? |
Silver Member Username: Luckas25
Eagle pass,
Texas
Usa
Post Number: 115 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 03:12 pm: |
ami me marca error en el modelo... el mi es un pansat 2500 pero no aparce en la lista...alguien q sepa?? |
Post Number: 34 Registered: Sep-08
| Posted on Saturday, January 17, 2009 - 03:26 pm: |
se esta frizzando |
Post Number: 707 Registered: Jun-05
| Posted on Saturday, January 17, 2009 - 03:28 pm: |
A MI TAMBIEN SE ME ESTA CONGELANDO. JUAN MANUEL YO LE PUSE LIFETIME. |
Silver Member Username: Tetuscosmicus
Post Number: 366 Registered: Apr-08
Alondra.. ftabins.net Saludos.. |
Monterrey
Post Number: 88 Registered: Oct-06
| Posted on Saturday, January 17, 2009 - 03:42 pm: |
porfavor, alguien digame que h*acer... cual es la ultima conversion para los puff? como la empiezo? hay algun post con instrucciones? tengo un pansat 2500 con puff y no se por donde empezar :S |
Post Number: 708 Registered: Jun-05
| Posted on Saturday, January 17, 2009 - 03:49 pm: |
QUE bin tiene tu pansat? es original? |
Monterrey
Post Number: 89 Registered: Oct-06
| Posted on Saturday, January 17, 2009 - 04:02 pm: |
es un megasat yt6688, dice: Fwank7 API:75-3.00_EUbX *Jvvh-Team-PUFF* PUFF * Ver101 no recuerdo cual bin es pero se lo cargue por ahi del 3 o 4 de enero |
Monterrey
Post Number: 90 Registered: Oct-06
| Posted on Saturday, January 17, 2009 - 04:08 pm: |
tengo el Fwank7_Jvvh-Team-PUFF_300 instalado en mi pansat 2500a....... seguno lei hay una conversion, pero, como se empieza? |
Silver Member Username: Borinick
Post Number: 487 Registered: Mar-07
| Posted on Saturday, January 17, 2009 - 04:11 pm: |
Omar Gonzales esa caja es un clone de pansat 2500 tienes que convertila y despues ver si tiane el programa de puff si cuando la prendes dice puff ya esta convertida vas encuentra todo lo que necesita por los clones de puff 2500 ok. |
Silver Member Username: Cancinoi
Santo Domingo Este, R D. Republica Do...
Post Number: 368 Registered: Oct-07
Viewsat pro y xtremen trabajando como debe ser... |
Monterrey
Post Number: 91 Registered: Oct-06
| Posted on Saturday, January 17, 2009 - 04:15 pm: |
de hecho esta convertida a puff... pero lei que hay que convertirla de nuevo y ahi es en donde estoy atorado... estoy buscando posts por todos lados y nada |
Post Number: 709 Registered: Jun-05
| Posted on Saturday, January 17, 2009 - 04:17 pm: |
METETE EN ESTA PAGINA dssfeedback TE INSCRIBES ES GRATIS LUEGO BAJAS EL PAQUETE QUE DICE PANSAT FIX 1-17-09, DE AHI CON EL APARATO APAGADO CON EL CONTROL REMOTO LE CARGAS EL BOOT 101 CON EL CARGADOR QUE DICE 2700 CUANDO TERMINE, Y VUELVA A PRENDER SOLO LO APAGAS DEL SWITCH DE ATRAS Y CON EL OTRO CARGADOR LE CARGAS EL BIN 204, Y YA ES TODO PERO NO ESTA TRABAJANDO BIEN PUES SE ESTA CONGELANDO. |
Eagle pass,
Texas
Usa
Post Number: 116 Registered: Sep-06
| Posted on Saturday, January 17, 2009 - 04:24 pm: |
me marca faled conection al intentar cartga el 204...alguien sabe porque?? |
Post Number: 367 Registered: Apr-08
| Posted on Saturday, January 17, 2009 - 04:38 pm: |
fwank7-team 204 puff se esta frisando mucho.. hay que esperar nuevo bin o arreglo.. Saludos raszaaaaaaaaaaaaaaaaaa.. |
Post Number: 710 Registered: Jun-05
| Posted on Saturday, January 17, 2009 - 04:41 pm: |
JUAN SI ES PUFF EL QUE ESTAS TRATANDO DE CARGAR FIJATE EN MI POST ANTERIOR ESTAN LAS INDICACIONES PARA PONERLO ES EL POST 709. YO BATALLE MUCHO PORQUE NO HAY INSTRUCCIONES |
Post Number: 368 Registered: Apr-08
| Posted on Saturday, January 17, 2009 - 04:57 pm: |
Algo para las CW600s Porfisssss.... |
Monterrey
Post Number: 92 Registered: Oct-06
| Posted on Saturday, January 17, 2009 - 05:09 pm: |
a ver si entendi... primero, tengo un equipo clon de pansat 2500A con el bin Fwank7_Jvvh-Team-PUFF_300 ... lo que tengo que h*acer es esto: "PANSAT FIX 1-17-09, DE AHI CON EL APARATO APAGADO CON EL CONTROL REMOTO LE CARGAS EL BOOT 101 CON EL CARGADOR QUE DICE 2700 CUANDO TERMINE, Y VUELVA A PRENDER SOLO LO APAGAS DEL SWITCH DE ATRAS Y CON EL OTRO CARGADOR LE CARGAS EL BIN 204, Y YA ES TODO PERO NO ESTA TRABAJANDO BIEN PUES SE ESTA CONGELANDO"????? |
Silver Member Username: Alp
Post Number: 134 Registered: Dec-06
| Posted on Saturday, January 17, 2009 - 05:32 pm: |
Alquien que me pueda ayudar, tengo un pansat 2500A convertido a puff le coloque el bin 204 pero me sale level 30 quality 0 ya verifique los settings y nada que podra ser??? |
Post Number: 135 Registered: Dec-06
| Posted on Saturday, January 17, 2009 - 05:46 pm: |
Disculpen ya verifique y tenia mal conectado el cable, gracias de todas maneras |
Tamaulipas
Mexico
Post Number: 173 Registered: Nov-06
| Posted on Saturday, January 17, 2009 - 07:07 pm: |
Instale a mi pansat 2700A el bin mas reciente que viene siendo este: X_87BL_081215_B75_V204_APIFEMU y de todas formas sigue frizandose la imagen, primero la imagen se congela y regresa de inmediato, luego se congela por unos segundos mas y por ultimo se pierde, hace esto de manera ciclica, si alguien tiene algo mejor que esto que lo postee por favor |
Silver Member Username: Lribon
Ajax,
On
Post Number: 333 Registered: Jan-07
| Posted on Saturday, January 17, 2009 - 07:17 pm: |
hola alguien me podria ayudar, yo tengo una con pansat convertida a puff y estoy tratando de hacerl el proceso para instalar el 204V, pero cuando trato de montar el boot 101, me sale el siguiente error.... alguien me puede ayudar?? Cable esta conectado, lo he intentado con la caja encendida y con la caja reiniciandola. |
