Thread: H07 error on a Panasonic DVD RP62 player |
New member Username: Tashidad
Greenville,
NC
United States
Post Number: 1 Registered: Jan-09
| Posted on Friday, January 16, 2009 - 03:26 pm: |
I know there's been some conversation about this on this message board and I've gone to the ledcar website to try and dismantle the module where the motor-gearing and spindle are so I can at least try to lube the motor with Tri-Flow or sewing machine oil but I can't get the cover off the module. The ledcar site says there's clips that can be pressed in and it should slide off but I'm having no luck. The unit I'm dealing with looks exactly like the one in the ledcar photos Anyone out these got some advice?? |
Gold Member Username: Samijubal
Post Number: 4045 Registered: Jul-04
| Posted on Friday, January 16, 2009 - 06:17 pm: |
All you need to do is get a small amount of oil on the spindle shaft and let it run down to the motor. This is a temporary fix only, the player will soon be dead. |
Platinum Member Username: Glasswolf
NW,
MI
Post Number: 12319 Registered: Dec-03
| Posted on Friday, January 16, 2009 - 06:32 pm: |
if ya like that RP62, I'll sell you my pristine RP82 with the faroudja DCDi chipset. I'm upgrading to a BD55. I have the manual, remote, original box etc.. no damage at all. |
Greenville,
NC
United States
Post Number: 2 Registered: Jan-09
| Posted on Friday, January 16, 2009 - 08:57 pm: |
Hey Glass--- I don't know what your talking about with the RP82 and what the heck is a faroudja DCDi chipset? And what is a BD 55? You in NW Michigan?? Wouldn't be near Petosky or Charlevoix by any chance?? |
New member Username: Moses_x
Kampala Uganda
Post Number: 1 Registered: Feb-09
| Posted on Friday, February 06, 2009 - 06:02 am: |
my panasonic dvd/cd player rv32 shows HO7 error message any advice |
