Home > Message Board > Home Video > DVD Recorders > Problems hooking up Toshiba HDD/DVD r...
Author Thread: Problems hooking up Toshiba HDD/DVD recorder to DTV converter box
Username: Amp1220
I tried to hook up my Toshiba HDD/DVD recorder to the DTV converter box. The only channel that showed up on my program list was channel 4 (the channel I selected on the converter box). Now, the other local channels do not appear. I am currently connected to an analog antenna. Can anyone tell me how to get the other channels to appear? Thanks!
Username: Samijubal
Post Number: 4041
Connect the antenna in to the DVD recorder then the converter, that will let the TVGOS download the info and shouldn't affect the converter if you have a good signal. If you do get problems when connected that way, you may need to add a signal booster.
Username: Samijubal
Post Number: 4046
Supposedly the DTVpal is the only converter compatible with the TVGOS. I can't verify that but look here:
http://www.macrovision.com/dtv/10057.htm
http://www.macrovision.com/dtv/10053.htm
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > DVD Recorders > Problems hooking up Toshiba HDD/DVD r... [ « Previous ] [ Next » ]
