Thread: White Westinghouse VCR |
New member Username: Gesvendor
Ludington,
MI
United States
Post Number: 1 Registered: Jan-09
| Posted on Monday, January 12, 2009 - 03:51 pm: |
I have a White Westinghouse VCR model WVCR8006. I have used the onscreen menu to set up preprogrammed times for it to record. I do not know how to then turn on this feature so that the VCR actually turns itself on to begin recording at the appropriate time. Can someone please help me? |
Gold Member Username: Samijubal
Post Number: 4029 Registered: Jul-04
| Posted on Monday, January 12, 2009 - 05:08 pm: |
If memory serves me right, you have to press a remote key for a few seconds, try the record key. I don't remember if the power is supposed to be on or off or if it matters. |
Platinum Member Username: Glasswolf
Raccoon City,
MI
Post Number: 12269 Registered: Dec-03
| Posted on Monday, January 12, 2009 - 05:29 pm: |
Also perhaps search google for a PDF format manual for the specific model of VCR. PS, I was just in Ludington not 30 minutes ago.. haha I live about 20 minutes East of there. |
Post Number: 4030 Registered: Jul-04
| Posted on Monday, January 12, 2009 - 08:40 pm: |
A VCR has to be off to timer record. Most VCRs automatically activate the timer when the VCR is turned off. There were some that didn't work that way though. Some of the Funai recorders activated the timer by pressing a remote key for 5 seconds. |
Post Number: 4031 Registered: Jul-04
| Posted on Tuesday, January 13, 2009 - 12:05 am: |
After thinking about it, I think it's the power button on the remote, it may work on the unit itself too. |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 2428 Registered: Feb-04
| Posted on Tuesday, January 13, 2009 - 07:26 pm: |
"I just bought a White westinghouse VCR used from another student here. It works fine. I had the same problem as you for about an hour. My boyfriend then told me the way to do it is hold the off button or a few seconds when turning off the VCR after you set a program. This activates the timer. Mine is model WVR-8004. It drove me crazy at first too, but thank goodness he figured it out." http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=453847#POST453847 |
New member Username: Founddumbed
Cranbrook,
BC
Post Number: 1 Registered: Feb-09
| Posted on Wednesday, February 04, 2009 - 02:06 pm: |
It (the manual) was lost and now it's found! Follow the display as directed and activate the timer by holding the power button down for at least 5 seconds. The manual states,"2 - 4 seconds", but I timed it and it was closer to 5 -6 seconds. Do not go back to the MENU before setting the timer. Stopping a programed recording in progress can be accomplished the same way. |
New member Username: Tok
Albuquerque,
NM
Post Number: 1 Registered: Jun-09
| Posted on Sunday, June 21, 2009 - 03:53 am: |
Hello, I am in a bit of a pickle. I have a WW wvcr-8004 and there is a tape stuck in it. I tried a few trouble shooting things with it. I tried to see if the vcr would work with a tv, and it did not turn on. I went on furter to cut and re wire the powercord, and it did not take. I wonder if there is even an electrical issue. I think the problem is more mechanical. I would love to dig in and try to save my tape, but as of now, I'm at bit of a loss. I dont want to take something off and then later not remember where it goes. I was wondering if there is anywhere that anyone knows of that I can get a manual for this piece of machinery. Thanks a bunch, Tok |
