Home > Message Board > Home Video > TV Basics > Mitsubishi WS-55908 Power on problem
Author Thread: Mitsubishi WS-55908 Power on problem
Username: Donsim
Simi Valley, CA
Ventura
Need Help, When I try to turn on the power to the TV the green light goes on for about 3 seconds then there’s a click and the set turns off. Is this a safety feature built into the TV and if so dose anybody have an idea what’s going on?
Note the blue / Pb B would sometimes not work on the DTV connector, if I pushed on the circuit board where the cables hook up the color would return. Last time this happened after I pushed on the board the TV not turning on thing started.
Is time for a TV repair man or time for a new TV?
Username: Marcoalomoto
Silver spring, Md
Usa
I have a Mitsubishi model # WS 65713 since 2 weeks ago the light in time bottom is blinking and I pointed with a paperclip ans it still the problem, also I disconnected all cables from the television and I unplugged the cord from the wall about 24 hours and put it back, but I don't see nothing work. Can you tell me what I can do.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > TV Basics > Mitsubishi WS-55908 Power on problem [ « Previous ] [ Next » ]
