Home > Message Board > Home Video > Satellite TV > SOLO HISPANOS--2 > Archive through December 23, 2008
Author Thread: Archive through December 23, 2008
Username: Juancho
CANADA
Xx
Post Number: 368
buscando la tarjeta.
New MApcall Glitch in the stream asof 4:14 CST
Ok guys, this can show you the reasons why some recievers have started freezing up, or have scrambled channels now.
New Mapcall 0x39 3E with a form of N3 was insurted into the stream and went active at 4:14 CST today. If you saw freezing on the channel, and a sound acompanying it, that was the newest version of MAP0x393E,v2.9.4.1 this is a form of N3 they are trying out to stop Nfusion attacking the CAMS directly thur the ROM card used, this procedure is to support the process of finding the location of the server the Nfusion Server is now on.
It actived a code, to transmit the Rom Cards Indentity back to the provider thur there own interent server.
I would think if Nfusion finds this all Nfusions will be shtdown ASAP, to keep them from finding the numbers to indentify this card, and IE: User/Name/Address Information, this is a solo attack, but watch to see what happens...
Viewsat unit froze only for less than 5 seconds, until tone stopped. Sonicview went out for more than 1 minute, not sure about anything else as I was not monitoring them all.
Anyway, lets see what happens next.
0dd
PS/ if I where anyone connected to IKS thur there Nfusion I would disconnect and turn off. Its just a warning
__________________
Thanks everyone here at XXXX.Com you guys are wonderful!!
PS/ I dont mind you asking me questions, but please link your questions to a post here on the site, it will be more helpful to you and myself.
Nueva MApcall de dn
Ok chavos , estas son las razones por las cuales algunos receptores han comenzado a congelarse, o que tienen ahora los canales codificados(scrambled channals.
Nueva Mapcall 0x39 3E con una forma de N3 fue implementada por DN hoy a las 4:14 (central standard time)CST . Si usted vio la congelación en el canal, y un sonido que acompano a este congelamiento, esta fue la mas reciente versión más de MAP0x393E, v2.9.4.1 esta es una forma de N3 que ellos están tratandopara parar a Nfusion,atacando las CAMS directamente a traves de la ROM card que usan (Nfusion) , este procedimiento es para apoyar el proceso de encontrar la ubicación del Nfusion Server está ahora en proceso.
Este (dik)activo un código, para transmitir las Rom Tarjetas Indentity ( Identificar las tarjetas)al proveedor(dik) a traves de su propio server de internet.
Yo pienso que si Nfusion se da cuenta de esto todas las Nfusions serian desconectadas ( del server)tan pronto como sea posible(ASAP,) para impedir que continue la búsqueda de los números para indentificar esta tarjeta, y la IE: usuario / Nombre / informacion de la Dirección , se trata de un solo ataque, pero ten cuidado a ver qué pasa .. .
Viewsat unidad sólo se congeló durante menos de 5 segundos, hasta que el sonido se paro. Sonicview se tardo mas más de 1 minuto, no seguro acerca de otros que yo no estaba monitoreando a todos ellos.
De todos modos, vamos ver lo que ocurre a continuación.
0DD
PS / Si yo tuviera conectado la Nfusion a traves de IKS yo la desconectaria y la apagara . Su sólo una advertencia
__________________
Gracias a todos aquí en XXXXX.Com,, ustedes son maravillosos!
Username: Juancholagarto
Mexico City, D.F.
Mexico
Post Number: 1062
OK compadre Ernesto:
Voy a probar primero a ver si todavía funciona ese polarotor que tengo. Gracias por toda la info compadre Ernesto.
Bueno, dejo grabando la película de Indiana Jones y a dormir, porque mañanita hay que trabajar.
Saludos
Username: Nadadesat
Post Number: 6333
ESTE ES EL SKEW CONTROL COMPADRE Y LOS UNICOS FTA QUE TRAEN ESTA FUNCION SON LOS PANSAT.
MIRE COMPADRE PARA QUE IDENTIFIQUE EL SKEW CONTROL AQUI LE PONGO UN PANSAT 2700 EN LA PARTE TRASERA Y LOS CABLES DEL SERVOMOTOR
VAN A LAS DOS ENTRADAS QUE SE IDENTIFICAN CON LOS PUNTOS ROJOS.
Username: Mabe
Post Number: 70
creo que me ignoraron :-(
Mexico City, D.F.
Mexico
Post Number: 1063
Maria:
Perdón, pero no había visto tu post. Posiblemente esté mal el número de puerto en el loader. Ya intentaste cambiarlo de puerto COM?
Muchas gracias compadre por esa información adicional. Usted siempre tan explícito en toda su información.
A dormir se ha dicho.
Saludos
Username: Rexio_mty
Post Number: 807
compadre Ernesto como vez eso de NFUSION, buena informacion de mi compadrito juanramirezone...
Username: Rexio_mty
Post Number: 808
oigan estoy tratando de cargarle el bin nuevo a mi caja pansat 2700 pero no quiere , es como si usara un cable incorrecto, sera que ya cambio algo o bien mi cable ya no funciona??
Username: Rexio_mty
Post Number: 809
el cable es un null modem y el loader que tengo es X-87BL Loader v27.02 [X-87BL], que sera , que sera???
le tendre que probar con una bombilla??
Username: Nadadesat
Post Number: 6334
SALUDOS COMPADRE REXIO MTY.
PUES BUENA INFORMACION, PERO AL QUE LE DEBE DE PREOCUPAR ES A MI OTRO COMPADRE CARLOS AVELAR.
YO LO QUE LES DIGO ES QUE NO COMPREN NADA HASTA QUE YA ESTE TODO CAIDO Y VEAMOS QUE APARATO ES EL BUENO.
PERO PARA ESTO FALTA UN RATO.
CAUTELA ANTE TODO.
MIENTRAS TANTO GOZEMOS EL PRESENTE.
OIGA COMPADRE COMO LA VE?
POR 139 PESOS 25 CANALES DE DISH MEXICO Y PARA FEBRERO YA ESTA JALANDO AKA EN MONTERREY.
YA ME INFORME EN LAS OFICINAS DE DISH ESTAN EN LEONES CUMBRES SEGUNDO SECTOR, ESTA UNJ AMIGO MIO ALLI TRABAJANDO COMO RECLUTADOR.
PERO COMPARANDO NO ES NADA PARA EL DISH AMERICANO.
SALUDOS.
Username: Miguel3000
Post Number: 309
IKS?? I DON'T THINK SO!!
Al menos yo...es lo ultimo que usaria para ver FREETV!!
Pero como dijo el CIEGO..ya veremos,,ya veremos!!
A ver que pasa con el tan afamado N3.
Tal ves ni sea tan duro de romperlo..
Pero eso ya es tarea de los que verdaderamente saben,,,,,CODERS??maybe!!
Saludos
Ringgggggggggg
Ringgggggggggggggggggg
Y esto que escribo no me lo dijo ningun BOSS ok??
Username: Eariverag
Guatemala
Post Number: 260
Buen día amigos,
Maria,
Usaste un cable Usb a Serial? En el cual conectaste tu cable null?
Quiza no hayas instalado el driver correspondiente para es cable aún,
Saludos,
Username: Eariverag
Guatemala
Post Number: 261
Para los que necesiten software...
www.zonadd.net solo hay que registrarse, es gratis.
El 90% en descarga directa (servidor propio) sin esperas de ningun tipo como RapidShare, MegaUpload, MediaShare, etc...
Username: Sergio_verdugo
Hermosillo, Sonora
Mexico
Post Number: 743
BUEN DIAS SALUDOS A TODOS
ESPECIALMENTE A MI ESTIMADO M&M,
QUE GUSTO VER QUE ESCRIBE DE NUEVO MAESTRO
Username: Canada_havana
Post Number: 1655
BUENOS DIAS Y BENDICIONES AL FORUM,,,
Username: Rexio_mty
Post Number: 810
Buen dia y saludos a la raza.....ya listos para las fiestas decembrinas.....
yo aqui batallando supongo que es el cable que ya chafeo...por que no carga el bin...como ultimo voy a intentar en otra compu para saber si es el puerto...aunque cargue el bin a un clon
y funciono perfectamente, alguien ha experimentado problemas en los 2700?? para cargarle el nuevo bin??
saludos
Username: Rexio_mty
Post Number: 811
Creo que DN, estara tan mal como sus antecesores de MASTV, he, he, he, pocos canales que ver y si quieres mas pue$$$$ pagar ma$$$, a ver como se pone con dish mexico, lo que si es seguro es que a toda la raza FTA nos dan trabajo SEGURO, minimo como instaladores, he, he,he, ya me veo instalando antenas dich y bebiendo mi coronita........he,he,he...salud, salud
Username: Juancho
CANADA
Xx
Post Number: 369
regio, estos nuevo bines son bien raros, trata esto, no esperes por las luces , primero click en wirte XX y enciende el reciver, no esperes por luces o letras, trata eso, es el timing que es diferente, poco a poco dale mas tiempo, pero no esperes por luces o letras.
Username: Juancho
CANADA
Xx
Post Number: 370
o si no treabaja asi, enciende el reciver e inmediatamente click en download, he load de este modo a unos amigos que tenian ese problema, ahorita le puso el bin a uno que trabajo de este modo. encciendelo y click download, espera , alos pocos segundos veran la barrita verde
Username: Juancho
CANADA
Xx
Post Number: 371
a uno hasta le puso la lista de canales que tengo para los convertidos con el BL loader 27.01. trabaja bien.
Username: Rexio_mty
Post Number: 812
Gracias compadrito Juan ramirezone, de hecho ayer en un intento mas se empezo a "cargar" por que se vieron las luces señal que estaba entrando el BIN, pero niguas no avanzo ni 1% asi lo deje por mas de 1/2 hora y nanais....pero tratare lo que comentas...
saludos compadrito
Username: Rexio_mty
Post Number: 813
Username: Ravim
Post Number: 53
Gracias a ERNESTO M.M. por contestar a mi pregunta, la verdad conozco poco acerca del fta, ya que a mi me vendieron el equipo con todo y motor y la persona que lo instalo no me explico nada y despues desaparacio, aunque he leido un poco, desconozco como programar un equipo y posteriormente instalarle una antena, he leido acerca de unos localizadores de sats con los cuales supiestamente ya no hay la necesidad de estar en el techo cazando los pajaros, pero no conozco el procedimiento para hacerlos funcionar, actualmente no cuento con equipo y tengo dudas sobre en cual equipo invertir, agradeceria si me contestaran algunas dudas que tanta diferencia existe entre el cw600 y cw700?, que tanto tiene que ver la entrada usb en el cw700?, saben los costos? ojala me recomendaran alguno.
GRACIAS por tomarse el tiempo para contestar.
Username: Neox
Tijuana, Baja California
Mexico
Post Number: 300
le se deseo feliz navidad a los gue hacen los bins y gue dios los benediga
Username: Regio65
Monterrey, Nuevo León
Mexico
Post Number: 382
FELIZ NAVIDAD A TODOS LOS MIEMBROS DE ESTE FORO QUE SUS DESEEOS SE CUMPLAN Y QUE DIOS LOS LLENE DE BENDICIONES EN COMPAÑIA DE SUS SERES QUERIDOS.
Username: Carbajal
Post Number: 50
Hola buenas noches.
Kiero a ver si alguin me puede ayudar tengo un pansat 2500 a 2700 le puse el bins nuevo y todo se ve oscuro ya no se ke haser por favor si me dicen ke tengo ke hser se los agradecere mucho.
Username: Albertome2
Post Number: 98
un sitieo nuevo para tus necesidades
http://gothicfta.sigs-n-more.com/forum/index.php
Username: Juancho
CANADA
Xx
Post Number: 372
carbajal buscate el bin fwanky 203 V2
Username: Pmorenoc
San luis potosi, San luis potosi
Mexico
Post Number: 20
Amigos Donde encuentro para descarga el bin 203 puff???
Username: Jmendozab
Post Number: 270
Señores,
¿Por que el afan de desprestigiar al nFusion?,
Será que tienen envidia de que no se ha caido en ningun momento?
Recuerden que la legislación mexicana no prohibe bajar la señal que se encuentra en el espacio aereo, por lo que no estamos infringiendo ninguna ley.
Username: Rober2154
Miami, Fl
Usa
Post Number: 541
SE CAYO DISHnET !!!!}
Username: Evilfred
Mexico, Distrito fedral
Mexico d.f
Post Number: 42
NO SE A CAIDO PERO SIGUE CONGELANDOSE DE VEZ EN CUANDO,,,
Username: Burrundun
Post Number: 59
Hola a todos
Nfusion down
Username: Burrundun
Post Number: 60
Nfusion UP!!!!!!!
:D
Username: Neox
Mexico
Post Number: 301
sonicview premier 360 up
Username: Carbajal
Post Number: 51
Ya le puse el bin fwanky 203 V2 y sigue vindose oscuro.
Username: Cherrysalas
Tampa, Fl
Pinellas
Post Number: 291
saludos a todos...por favor hace dias estoy sin luz. HAY ALGUN BIN NUEVO POR FAVOR ENVIARMELO A chrrysalas@yahoo.com O DARME UN VINCULO.
el mio es un convertido 2500-2700 PUFF
GRACIAS
Username: Carbajal
Post Number: 52
yo tambien tengo dias sin ver la luz y no se ke hser yo tambien tengo un pansat 2500 convertido a 2700 puff.
ayuda por}fa.
Username: Carbajal
Post Number: 53
Por favor si tiene algo ke me pueda ayudar se los agradeceria mucho mi correo es serma38@hotmail.com
de antemano muchas gracias.
Username: Mcd500
Post Number: 105
senores maestro tengo un pansat 2500 2700
comvertido b75 y ahora si puedo conbertirlo puff como puedo conbertirlo
por fabor ayudenme cual es primer paso y
el ultimo paso para conbertirlo
grasias
Username: 3dd13
HOLA ERNESTO M. M. ASE DIAS ME DIGISTE QUE ME PODIAS AYUDAR A ECHAR A ANDAR UNA NFUSION HD YA TENGO TODO LA QUE SE NESESITA SOLO DIME CUANDO BAS A ESTAR EN LINEA PARA QUE ME PUEDAS ESPLICAR PASO A PASO O PUEDES MANDARME UN CORREO
ruedaseddie@yahoo.com.mx
BUENO GRASIAS Y ES PERO QUE ME AYUDES
Post Number: 1656
BUENOS DIAS Y BENDICIONES AL FORUM,,,,, FELIZ NAVIDAD...
Username: Mabe
Post Number: 71
\NUEVO BIN CW600S, 211. CARGENLA YA!}
Mario, busca los pasos para convertir tu caja en foros anteriores
FELIZ NAVID!
Mexico City, D.F.
Mexico
Post Number: 1064
Hola a todos
Alguien sabe si hay algún movimiento del 119?
Resulta que a partir de hoy en la mañana bajó la calidad en todos los canales, incluso en el HBO2 West no tengo nada de calidad. Antes lo máximo de calidad que tenía era 64%, ahora solo llega a 50%. La antena no se ha movido porque no hace nada de viento por aquí.
Saludos
Username: Arrollador_de_perras
Post Number: 83
hay programacion para los puff??
Username: Vianche
Montreal, Quebec
Post Number: 1006
buenos dias a todos y que tengan una feliz navidad con mucho amor y salud
les cuento que hasta ahora mi cajita puff trabajndo de lo mas bien aunque se congela algunas veces espero que no se caiga
Username: Jorge_luis
Post Number: 2647
AMIGOS DE SOLO HISPANOS LES DEJO ESTA
LISTA DE PELICULAS PARA QUE SE PREPAREN
PARA CUANDO NAGRA 3 ESTE IMPLEMENTADO Y
TENGAN LAS MOVIES PARA ESE TIEMPO DE OSCURIDAD
Lista de peliculas en www.ftaup.com/vb
ultima actualizacion 21 Diciembre 2008
link directo para las descargas.- http://ftaup.com/vb/movies-y-series/7872-peliculas-ordenadas-por-abecedario-list a.html
registro gratuito, checan su email para confirmar registro y oueden poner a su servidor y amigo como referencia ERROR
007 - Quantum Of Solace
2012 Doomsday (2008)
24: Redemption
27 Dresses (2008) Online
30 Dias de Oscuridad [DVDScreener]
A
Abducidos/taken (serie)
AmarTe duele
Alien vs Predator 2
B
Bolt (COMO UN RAYO)
Barbie en un cuento de Navidad
Ben 10:La carrera contra el tiempo
C
CrepÚsculo
Campanilla, Tinker Bell (Infantil)
Cumbia Callera - 2008- Una Pelicula Diferente
Cj7
City Of Ember
D
Doctor Dolittle 4
Dragon Ball: The Magic Begins
Dr. House Md serie
Disaster Movie
E
El niÑo con el pijama de rayas
el silencio de los inocentes
el dia que la tierra se detuvo (Ultimátum a la Tierra)
El fin de los tiempos
Escuela de Rock
F
Fool's Gold (2008) Online
G
H
High school musical 3: Fin de curso
Heroes
Harry Potter and the Order of the Phoenix
Historia del manga (documental)
I
Indiana Jones y el reino de la calavera de cristal
J
K
Knight Rider (El auto fantástico)
L
Los extraÑos
La misma luna
la muerte de superman
La Momia: La Tumba Del Emperador Dragón
La Leyenda de Santa Claus
M
Madagascar 2
Meet Market (2008) Online
Max Payne
Mongol
Meet Dave (Atrapado en un pirado)
N
Navidad S.A
naruto
O
Over.Her.Dead.Body.2008.CAM.XVID-Stuffies
P
Pingüinos De Madagascar: Mision Navideña
Prison Break 3ra Temporada
PuccaSerie Animada
Pérez, el ratoncito de tus sueños 2
Punisher War Zone
Q
R
RocknRolla
Red De Mentiras
Rambo (2008) Online
Rec
S
SMALLVILLE - Octava Temporada
Smallville Season 7 Capitulo 16 actualizado
Saw 5
Star Wars: La Guerra de los clons
Space Chimps
Superbad
Snow Buddies
Shrek especial Navidad
T
Tenacious D
Trailer Dragon Ball Movie2009
The Dark Kight (BATMAN)
The Unknown Trilogy (2008) Online
The Eye (2008) Online
Talento De Barrio
U
Unholy
V
Volver Al futuro (trilogia)
W
Welcome Home Roscoe Jenkins (2008) Online
Winx club: El secreto del reino perdido
X
Y
Z
Mexico City, D.F.
Mexico
Post Number: 1065
Hola:
Alguien me pudiera decir qué lnb se necesita para el Galaxy 3C Ku?
Saludos
Post Number: 1657
BUENOS DIAS Y BENDICIONES AL FORUM,,,,,,
Mexico City, D.F.
Mexico
Post Number: 1066
Hola:
Ya encontré el listado de lnbs.
Saludos
Username: Elmoxp
Ottawa, Ontario
Post Number: 250
Si yo quiero aputar mi Dish 36" a el Sat 40.5 W, o a el 95W, necesito algun Bin?
son FTA pero no se qeu configuracion o que Bin Necesito
gracias
Username: Oijaz
Post Number: 162
Un saludo al forum
Tengo dos preguntas. Espero que alguien me ayude, please.
Tengo una sonicview 8000HD y le instale una antena dish 1000 con la que agarro el 110, 119, 129; pero ninguno de los canales en alta definicion que agarro con el 129 me da lenguaje en espanol.
1. Hay alguna manera de setear el recibidor o cualquier otra cosa para escucharlos en espanol?
2. Es cierto que si en vez del 129, agarro el 61.5 (echoStar 3)puedo agarrar los mismos canales que el 129 pero tambien en espanol?
Muchas Gracias
Username: Javy_gza
MONTERREY , NUEVO LEON
MEXICO
Post Number: 2044
SALUDOS A LA RAZA
WENO RAZA IA METI SOLICITUD COMO
INSTALADOR EN DIS MEX JEJEJE
NOMAS DE HOBBY JAJAJA TMBN PA TESTEAR UN RATO JEJEJE . SALUDOS
Username: Javy_gza
MEXICO
Post Number: 2045
TMBN ESTOI ESTUDIANDO COMO PROGRAMAR
LAS ATMEGAS AUNQE ES UN POCO TARDE X LO
DE NAGR 3 PERO SI LA ATMEGA TRABAJO CON
EL NAG 1 Y NAG 2 PROBABLE MENTE TMBN CON
NAG 3 TRABAJE JEJEJE SALUDOS.
NOTA
SI ALGUIEN TIENEN ISO PROG Y ATMEGS BARAS
P TESTEAR SE LOS AGRADECERIA SI ME LOS
VENDIERAN O ME LOS PASARAN .SALUDOS RAZA
Username: Carbajal
Post Number: 54
Hola buenas tardes.
Tengo un pansat 2500 convertido a 2700 puff y le puse el bins nuevo y sigue sin funcinar se ve todo oscuro y si ahi señal,no se sinto ke me hase falta de istalar algo otro bins pero no se cual si me pudiera ayudar se los agradeceria mucho.mi correo es serma38@hotmail.com
Username: Kadanny
Post Number: 104
A todos mis amigos y amigas de este foro les quiero desear una Feliz Navidad y un Prospero año nuevo 2009. "Que Dios los bendiga hoy y siempre".
Username: Neox
Mexico
Post Number: 302
que dios bendiga a los que hacen los bins y les deseo una feliz navidad a ellos y a toda su familia y un prospero año nuevo 2009
Mexico City, D.F.
Mexico
Post Number: 1067
Elmo:
Para el 40.5º West, necesitas un plato para banda C, ya que hay muchos canales para esa banda, pero para Ku solamente hay un canal.
En cuanto al 95º West, en banda Ku lo único que verías son como 4 o 5 canales de la CCTV (China) en varios idiomas, ya que los canales de cadenas como Univisión, Fox y NBC también están en banda C libres. Para este sat. en Ku necesitas un LNB lineal.
Saludos.
Username: Carbajal
Post Number: 55
Hola,buenas tardes.
Sigo si ver la luz ya puse todos los bins ke me han mandado y no se ve nada se ve oscuro y si ahi señal por favor ayudenme mi pansat es 2500 a 2700 puff.Grcias
Username: Carbajal
Post Number: 56
Si me ayudan desde el principio se los agradeceria mucho.
Cual es el primer paso a seguir y hasta el ultimo.
Muchas gracias.
Username: Carbajal
Post Number: 57
Ahorita estoy conectado en el massenger.
mi correo es serma38@hotmail.com por si alguin me kiere ayudar.
Post Number: 100
tu FTA se esta congelando el fix esta listo
http://rabbitslair.sigs-n-more.com/index.php
Username: Hardcorecowboy
Post Number: 19
Carbajal:
Que bin tienes ahorita?
Post Number: 102
Viewsat file listos lost captiveworks estan casi listos
Username: Carburante
Post Number: 155
alberrrrto si tu quieres trafico para tu web dilo y aqui la raza es solidaria pero no cojas a la gente para el relajo diciendo cosas que no son. vengo de visitar el link que dejas y es una pagina acabadita de salir con 4 gatos como miembros, mira los post de error y veras como el pide que la gente visiten los links e incluso que lo den a el como referencia. asi se procede , de la manera que lo haces tu huele a SPAM nd FISHING.
Username: Rrios01
Monterrey, N.L.
Mexico
Post Number: 768
Saludos a toda la raza, no estaba
muerto andaba de parranda, jajaja
compadritos del alma ernesto, rexio
, juan carlos, fernando de venezuela
, carlos avelar, chepe pe y a todos
los amigos y no tan amigos como
juan ramirez un saludo de buena fe
y aqui seguiremos
saludos.
Username: Rrios01
Monterrey, N.L.
Mexico
Post Number: 769
cw trabajando sin freeze con el bin
215A.
y llegaron la legiones, jajaja
saludos compadrito ernesto espero que
este muy bien en compañia de sus seres
queridos y como usted lo dijo
estamos en diciembre y vienso tv gratis
compadre rexio con este frio tambien
se antojan las coronelas
Username: Elmoxp
Ottawa, Ontario
Post Number: 251
Juan CArlos Fuentes
Gracias por tu valiosa Informacion,
ahora me pregunto que plato tengo qeu comprar y que LNB para tomar los canales en Banda C ya que me gustaria tener un Adaptador de LNbs para tomar los dos pajaros el 40.5W y el 95W con el mismo plato si se puede, ya que no me gusta el motor por cuestiones de frio y tener en los canales colombianos y Univision recuerda que estoy en canada y un poco lejos pienso yo de esos pajaros
Gracias
Post Number: 1658
Username: Chicagokid
Antigua
Post Number: 554
FELIZ NAVIDAD!!! Y FELIZ AÑO NUEVO!!!!
DpansatUpload
Username: Tetuscosmicus
Post Number: 337
PARA TODOS MIS AMIGOS DEL FORO,,
FELIZ NAVIDAD Y PROSPERO
AñO NUEVO 2009...FELICIDADES A TODOS..
TETUSCOSMICUS...
Post Number: 338
SI TOMA NO MANEJE POR
FAVOR...RESPETE A SU FAMILIA...
QUIEN LES APRECIA TETUS..
Mexico City, D.F.
Mexico
Post Number: 1068
Elmo:
No puedes tener los dos satélites con un solo plato, ya que recuerda que para banda C necesitas una antena parabólica, y no una Offset. Necesitas una por satélite para el caso de los que mencionas. Por lo que te recomiendo mucho un motor, son muy útiles para el caso de este tipo de antenas. En cuanto al tamaño... en lo personal te recomendaría una de 3 metros. La huella para estos sats es muy buena en tu zona.
Saludos.
Mexico City, D.F.
Mexico
Post Number: 1069
Elmo:
Si puedes chécate los mapas con las huella de esos satélites en lyng sat, porque parece que con una antena de 2 metros la haces. Perno necesitarías el polarotor para esa frecuencia y debe ser lnbf, cuestan como 40 dólares.
Saludos
Saludos
Username: Nadadesat
Post Number: 6335
COMPADRE DEL ALMA, ¿DONDE ANDABA? MI CHINO DE ORO, TANTA FALTA QUE LE HACE FALTA USTED A ESTE FORO.
ME DA MUCHO GUSTO SABER QUE ESTA BIEN.
HAY QUE MATAR AL BECERRO MAS GORDO Y DESTAPAR BOTELLAS DE VINO PORQUE MI COMPADRE HA VUELTO.
SALUDOS COMPADRE.
Username: Nadadesat
Post Number: 6336
HAY NOMAS PARA COMPLETAR LA INFORMACION DE
MI OTRO COMPADRE JUAN CARLOS FUENTES.
LOS CANALES UNIVISION Y TELEFUTURA QUE ESTAN EN EL SATELITE GALAXY 3C Y QUE ESTAN EN BANDA C, TAMBIEN ELMO LOS PUEDES ENCONTRAR EN EL SATELITE GALAXY 18, ESTO EN BANDA KU, CON UNA ANTENA DE 80 CENTIMETROS Y UN LNB LINEAL LO CAPTAS.
SALUDOS.
Username: Elparrandero
Los angeles, Ca
Los angeles
Post Number: 174
hola saludos foro ,,,se que estoy muy atrasado con todo esto del fta ..pero tengo un par de dudas ,,como siempre ,,he leido un poco y escuchado otro poco ,,sobre que en unos meses nocquedaremos sin senal ,,solo quisiera saver si tardara mucho esto de estar a oscuras ,,espero que elguien me lea ,,,gracias de antemano ,,
Mexico City, D.F.
Mexico
Post Number: 1070
solo uno:
Nadie sabe exactamente si los coders lograrán abrir Nagra 3 o cuánto tiempo les lleve. Mientras tanto, como dice mi compadre Ernesto M.M. a disfrutar lo que ahorita tenemos. No tiene caso preocuparse por lo que vendrá mañana. Vivamos el presente.
Saludos
Username: Nadadesat
Post Number: 6337
COMO SABER CUANDO SE USA UN LNB LINEAL Y CUANDO SE USA UNO CIRCULAR?
ESTO ES FACIL, EN LA PAGINA DE LINGSA*T
FIJEMONOS EN LAS LETRAS QUE ESTAN ENFRENTE DE LAS FRECUENCIAS DE LOS TRANSPONDERS.
SI LAS LETRAS SON "V" O "H",EL LNB ES LINEAL, PUES LA POLARIDAD ES VERTICAL U HORIZONTAL.
EJEMPLO:
SATELITE GALAXY 18.
11720 V.
TP. 1.
O
11860 H.
TP. 8.
POR OTRA PARTE SI LAS LETRAS SON: "R" O "L", EL LNB ES CIRCULAR, PUES LA POLARIDAD ES CIRCULAR DERECHA O IZQUIERDA.
LAS INICIALES CORRESPONDEN A LAS PALABRAS DERECHA O IZQUIERDA EN INGLES.
EJEMPLO, EL EHOSTAR 10:
12268 L
TP 4.
O
12545 R
TP. 23.
ESTO APLICA TANTO PARA LA BANDA C, COMO PARA LA KU.
SALUDOS.
Username: Regio65
Mexico
Post Number: 383
A LOS MASTERS QUE VIVEN EN MONTERREY
QUE OTRO PAJARO APARTE DEL 119 Y 110 PUEDO AGARRAR PARA UTILIZAR LA ANTENA QUE TENIA CON EL 91
GRACIAS
Username: Oijaz
Post Number: 163
Un saludo al forum
Muchas Gracias
Username: Carbajal
Post Number: 58
Tengo cargado este bin Fwank7_Jvvh-Team-PUFF_V203_f_emu_.bin juan camaney
Username: Elmoxp
Ottawa, Ontario
Post Number: 252
cuando Juan Carlos Fuestes dice una antena de 2 metro o de 3 habla del tamano de la antena? es que aca venden por ejemplo 33" y 36" con LNB linear y venden las de 18" 24" para Bev y Charlie
me gustaria saber para ir a el negocio y comprar lo que necesito para eso dos PAjaros el 95w or el 123W y el 40.5
Gracias
Username: Dilan
GUADALAJARA, JALISCO
MEXICO
Post Number: 99
hola a todos sigo sin ver el echo 7
ya le puse varios bines
el 203 para pansat 2700a original y
nada solo veo el echo 8.1 alguien sabe como acer para que se vea el echo 7
tengo 65 de calidad pero esta en scramble channel
felices fiestas
Username: Carbajal
Post Number: 59
SOLO UNA PREGUNTA,NECESITO OTRO CABLE DE DB9 HEMBRA PARA PODER PONERLE ESTE BIN Fwank7_Jvvh-Team-PUFF_V203_f_emu_.bin O CON EL MISMO KE TENGO FUNCINA BIEN.
Username: Nadadesat
Post Number: 6339
DAVID YO QUE VIVO EN MONTERREY TE SUGIERO
QUE CON UNA DE SKY Y UN LNB LINEAL, TAMBIEN DE CIELO.
LE APUNTES AL SAT. GALAXY 18, ESTE ESTA A 123 GRADOS WEST A UN LADITO DEL EHOSTAR 7.
ESE PAJARO ABAJA COMO 45 CANALES, ENTRE ELLOS DOS DE TELEFUTURA Y 5 UNIVISION Y LOS DEMAS SON DE FOX, CBS Y OTROS EN INGLES.
EL LNB QUE USABAS PARA BEV NO TE SIRVE PARA ESE PAJAR, PORKE EL GALAXY ES DE POLARIDAD LINEAL Y EL BEV ERA CIRCULAR.
Username: Fghio
Monterrey
Post Number: 23
que tal a todos
alguien que viva en mty, la calidad de la señal esta muy baja, alguien sabe porque o soy al unico que le pasa esto
Username: Nadadesat
Post Number: 6340
ELMO, JUAN CARLOS, EACTAMENTE SE REFIERE AL TAMAÑO DE LA ANTENA, PORKE AQUI EN MEXICO SE USA EL SISTEMA METRICO DECIMAL: CENTIMETROS, METROS ETC.
EN CAMNBIO EN USA SE USA EL SISTEMA INGLES:
O SEA, ENTRE OTROS PIES Y PULGADAS, TU TE REFIERES A PULGADAS EN CUANTO A LA MEDIDAS QUE MENCIONAS.
SALUDOS.
Username: Nadadesat
Post Number: 6341
JASIEL MUNOZ.
LA OPCIION DE ESPAÑOL E INGLES EN LA SEÑAL QUE RECIBES DEL SATELITE, SOLO ESTE LA DETERMINA.
SALUDOS.
Username: Nadadesat
Post Number: 6342
CARBAJAL PARA PONERLE EL BIN QUE REFIERES AL APARATO MENCIONADO SE USA UN CABLE STRAIGHT NO EL NULL.
SALUDOS.
Username: Nadadesat
Post Number: 6343
PELON EN EL SAT 11O YO QUE VIVO EN MONTERREY ME MARCA 90 POR CIENTO.
Y EN EL 119 ME MARCA CERO ,O SEA , NADA
PERO AUN ASI ME BAJA MAS DE 300 CANALES.
SALUDOS.
Username: Carbajal
Post Number: 60
ENTONCES POR ESO SE VE LA PANTALLA OSCURO PQ ESTOY USANDO EL CABLE NULL.
UN SALUDO ERNESTO
Username: Nadadesat
Post Number: 6344
NO CARBAJAL SI USAS EL CABLE INCORRECTO NO PUEDES METERLE EL BIN A TU RECEPTOR.
NO SE TU PROBLEMA EN CONCRETO, PERO LO TUYO ES OTRA COSA.
SALUDOS.
Username: Fghio
Monterrey
Post Number: 24
gracias maestro Ernesto.
no a echo viento para que se hayan movido las antenas, en el 119 de plano no baja ningun canal y el 110 todos pero con muy mala calidad de echo no se pueden ni ver, que cres que sea, o cambio la huella de los sats
gracias
Username: Nadadesat
Post Number: 6345
FELIZ NAVIDAD A TODOS.Upload
Username: Fghio
Monterrey
Post Number: 25
gracias
Username: Nadadesat
Post Number: 6346
PELON USAS DISEQ ?
LOS SATS ESTAN BIEN NO HA CAMBIADO LA PISADA DE LOS SATELITES.
QUE TIPO DE ANTENA USAS?
SALUDOS
Post Number: 104
una vez mas los fta se congelan lean porque
Username: Carbajal
Post Number: 61
}A VER SI ME EXPLIQUE BIEN.
gRACIAS
Username: Carbajal
Post Number: 62
bUENO ERNESTO TE EXPLICO MI PROBLEMA YO TENGO UN PANSAT 2500 CONVERTIDO A 2700 PUFF DESDE SALIERO LOS NUEVOS BIN NO PUEDO HSER KE FUNCIONE MI PANSAT, LE PONGO LOS KE ME HAN MANDADO Y SIGUE TODO IGUAL LA SE VE OSCURO NOMAS LOA CANALES DE PROMOCIO SE VEN.
GRACIA.
Username: Fghio
Monterrey
Post Number: 26
Ernesto si uso diseqc, la verdad no estoy muy familiarizado con el tipo de antenas pero las dos eran de un directv, algunos amigos tuvieron que bajar las antenas de el techo al patio por algun por algun problema con unas repetidoras de Nextel.
sera lo mismo?
Home > Message Board > Home Video > Satellite TV > SOLO HISPANOS--2 > Archive through December 23, 2008 [ « Previous ] [ Next » ]
