Home > Message Board > Home Video > DVD Recorders > Can i record from tv using hdmi cable...
Author Thread: Can i record from tv using hdmi cable only?
Username: Mikej640
What im trying to do is use my toshiba dvd recorder to record directv from my samsung tv using only a hdmi cable. The guy at the store says i can and the manual that came with the recorder says i can but i can't seem to get it to work because the source select gives me a blue screen. 1. sat box is connected to hdmi2 and dvd recorder is on hdmi1 on the tv. Two diff sources!! plz help, is it possible?
Username: Samijubal
Post Number: 3982
HDMI on DVD recorders is an output, not an input. There is no DVD recorder made that will record from HDMI. One of the main reasons for using HDMI on electronics is the copy protection which can't be defeated.
Username: Mikej640
Ok thanks, I think the manual that came with dvd recorder is mistaken or misleading. Thanks...mike
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > DVD Recorders > Can i record from tv using hdmi cable... [ « Previous ] [ Next » ]
