Thread: Captive Works? |
Bronze Member Username: Post_man
Post Number: 65 Registered: Nov-07
| Posted on Wednesday, December 24, 2008 - 01:21 pm: |
Does anyone know why when I try to add a new satellite to CW-600S Premium. Satellite Direction (West)and the SB keeps coming up O*"E" ????? |
Post Number: 66 Registered: Nov-07
| Posted on Wednesday, December 24, 2008 - 04:28 pm: |
Guys thank you. I guess I came to the wrong place with my question. could anyone here give me a link to find the answer to my question? |
Gold Member Username: Plymouth
Post Number: 6616 Registered: Jan-08
| Posted on Wednesday, December 24, 2008 - 04:35 pm: |
Omar Sharif I don,t really understand your question. But i think that is the motor settings. Use this for give your position: http://satcalculator.freehostia.com/
New member Username: Tech2k
Post Number: 6 Registered: Aug-07
| Posted on Wednesday, December 24, 2008 - 11:12 pm: |
From what I remember, you must re-calculate for East position. It's been a couple of years but I did run into the same problem and that is what I did. |
Post Number: 67 Registered: Nov-07
| Posted on Thursday, December 25, 2008 - 07:02 am: |
Bart Black what do you mean you must re-calculate for East position? Iam trying to Scan in this Bird which is not listed in this receiver. Intelsat 3R @ 43.oW. but it keeps coming up as Intelsat 3R @ 43.oE Could it be in the sofeware? I enter West and it keep showing up as East Thanks and Merry Xmas |
Post Number: 6619 Registered: Jan-08
| Posted on Thursday, December 25, 2008 - 10:00 am: |
OMAR Go in Motor menu then with the satcalculator enter your position and you will have West option on new satellite.
Post Number: 68 Registered: Nov-07
| Posted on Thursday, December 25, 2008 - 12:00 pm: |
plymouth what are you saying? All my position settings are correct. I have no problem with the existing satellites only now with this new one. Do you own a Captive Works receiver? Edit Satellite Satellite Direction you have a choice one of the two......... EAST or WEST When I chose West, East pops up pick East, East pops up What ever happen to RTAP & bruce l those guys were good with CW? |
Post Number: 6623 Registered: Jan-08
| Posted on Thursday, December 25, 2008 - 12:10 pm: |
Omar i have CW600 Premium with motorized dish. When you add a new satellite you must set your position in motor menu because your receiver think that you are in europe by default.
Post Number: 6624 Registered: Jan-08
| Posted on Thursday, December 25, 2008 - 12:16 pm: |
Go in menu , System Setting then Usals Setup and enter your position in regard with Satcalculator. Now you will be able to set West in Add satellite menu.
Post Number: 69 Registered: Nov-07
| Posted on Thursday, December 25, 2008 - 12:56 pm: |
Look plymouth in the System Settings then in Usals Setup is like I have already said, it is set on WEST. Thanks for your time. btw do you know how to Restore a deleted Satellite on the CW-600S Premium Receiver ? my problem may be here. |
Post Number: 6625 Registered: Jan-08
| Posted on Thursday, December 25, 2008 - 01:09 pm: |
Cw does not have Satellite info file as for Viewsat but you can load the factory bin then the latest bin file. Here is the factory bin: http://www.captiveworks.com/software/CW600PV1.09_Reocrder_2_20_07.bin
Post Number: 70 Registered: Nov-07
| Posted on Thursday, December 25, 2008 - 01:54 pm: |
Would a factory Default Restore all the factory set files? |
Post Number: 6626 Registered: Jan-08
| Posted on Thursday, December 25, 2008 - 04:25 pm: |
Omar If you do that you will lost all your setting.
Silver Member Username: Fakeman1
Germantown,
Maryland
Post Number: 199 Registered: Jul-08
| Posted on Friday, December 26, 2008 - 11:49 am: |
Omar Sharif Would a factory Default Restore all the factory set files? YES best way loading the factory bin and then the latest bin file will also lose all your setting. |
