Thread: TP help on B-four_U, S-E-T |
Bronze Member Username: Gonxggo
Post Number: 68 Registered: Mar-07
| Posted on Tuesday, December 23, 2008 - 08:49 pm: |
no signl on 12033 L, t-p 22 Can someone please help? Is there any other sat/tp that can get same chhannels? |
Silver Member Username: Albino_midget
Post Number: 753 Registered: Jul-06
| Posted on Wednesday, December 24, 2008 - 06:25 am: |
61.5W - B4U -TP - 12384 SET - TP - 12472 |
Platinum Member Username: Nydas
Post Number: 13632 Registered: Jun-06
| Posted on Wednesday, December 24, 2008 - 10:47 am: |
If you have the correct Dish (>30") and a proper LNB for 118, then you should get on TP 22 - 12033 (H) those two channels. Which receiver are you using? Are you getting other 118W channels? |
Post Number: 69 Registered: Mar-07
| Posted on Thursday, December 25, 2008 - 02:24 pm: |
Yes Nalin. I am getting all the TPs and chanels except all the channls on TP 2-2. I don't see signal on T P 22. These last two pu-ff screwed everything. I didn't have any prob with previous bi-ns. |
Post Number: 13638 Registered: Jun-06
| Posted on Thursday, December 25, 2008 - 02:29 pm: |
You are luckier than many who are having 2-3 TPs screwed up. |
