Thread: NO TV ON 61.5 after loading the current variety of PUFF bins.... Help |
Bronze Member Username: Sher
St anne de bellevue,
Quebec
Post Number: 19 Registered: Apr-07
| Posted on Monday, December 22, 2008 - 10:32 pm: |
After loading the currently in type of bins the 200sss V versions I have not been able to get any picture on 61.5 channels, the signal is fine but all I get is scrambled channel sign, tried turning it off and on, tried reloading the channels both with blind scanning and without it ..... no result. Even changed the satellite from echo 3 to echo 7. I can see all the channel list but...... \please help |
Platinum Member Username: Nydas
Post Number: 13629 Registered: Jun-06
| Posted on Tuesday, December 23, 2008 - 08:55 am: |
The Fwank7 PUFF_203V2 works. After installing the BIN: 1. Note down your user and antenna settings. 2. Delete all chanels and doa system reset. 3. Power down. 4. Power up and do user settings. 5. Do Antenna setup for one Sat, and do a Blind scan. 6. At the end of scan you should see the picture. 7. Do other antenna set ups and scan. 8. Do your channel editing and parental controls and favourites. 9. Save this under channel master. 10. Watch TV. |
Bronze Member Username: Hockeycraze12000
Post Number: 26 Registered: Nov-08
| Posted on Tuesday, December 23, 2008 - 03:37 pm: |
This happened to me to when i was putting in 202. Just correct the signal settings and blind scan, even if theres no quality, when you do the scan you will get the channels working. ask somebody on the forum for the correct settings and make sure you tell them your lnb type. |
