Home > Message Board > Home Video > Satellite TV > Archive through December 26, 2008 > Fortec ultra?
Author Thread: Fortec ultra?
Username: Indopak
Post Number: 141
i tried to upload the new file to my fortec ultra which is a puff. that file is working on my clone receivers but not on my fortec one. what im i doing wrong? or am i not allowed to put that file into a fortec?
Username: Doreenakadj
Ontario
Post Number: 2319
i have a fortec ultre also and use PUFF files. have you converted it to 2700 or is it just still a fortec?
Username: Indopak
Post Number: 142
no its converted to PUFF, and i put Fwank7_Jvvh-Team-PUFF_V203(V-2).zip , it turns on and everything, but after i scan it there is no picture. why is that?
Username: Indopak
Post Number: 143
i have used the same file on a clone PUFF, and it works fine, but no picture in the converted fortec ultra receiver :S
Ontario
Post Number: 2322
are the component cards all in the right place?
Username: Nydas
Post Number: 13610
The Fwank7 PUFF_203V2 works.
After installing the BIN:
1. Note down your user and antenna settings.
2. Delete all chanels and doa system reset.
3. Power down.
4. Power up and do user settings.
5. Do Antenna setup for one Sat, and do a Blind scan.
6. At the end of scan you should see the picture.
7. Do other antenna set ups and scan.
8. Do your channel editing and parental controls and favourites.
9. Save this under channel master.
10. Watch TV.
Username: Jaye50
Post Number: 149
bin works fine on my converted ultra.....but some ppv channels are missing....and i'm having plenty of trouble with my remote.....it only recognizes it 10% of the tiime....
Username: Nydas
Post Number: 13614
UKR usually posts a "2700 remote" compatible BIN with his regular BIN.
He has not this time, but look for it at ftatalk.com in the files for Fortec Ultra and files for Pansat 2500
Home > Message Board > Home Video > Satellite TV > Archive through December 26, 2008 > Fortec ultra? [ « Previous ] [ Next » ]
