Home > Message Board > Home Video > Satellite TV > Archive through December 26, 2008 > Latest bin for Pansat2500-2700
Author Thread: Latest bin for Pansat2500-2700
Username: Bec03
Post Number: 11
People, Can somebody help me with my Pansat 2500-2700 what bin should I load,I have no idea what is going on last eight month, Thanks,thanks,thanks.
Username: Albino_midget
Post Number: 751
If you have 2500
Pansat 2500 PUFF Fwank7_Jvvh-Team-PUFF_V203(V-2).zip
www.keys-newbies.com/files.html#pansat
The receiver 2500 needs to be converted to puff - if not done already.
If you have 2700 use v203 for the pansat 2700
Username: Bec03
Post Number: 12
Albino Midget Thanks a lot. it was 2500 but later i converted it to 2700, so what do i have now?
Post Number: 752
You have a pansat 2500 that has been converted , so it can use modified pansat 2700 bins.
This is the latest bin
Pansat 2500 PUFF
You will need to have converted to PUFF boot , before using that file.
internet search - convert to puff - should give the directions if needed.
good luck
Username: Lubfr01
Post Number: 38
please list all the steps for applying this Fwank7_Jvvh-Team-PUFF_V203(V-2) to (FLU converted to) Pansat 2700 box...
Thanks.
Frank
Username: Nydas
Post Number: 13598
PUFF_203 full EMU for FLU/2500 Conversion to 2700
Full kits for Latest conversion BINs and other files - also for Revert to 2500
PUFF_203 full EMU version
PUFF link
Alternative PUFF link
Download and unzip into separate directory.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Please note, you may need to rescan
Username: Nyd_us
POST: 15666
All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released..
Many of these specialize in particular FTA receivers as noted next to their links..USE those for your particular receiver manufacturer..
If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community now...
Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information .
So again I highly recommend using ANY of these sites BELOW!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby!
FTA View
www.ftaview.com (all receivers)
Data Viewing Sequences
www.dvsfta.com ( Conaxsat and all receivers)
FTA Bins
www.ftabins.net (Vortex and All receivers)
MarketRealm (all receivers and plastic)
http://www.marketrealm.com/private/forums.php (all receivers)
Future FTA - Blacklist's Pansat Site:
http://www.future-fta.info/forum/index.php (Pansat)
Free To Air: Norw Group
http://www.f2atv.com/ (C00LSAT and All receivers)
FTA For All
www.ftaforall.net (Sonicview and Viewsat)
CompleteFTA (Captain and all)
www.completefta.com
Cut and Paste these into your browser:
REMOVE the * in links below: These are the larger sites,and therefore Ecoustics has blocked their names and active links..
http://forums.dsstester.c*om/ (All receivers)
http://www.dsscommunity.c*om/forums/ (All Receivers)
http://www.al7bar.t*k/ (All receivers)
http://www.dsscentral.n*et/ (All Receivers)
Satellite Finders (Look Angle Calculators)
http://www.arachnoid.com/satfinder (Dish 500 support)
http://satcalculator.freehostia.com/
http://www.hollsco.com/Products/SatCalc/
http://www3.telus.net/rampage/skew.htm (Dish 500 support)
http://www.remotesat.com/lookangle.htm
www.dishpointer.com
Satellite Charts
For information on all satellites and channels they offer
http://www.lyngsat.c*om/america.html
Best site for DISHNET info, channels, transponders and changes etc..
http://ekb.dbstalk.com/dishlist.htm
Direct links to current Dishnet and Bev keys:
www.tvkeyz.com/
www.dss-keys.com/
www.fta123.blogspot.com
or get Keymaster 4.0 here free and NO registration is required...
http://www.hostclip.com/dl/2ab89758e23ffdea64f64498c8dc926f
Best TV Guide site
www.titantv.com
Channel Master home site
www.sharpc.com
Relevant Product Infoo say.
Username: Plymouth
Post Number: 6555
False Nalin
Check post number
Username: Bec03
Post Number: 13
Thanks Albino Midget, thanks Nalin Nyda, thanks a lo-o-o-ot guys.
Username: Imnycusa
Post Number: 142
I installed the latest file Fwank7_Jvvh-Team-PUFF_V203(V-2). Howeve, I still dont dont see anything. What's the troubleshooting process? Thnaks in advance. welcome back Nalin. I hope you had nice vacation time.
Username: Imnycusa
Post Number: 143
It started working after I performed a system reset and blind scan.
Username: Nydas
Post Number: 13600
The Fwank7 PUFF_203V2 works.
After installing the BIN:
1. Note down your user and antenna settings.
2. Delete all chanels and doa system reset.
3. Power down.
4. Power up and do user settings.
5. Do Antenna setup for one Sat, and do a Blind scan.
6. At the end of scan you should see the picture.
7. Do other antenna set ups and scan.
8. Do your channel editing and parental controls and favourites.
9. Save this under channel master.
10. Watch TV.
Username: Kll
Post Number: 145
What is going on with F2ATV
Home > Message Board > Home Video > Satellite TV > Archive through December 26, 2008 > Latest bin for Pansat2500-2700 [ « Previous ] [ Next » ]
