Thread: Does This Work |
Bronze Member Username: Rockets08
Post Number: 28 Registered: Apr-08
| Posted on Thursday, December 18, 2008 - 04:16 am: |
If my laptop doesn't have a RS232 port, will a USB to RS232 adapter work on the laptop instead of updating with the desktop?
Bronze Member Username: Laxey34
Miami,
FL
United States
Post Number: 62 Registered: Oct-05
| Posted on Thursday, December 18, 2008 - 05:59 am: |
I doubt. The uploader may not recognise the USB |
Miami,
FL
United States
Post Number: 63 Registered: Oct-05
| Posted on Thursday, December 18, 2008 - 06:00 am: |
get a receiver with USB check www.caritech.netfirms. com |
Gold Member Username: Plymouth
Post Number: 6512 Registered: Jan-08
| Posted on Thursday, December 18, 2008 - 07:11 am: |
Yes if you have the software with it.
Silver Member Username: Bernardmi
Post Number: 301 Registered: Dec-07
| Posted on Thursday, December 18, 2008 - 12:16 pm: |
Get this one from a reputable US company. It works. On all PC's and on all OS (win 95/98/NT/2000/XP and Vista) http://www.iogear.com/product/GUC232A/ I recommend this to anyone. Guaranteed to work and be satisfying. |
Post Number: 29 Registered: Apr-08
| Posted on Friday, December 19, 2008 - 02:08 am: |
Greggor: Anyway to check if loader will work before buying? Plymouth: Would this be a better alternative since the other adapter came with no CD?
Post Number: 6525 Registered: Jan-08
| Posted on Friday, December 19, 2008 - 07:32 am: |
Ken Do you have link? You can buy The Outer Limits choice.
