Home > Message Board > Home Video > VCR > RECORDING FROM CABLE TV TO VCR
Author Thread: RECORDING FROM CABLE TV TO VCR
Username: Beargo
HELLO I WOULD LIKE TO KNOW IF I WANT TO RECORD A CERTAIN PROGRAM, I GUESS IT IS OBVIOUS THAT I SHOULD LEAVE MY TV ON THE CHANNEL THAT THE PROGRAM IS ON? I HAVE SET THE TIMER TO START AND STOP AT A CERTAIN TIME AND DAY. THANKS FOR ANY HELP...DAVE
Username: John_s
Columbus, Ohio
US
Post Number: 2365
DAVE, DO YOU HAVE A....er, sorry.
Dave, do you have a cable box, or are you using straight cable with no box?
Username: Beargo
I HAVE A CABLE BOX TO MY VCR AND WOULD LIKE TO RECORD,,...THANKS...DAVE
Username: Beargo
I HAVE A CABLE BOX TO MY VCR AND WOULD LIKE TO RECORD A PROGRAM
Username: John_s
Columbus, Ohio
US
Post Number: 2370
1) Leave your cable box powered up and showing the channel you want to record.
2) Set the VCR's timer to the appropriate day and start/stop times. Program the VCR to record either channel 3 or 4, depending on the normal playback channel you normally have the TV set to.
3) Don't turn off the cable box. You can turn off the TV.
Username: Beargo
I would like to thank John S for his help with my vcr recording problem. Everything worked out fine thanks to john's instructions....Dave
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > VCR > RECORDING FROM CABLE TV TO VCR [ « Previous ] [ Next » ]
