Home > Message Board > Home Video > DVD Recorders > Dish Network remote tv to DVD/DVR
Author Thread: Dish Network remote tv to DVD/DVR
Username: Cherimj
We just got Dish Network and have two TV's. The receiver is located with the HD TV which is on a rolling TV cart so we did not get the DVR receiver as to not damaged the hard drive in the DVR. Our sound system, etc is hooked up to the larger non-HD tv so it runs through the remote tv2 set-up. We own our own DVR which we basically use as a glorified VCR to record programming. We can not get the Dish programming to run through the DVR like our cable used to and therefore can't record. Dish instructions are to set DVR/VCR to channel 60 and output to 3 or 4 but the Dish programming shows up on 60 whether the cable from the wall is plugged into the DVR/VCR or the TV directly.
Any suggestions?
THANKS!
Username: Samijubal
Post Number: 3951
If you are trying to use a TiVo or similiar, they aren't compatible with satellites. HDDs aren't that fragile that they can't be moved around on a TV cart.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > DVD Recorders > Dish Network remote tv to DVD/DVR [ « Previous ] [ Next » ]
