Thread: Dvd recorder not recognising dvds |
Bronze Member Username: Hades305
Post Number: 34 Registered: Aug-07
| Posted on Monday, October 27, 2008 - 06:16 pm: |
hey there, I have a samsung R150. been using it for the past few months. worked great. recently it no longer recognises empty dvds that ive always used, even different kinds. I keep getting the same message " disc cannot be played". I have gotten a few to work, that's after inserting several. I cleaned the lens(dry) , but to no effect. thought of doing a firmware update, but the firmware on the recorder is more recent than the one availabe on Samsung's website. Any suggestions will be greatly appreciated. marc |
Gold Member Username: Samijubal
Post Number: 3949 Registered: Jul-04
| Posted on Tuesday, October 28, 2008 - 12:30 am: |
You could try opening and cleaning the lens with a q-tip wet with alcohol. Samsuck makes lousy recorders, if it doesn't work it's toast. |
Post Number: 35 Registered: Aug-07
| Posted on Saturday, November 01, 2008 - 10:43 pm: |
thanks David, sorry about the late reply. will try with the q-tip |
