Thread: RE BLACKBIRD RECEIVER |
New member Username: Andy99
Post Number: 1 Registered: Jun-04
| Posted on Thursday, June 10, 2004 - 12:17 am: |
has anyone puchased one of these is it true you need no card. any feedback woud be great |
| Posted on Wednesday, June 16, 2004 - 05:17 pm: |
ANDY THEY WORK BUT I RECOMEND THE PANSAT 2500 IT KICKS.......I HAVE A SYSTEM FOR SALE THE RECIEVER DISH AND LNB READY TO WATCH TV.....525 DELIVERED USA OR CANADA JMILL1948@AOL.COM |
| Posted on Wednesday, June 16, 2004 - 08:45 pm: |
I would like to know if anyone has had any knowledge about the Blackbird receiver. Does it work as advertized? Is it easy to set up? Any info would be appreciated. Thanks |
| Posted on Wednesday, June 16, 2004 - 09:52 pm: |
like i said the pansat is the one to get preprogramed with lots of support..... check out jmill . the blackbird on the other hand has gone up in price pansats are going up to since fta is about the only way left to easy test....gami32 |
New member Username: Jmatarazzo
Post Number: 8 Registered: May-04
| Posted on Friday, June 18, 2004 - 01:03 pm: |
hello i have the pansat 2500(off ebay for 230 delivered. not 525)what is the process of set up.their instructions blow.do you need to keep installing software,or updates?is there a website that has better help?also.what is a good type of dish to use(besides the t-55 superdish)i already have a dtv dish aimed already for dtv.(im in rhode island)any help would be great. thanks |
Unregistered guest |
| Posted on Tuesday, July 06, 2004 - 01:03 am: |
Blackbird works great I use it actually too k about two days to get eveything set the way I wanted I am recieving a little over 1000 channels now local for just about every city in the US The you know what selection... is outstanding. The only real pain in the !#!%# is the fact it does not name all the channeles correctly when doing Sat Scan. I use a Wineguard Dish w/DG-2100 H-H motor with my old direct TV LNB it can track 7 sat easily currently I have three proggrammed for 1000 channel more tv than I can watch |
| Posted on Sunday, July 11, 2004 - 11:01 pm: |
Check out http://forums.al7bar.tk they have lots of information on all the FTA, blackbird, pansat etc... receivers, get honest opinions from people actually using them! |
Bronze Member Username: Jmill1948
Chester,
Va
Usa
Post Number: 63 Registered: Apr-04
| Posted on Saturday, July 17, 2004 - 10:08 pm: |
YES FTA IS THE WAY TO GO IF YOU NEED HELP GIVE ME A SHOUT.BUMP........J JMILL1948@AOL.COM |
charles perlman Unregistered guest |
| Posted on Thursday, July 29, 2004 - 03:00 am: |
the forums over at dsshelper.com are replete with an enormous amount of info on FTA receivers they have foums dedicated to several didferent makes and models of FTA units im about to order my second receiver now that i learned how i can test two Pansats with one dish |
| Posted on Monday, August 09, 2004 - 12:21 pm: |
Does anyone have info on hooking up more than one tv to the receiver? I have been seeing "UHF Ready" and "IR Ready" in some of the ads. Can anyone expand on this? |
| Posted on Thursday, August 12, 2004 - 10:19 am: |
I need some help with my blackbird receiver. I just purchased a blackbird and the instruction I find about it on the net does not have match what is showing on my screen. For example it says to go to Installation then select Dish setup. My menu does not have dish setup but other options such as antenna. Can anyone help. I also need a site where I can find keys and software I guess but don't know what to do with it. Please help, thanks. |
| Posted on Friday, August 13, 2004 - 03:29 pm: |
Blackbird - I think I need to flash it. Can anyone help me with it. I need to know the name of the software to use and the name of the software to flash it with. You can email me at marc@lambton.on.ca Thanks |
| Posted on Friday, August 13, 2004 - 03:55 pm: |
my receiver went out and now i cant get nothing but the green light on front....it wont pick up connect to pc or anything any body know whats going on or how to fix it?
| Posted on Friday, August 13, 2004 - 09:29 pm: |
i am having the same problem as i was updating the power was diconnected .turned it back on the green lite was on but unresponsive. any suggestions Walt at Waltkboom@aol.com |
a friend Unregistered guest |
| Posted on Sunday, August 15, 2004 - 11:07 am: |
for anyone who has the blackbird you will need to wait for the site to upgrade software blackbird will tune some channels meanwhile but it takes long to tune in. |
| Posted on Monday, August 23, 2004 - 02:02 pm: |
Still need help. I am trying to flash my blackbird but keep getting "Connection Failed" when I try to connect to com port1 or 2. Can anyone help. Thanks marc@lambton.on.ca
arniesr Unregistered guest |
| Posted on Friday, September 10, 2004 - 01:22 am: |
After installing upgrade software to my enforcer it wont keep the keys I program into it when I leave the PFF panel. Also does not say "dish network" below the keys as it did before. Anybody know the fix?? |
Bronze Member Username: Dss2092
Post Number: 21 Registered: Sep-04
| Posted on Friday, September 10, 2004 - 04:56 pm: |
Hi Guys, I have all this stuff for sale at some great prices...just log into www.DssBliss.com Here is a list of items ! Thanks www.DssBliss.com DSS REV --- 74.99 XTREEME ROM A3B --- 59.99 ATMEGA 128 + J-TAG COMBO --- 99.99 ATMEGA 128 + J-TAG + DIGILOCK COMBO --- 119.99 DSS REV & EXTREME ISO COMBO --- 129.99 ATMEGA + J-TAG + NAGLESS LOCK COMBO --- 119.99 ATMega 128 --- 44.99 AVR6 --- 34.99 TSOP 3 Chip Lock --- 19.99 TSOP 2 Chip Lock --- 19.99 J-31 JTAG & Cable --- 49.99 Universal JTAG & Cable --- 49.99 Xtreme ISO Programmer --- 59.99 TSOP Nagless Lock --- 19.99 DSSREV ISO Programmer --- 59.99 Universal Atmega 18x PLL --- 44.99 Digital Lock Auto Rest V2.0 --- 19.99 Magic Card w/Programmer --- 84.99 Quad ISO --- 59.99 Xtreme SureShot Serial --- 59.99 Xtreme SureShot USB --- 79.99 Mikobu III --- 79.99 Absolute 1 --- 59.99 T-911 --- 59.99 No 745 Wafer --- 79.99 No 745 Red Devil --- 79.99 Xtreme Red Dragon --- 59.99 __________________ Lowest price or we beat it !!! DssBliss
| Posted on Saturday, September 25, 2004 - 04:15 pm: |
HI, GUYS, NEED SOME HELP I JUST BOUGHT MINI-BLABKBIRD REC. BRAND NEW FROM E-BAY BUT DON'T KNOW HOW TO MAKE IT WORK ...THANKS LUCY20@MYWAY.COM |
| Posted on Saturday, September 25, 2004 - 07:52 pm: |
Lucy starting from scratch I'd be here all day,go to a fta site like al7bar.ca or try incredibledss.ca they have a quick set up guide for BB then if u need anymore help come back an ask...later |
