Thread: American VHS video in European video recorder? |
| Posted on Wednesday, June 09, 2004 - 09:42 am: |
Hi, here's a question... Can I play a video I buy from an American ebayer on my European videorecorder or not? I was thinking that as long as both are VHS I should be ok... Or am I to optimistic? |
Bronze Member Username: Xol
Post Number: 12 Registered: Jun-04
| Posted on Wednesday, June 09, 2004 - 12:05 pm: |
Hi. I would sat you are too pissimistic. If your VHS is European i.e. PAL and your VCR is PAL there will be no problem. Most European VCR can palyback American (NTSC) VHS and some can record. In case you have PAL/NTSC problem you will most likely get B&W picture
| Posted on Wednesday, June 09, 2004 - 04:39 pm: |
Thank you very much for the reply!!!
| Posted on Sunday, June 20, 2004 - 05:26 pm: |
hey i was just wondering..i recorded a show on my vcr here in Canada(NTSC) and im going to be going to Europe where i want to show someone this tape.They have a multi-system vcr but the TV might be PAL and i don't know if it will work.THE VCR IS PAL/NTSC |
New member Username: Samijubal
Post Number: 6 Registered: Jul-04
| Posted on Friday, July 02, 2004 - 10:11 pm: |
If they have a multi-system VCR it will play. |
New member Username: Katily
Post Number: 1 Registered: Nov-04
| Posted on Thursday, November 04, 2004 - 04:44 pm: |
What about the opposite? I have a PAL tape, with a NTSC vcr and tv. Will I be able to watch the pal tape? |
Silver Member Username: Samijubal
Post Number: 378 Registered: Jul-04
| Posted on Friday, November 05, 2004 - 12:53 am: |
no |
Unregistered guest |
| Posted on Friday, December 10, 2004 - 12:45 pm: |
I am in the same boat as kate lily. I have a PAL vhs tape which I really, really need to watch here in USA. Is there somewhere I can have it copied onto the "right" format? thanks for any info!!! Nina NBruhns@aol.com
New member Username: Delightfuldenny
Tacoma,
Wa
Usa
Post Number: 1 Registered: Dec-04
| Posted on Friday, December 10, 2004 - 07:41 pm: |
hi, my samsung sw 5000 just went out and i don't want to buy another one. i see on ebay that there are pal converters that will convert pal to ntsc. i think i need a vcr that plays pal. can anyone tell me the best way to to this? i found cdm 1200 converter any good. help please. thanks, denny |
| Posted on Tuesday, February 08, 2005 - 01:54 pm: |
I used my camrecorder (Bought in the UK) to make a Video for my family in America... The Video is in a Mini DV Casette... My question is: Will they be able to watch it using an american VHS or DVD pLAVER?? tHANKS FOR YOUR ANSWER! |
Post Number: 598 Registered: Jul-04
| Posted on Tuesday, February 08, 2005 - 04:28 pm: |
If the camcorder is PAL, no. |
