Thread: Nagra 3 Just around The Corner |
Bronze Member Username: Thetaffey
Post Number: 42 Registered: Feb-08
| Posted on Thursday, August 28, 2008 - 12:18 pm: |
How Long till Nagra 3 is fully implemented in the stream? Anyone know Is this encryption system crackable? |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 3308 Registered: Oct-06
| Posted on Thursday, August 28, 2008 - 12:54 pm: |
Everything is crackable But to estimate exact time is totally unknown at this time I also think only B#V is swaping card D#N is taking an entirely differnt path I don't know if B#V completed all card swap Since I don't live in Canada To my best estimate I say end of September possibly October 2008 I don't know if all the sudden they decided to take same path as D#N and change entire hardware concept Everything is possible at this time But as a wild guess I say they'll take 2 different path One changing security card Other changing entire system concept If indeed this happens B#V will turn cold this Fall 2008 D#N will remain wide open until fall of 2009 I hope this helps to predict forcast a little |
Silver Member Username: Lomna
Post Number: 313 Registered: Dec-07
| Posted on Thursday, August 28, 2008 - 03:05 pm: |
K.T You are so smart ! how come ? I wanna be like you. |
NY
Post Number: 3313 Registered: Oct-06
| Posted on Thursday, August 28, 2008 - 03:18 pm: |
Nothing too smart It's common sense or educated guess Investgators have to follow trails and use educated guess Many times trails can turn cold I could be pissing in the wind if my strategy is wrong |
New member Username: Obamabinbiden
Piece,
Of
Shit
Post Number: 4 Registered: Aug-08
| Posted on Thursday, August 28, 2008 - 03:44 pm: |
DN card swap is under way! |
Bronze Member Username: Afg_paramin
Post Number: 76 Registered: Dec-07
| Posted on Thursday, August 28, 2008 - 06:39 pm: |
i heard it will come into effect when new channels launch usually in september |
Silver Member Username: Psychmonster
Rhodium Member aint nuthin...
Post Number: 900 Registered: Jul-06
| Posted on Thursday, August 28, 2008 - 09:38 pm: |
nag 3 has been in portugal for 2 1/2 years and no hack yet...compare to d4 direct tv card |
