Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Panset 3500sd keeping loosing signal
Author Thread: Panset 3500sd keeping loosing signal
Username: Shahrukh007
Post Number: 8
hello, I have superdish 121 with DP34 switch -> connect to my receiver pansat 3500sd -> when i turn off the switch from the back of the box it got the picture for few second then go back to no signal. Any reason this happening. How to fix it. Any help would be great help !!!!!!!!!
Post Number: 9
Any help would be great appropriate.
Username: Rtap
FL
Post Number: 2240
try running cable directly to lnb to see if you do not loose signal.you may have to replace the switch.
Username: Jjgee
Palatine, IL
Post Number: 130
Hey Tap, what is happening? Don't see you anymore at the other place.
Username: Rtap
FL
Post Number: 2241
whats up jjgee.what other places
Username: Jjgee
Palatine, IL
Post Number: 131
Crzy
Username: Rtap
FL
Post Number: 2243
i left crazy to av and yosanth.i am running dssworld.co*nr replace the * for .
come check it out jjgee.you love it.live chat box for help.i'm there now
Username: Jjgee
Palatine, IL
Post Number: 132
I was wondering where you went, I will come over and look you up.
Post Number: 10
Guys how can i connect pansat without DP34 switch.
Username: Picanha
East LA
Post Number: 54
Probably start another thread since dumbazz jjgee hijacked your thread and RTAP saw an opourtunity to pimp out his stupid site.
Post Number: 11
How should remove the dp 34 switch and connect one 3 LNB to pansat ?
Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Panset 3500sd keeping loosing signal [ « Previous ] [ Next » ]
