Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Sonicview 4000 Acting Strange
Author Thread: Sonicview 4000 Acting Strange
Username: Toney
Antigua
Post Number: 56
Hello Everyone,
I am presently experiencing this problem with my Sonicview 4000 Receiver. The problem that I am experiencing is I am getting NO Signal on my television screen. Whenever I do a blind scan on my receiver, I am seeing all the channels appearing and also my signal strength. When I exit out of the menu, I am getting No Signal appearing on my television screen. I hooked up, another receiver to the same cable coming from my dish, and I am getting picture and also signal strength. I change my LNB type to Universal and Single in thr Dish Setting Menu and it is not working. I flashed my receiver with the Factory bin then with SV4000_V0249P_Charlie_Fixed_081308.bin and it is still not working. My Setup is as follows:
1 12ft Solid Prime focus Dish
2 California Amplifier for Prime Focus Dish
3 Single Cable run from the LNB straight to the Receiver.
I would grateful if you can assist me in having my problem resolved. Thanks in advance.
Username: Tapeman
New York City in-HD, NY
Post Number: 3293
I don't have proof of this
But I'm suspecting newer ECMs designed to cause conflict especially when yo do blind scan
This is what I would do:
- Load newest bin
- Do factory default
- Do not do blind scan
- Do channel sat scan or TP scan
- Do and test one sat at a time
- Come back and tell me how this worked for yo
Username: Mucho
Post Number: 554
Andre Toney
With the equipment listed above what
satellite on C-band are you trying to scan in?
What make and type LNB are you using?
Username: Tapeman
Post Number: 3296
He's saying signal problem on ku band
Due to blind scan
Username: Toney
Antigua
Post Number: 57
Hello Guys,
Thanks for your suggestions. I am on Echostar 3 (61.5) where I am experiencing this problem. I am living in the Southern most part of the Caribbean.
Toney.
Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Sonicview 4000 Acting Strange [ « Previous ] [ Next » ]
