Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Pansat 2700 night rider lights
Author Thread: Pansat 2700 night rider lights
Username: Lizwakefield
Post Number: 87
hi how can i fix the night rider light problem i have a converted flu to pansat
2500 or 2700 i am not 100% but it doesnt have the b75 bin installed
thanks
please help
Username: Prfrmnj
Post Number: 2869
You will need to do a forced boot flash! Basically follow this:
1. Power Down and disconnect STB.
2. Connect STB to your PC
3. Open BL Loader
4. Open Bin File to Load
5. Click Download to commence File Transer.
6. Immediately turn STB on from Rear
DO NOT interrupt the process until download is complete.
YOU WILL see a message at the end of the download saying "Burning". Do not be alarmed, this is normal.
Once the download is complete, your stb will reboot itself. Power down STB from rear and reconnect to your TV.
Post Number: 88
which loader do i use 1.4 or 2.72
and boot file 75 right?
Username: Prfrmnj
Post Number: 2872
The loader is going to depend on what files you have loaded in the past. But it should be 2.72
A pic is worth
1000 posts!!
Post Number: 17938
PRFRMJ
Where the hell have you been?
Don't mind me. I'm an interested surfer.
Username: Prfrmnj
Post Number: 2873
Paul - I've been modding at FTA Bins. Decided to stop by to check out what was going on and posted here and there to help out. lol
Post Number: 89
the thing is its not my receiver so id ont knwo waht was put there in there in the past :-(
Username: Justforhahas
Post Number: 170
Go into menu and system info and find out whats loaded in there now.
Post Number: 90
I CANT DO THAT CUZ THE LIGHT ARE FLASHING OVER ......
ALSO MY OTHER RECEIVER ALSO PANSAT 2700 JUST DIED AFTER I LOADED BIN286 FEW DAYS AGO ANYONE KNOW WAHTS THE PROBLEM THERE.....IT WAS WORKING AT FIRST AND THEN IT JUST STOPPED
Username: Prfrmnj
Post Number: 2874
Your gonna need to know if b75 was loaded on that receiver and then load then follow what I told you to do earlier. As far asthe one not working, sounds like you need to jtag it. This is because it may very well have been a clone and you loaded a file intended for an original and not clone.
Post Number: 91
i am pretty sure that b75 was not loaded on the receiver..i tried to load it but it didnt work..or maybe i had the wrong boot file waht do i do
thanks for ur help :-)
Username: El_birbano
Calle12, Sonora
Xxx
Post Number: 170
Liz. Knight Rider (----) mean boot60
just load CanAm-Puff_253_640 K)
(load this bin when the KR are running)
wait untill you see PUFF
running on the led
That mean "converted to PUFF."
then load last bin 286 PUFF
when PUFF are running, (no turn off receiver
Do as PRFRMNJ said to download the files, but use BL 1.40 loader
Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Pansat 2700 night rider lights [ « Previous ] [ Next » ]
