Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Puff 283 jvvh still the champ
Author Thread: Puff 283 jvvh still the champ
Username: Psychmonster
Rhodium Member
aint nuthin...
Post Number: 894
autoroll off searches 440% and then am back on Bev and Dn and no freezing...cheers to mods...this has defeated the morph so far
Rhodium Member
aint nuthin...
Post Number: 895
trick is setting default after any changes... default...works auto and auto off...takes 10 mins to go though both but try roll on , defaut, hard boot and then do the same with autoroll off searching let it play out...bev0901...scramnbled will be there afer search 5 mins then you are up...this is old tech...they have not defeated it yet...they are woking on the 287...just give 10 mins patience (autoroll, off is best....and you are wide open....if you cant figure this out, you beed to back to 101
Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Puff 283 jvvh still the champ [ « Previous ] [ Next » ]
