Thread: Need help with Anik F3 118.7 EPG using echostart 9 on VS PVR 7000 |
New member Username: Bajranbali
Post Number: 2 Registered: Feb-08
| Posted on Saturday, August 23, 2008 - 12:00 pm: |
i read threads on this forum and other forum but none help. Here is what i did. i use eacho star 9 (121) satelite and modify TPs for 118, scan the satelite i got all the channels with correct SID. but problem is i dont get EPG not current program information even. i try tunning to GEO and AAGTV for entire night but didn't get any info. i downloaded receiver guide but still didn't get current running program information. i did blind scan also. nothing help me, i am getting 11 channel on TP7 11806 which is right according to lyng sat. i have a single LNB which can get both echostar 7 and anik F3. i use universal setting and standard setting to scan echostar 9 but nothing help. any suggestion to try out Thanks in advance |
Platinum Member Username: Nydas
Post Number: 11413 Registered: Jun-06
| Posted on Saturday, August 23, 2008 - 03:08 pm: |
Best if you post your detailed settings for 118.7 and 119 |
Post Number: 3 Registered: Feb-08
| Posted on Sunday, August 24, 2008 - 07:41 pm: |
Thanks for reply here is setting for both i put on universal lo setting is on 10750 on disqec port 2, 7th TP is 11806 20000 FEC 7/8 got all 11 channels. what else you needed, is PVR 7000 code is able to get EPG for 118.7? |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 3474 Registered: Jan-08
| Posted on Sunday, August 24, 2008 - 11:58 pm: |
bjaranbali note your satellites settings, do a factory default, load bin file and rescan your sat
Bronze Member Username: Taran420
Post Number: 73 Registered: Jan-07
| Posted on Monday, August 25, 2008 - 02:06 pm: |
well, this is a common problem with anik 118 with VS 7000. Even i dont get EPG on my VS PVR, but get it fine on my SV8000HD and VS Ultra...........i guess something in the programming..............if u solve it, do let us know |
