Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Help with CW 600S Premium
Author Thread: Help with CW 600S Premium
Username: Vasu_vijay
Post Number: 68
IS the file 2.01 latest fix for DN?MY old bin 2.00 went scrambled since thursday?Please let me know
Username: Justforhahas
Post Number: 117
All fixes are always for BOTH DN and Bev. They are usually released to fix a previous provider (DN or Bev) ECM, but will get both providers always, unless a new ECM goes into affect.
File 2.01 was released on August 15, after a Dishnet (DN) ECM on August 13. It gets Both providers now.
Username: Brucester
Post Number: 1585
and by the way it came out on the 14 not 15 lol
Username: Brucester
Post Number: 1586
Forum Last Post Threads Posts
CW 600 Regular Files
Files Only
Cw600sv1.96
by CG 08-14-2008 10:53 PM 59 59
CW 600S Premium Files
Files Only
Cw600pv2.01
by CG 08-14-2008 10:52 PM 63 63
CW 650 Classic Files
Files Only
CW650S_Classic_V1.30
by Fastlane 08-14-2008 10:53 PM 26 26
CW 700S Files
Files Only
Cw700sv1.83_2008_08_14
by Fastlane 08-14-2008 11:48 PM 50 50
Captive Works 800S Files
Files Only
Cw800sv1.83_2008_08_14
by Fastlane 08-14-2008 11:50 PM 71 71
Captive Works 1000 Section Files
Files Only
CW1000-SC_Update_07-23
by CG 07-25-2008 07:28 AM 11 11
Captive Works 3000 Hi Def Files
Files Only
cw3000-sc-update-08-21.tar.bz2...
by Ironcladbrute 08-21-2008 11:12 PM 70 70
Captive Works CW100-R Files
Files Only
CW100R update 06-02-2007
by CG 09-19-2007 12:17 PM 1 1
Post Number: 123
Bruce , have you been an arguing wannabee azzhole your entire life?
The USA is divided in time zones, the files came out early in the morning on the 15th EST.
and look at your time 11pm on the 14th, you want to be an azzhole over 1 hour?...guess you do...You are a typical Zoocoustics wannabee providing no informative posts, just wrongful bashing and info.
Username: Nydas
Post Number: 11410
Bruce 1: Please keep on helping the CW people and do not listen to disrupters
Username: Brucester
Post Number: 1588
my info is right your info is not thats a c/p from completefta you try to mack cw look bad the 14 is the 14 not the 15 burnout and i am not going to stop helping with cw but thanks to other members here i dont have to help all the time
Post Number: 125
You are an idiot like your brother Plymouth, if you think thats a copy/paste from anyplace.
Go play with that toy receiver you have.
Post Number: 126
Yes yours is c/p, based on PST time. My posts are my own and factual, unlike yours.
Username: Nydas
Post Number: 11415
justforhaha: The only obvious idiot here is YOU...
Post Number: 127
Its the Ecoustics queen wannabee herself, still giving out wrongful info.
Username: Gregraf
Post Number: 1068
Username: Plymouth
Quebec city, Quebec
Post Number: 3459
HAahaha aka LK
you are a bulshiter
Username: Kenroy
Kingston, Kingston
Jamaica
Post Number: 36
bruce i need help with my CW 8oo.... is it up or down because i dont know if i set it up properly
Username: Plymouth
Quebec city, Quebec
Post Number: 3470
Kenroy it is up, check if autoroll is "on"
and do a hard reboot after load file
Username: Brucester
Post Number: 1592
its up on dish and bev
Guide to Loading Your CW800
1. Plug in USB w/unzipped files into CW800 (USB READY WILL APPEAR)
2. Press the USB button on the remote
3. Scroll over and select the SOFTWARE TAB
4. Find new file and press OK
5. When finish press YES to reboot
6. After reboot factory default (MENU>INSTALLATION>FACTORY DEFAULT)
7. Set antenna settings and scan satellites
8. Enable the Patch (F1 then 000)
9. Wait for box to autoroll
10. WATCH TV
Username: Brucester
Post Number: 1593
here is some good info for you to c/p in your computer
CW 800 Remote Setup and Codes
C/P
Code input
1. Turn on the device which you planning to program
2. Find the code from the code list to match the brand of your device.
3. Press "SET" button until 3 seconds later, then LED will be light on.
4. Press the device function button( ex. TV), then the LED will light once.
5. Input the 3 digi code which matches the device in the list, the LED will blink once for each code. If the code is valid for this device, the LED will be off, means the code is fit for this device. If the code is not valid, therj the LED will be off after blink some times, means the code is not correct for this device, need to input new code..
6. Now to test whether the RCU can control the device, if can't, return back to the code setup procedure, and input other code that supposed to match this brand device, if all the code under this brand can't control this device, you need to try the following way by code searching, you may be able to find the code.
7. Write down the correct code for next time use.
Manual codesearch
Code searching means starting from the current device by pulsing 1 to continue search, one time "POWER" one time plus 1 to the code.
1. Press "SET" and hold it for 3 seconds, then LED will be light.
2. Press the function button (ex.TV) , LED will blink once
3. Aim the RCU to the device (ex. TV) and press "POWER" button, one time "POWER" you will get LED blink once..
4. When it switch off the device, means the code you input is correct, then press"EXIT" and save the code, LED will be off.
If you have problems with tv and dvd hold SET down for 3 seconds while holding SET push TV or DVD while SET is being pushed. Led light on TV or DVD should stay on, then put code in.
Code auto setup
1. Press"SET" and hold for 3 seconds, LED will be on
2. Press the function button(ex.TV), LED will blink once.
3. Aim the RCU to the device (ex.TV) and press"POWER" button once and release.
Code Display Setup
1. Press "SET" and hold for 3 seconds, LED will be on,
release the button.
2. Press the function button (ex. TV), LED will blink once.
3. Press "SET" button again, LED will blink once.
4. Press any numeric button, when you press one number and make the LED blink once, this number should be the first one in the code.
5. Repeat the above 4, take the same way to find the second and third number for this code. When you find the third number, the LED will be off.
• TV
1 ' ABEX 120
2 ADMIRAL 603.224.701
3 ADVENT 219.893
4 ADVENTURA 019
5 AIKO 407
6 AIWA 121.221.324.528
7 AILERON 706
8 AMARK 603
9 AMTRON 906
10 AKAI 112.801.309.024
11 ANAM.NATIONAL 906.901.104.805.920
12 AOC
902.102.502.003.217.119. 320
13 APEX 023.223.123.741
14 ARCHER 603
15 ASPECT 507
16 AUDIOVOX 906
17 AXION 319.793
18 BANG&OLUFSEN 620
19 BELCOR002
20 BILL.&.HOWELL 704.506.601.701
21 BENQ 709 .909.711
22 BRADFORD 906
23 BROKSONIC 316. 115.626.
327.632.041
24 BROKWOOD 002
25 CANDLE 002.502. 019.402
26 CAPEHART 119
27 CELERA 023
28 CELEBRITY 801
29 CENTROS 518
30 CENTURION 502
31 CETRONIC 805
32 CHA.NGHONG 023.741
33 CITIZEN 002.502.906. 112.512.115.520.701.402. 805.407
34 CLAIRTONE 003
35 CLASSIC 023.741.805
36 CLP 006.008
37 CLP.CLASSIC 021.011.005. 020.002.006
38 COLOR.VOICE 602
39 COLORTYME 002.502.602
40 CONCERTO 002.502
41 CONCIERGE 713
42 CONTEC906.802.003.805
43 CORNEA 606
44 CRAIG 906.805
45 CROSLEY 807
46 CROWN 906.805
47 CURTIS.MATHES
704.112.614.002.502.601. 506.512.437.701.103
48 CTX 603
49 CXC 906.805
50 DAEWOO 614.002.502. 611.102.415.905.505.826. 529.609.805.407.303.602. 214.403.314.503.615.046.
51 DAYTRON 002.502
52 DELL 522.404.814
53 DIAMOND.VISION 622.810.496
54 DIGISTAR
056.118.413.213.318
55 DIMENSIA 704.601
56 DISNEY 417
57 DUKANE 507.808
58 DUMONT 713.002
59 DURABRAND 520.115. 916.024.317.027.447.323
60 DYNASTY 805
61 ELEKTRA 701
62 ELECTROBAND 801.003
63 ELECTROHOME
002.502.024.901.803.027
64 ELITE.VIDEO 321
65 EMERSON
002.502.006.115.506.706.5
20.906.316.614.505.324.92
4.626.826.024.327.128.228.
632.134.247.605.705.805.7
03.903.004.519.106.104.30
4.604.804.005.105.305
66 ENVISION
002.502.009.027
67 FISHER
506.612.428.619.802
68 FUJITSU 321.706
69 FUNAI
706.520.906.324.247.805
70 FUTURETEC 906.805
71 GATEWAY 206
72 GE
704.312.018.002.502.006. 007.601.835.901.114.103. 803.806.310
73 GIBRLTER 713.002
74 GOLDSTAR
002.205.102.324.435. 802.307.609.217.502
75 GRUNDY706.906
76 UESTVISION 721
77 HAIER
709.223.323.317
78 HALLMARK 002.502
79 HARVARD 906
80 HITACHI
410.507.815.607.808.002. 502.710.324.701.802.707. 315.515.715.519
81 HISENSE
908.819.023
82 ILO 421.078.001.116
83 IMA 906
84 INFINITY 807.430
85 INITIAL 078
86 INSIGNIA
911.520.247.504. 323.115.914.213.318
87 INTEGRA 719
88 INTEQ 713
89 JANEIL 019
90 JBL 807
91 JCB 801
92 JC.PENNEY 704.002 102.502.112.321.512. 007.601.310.402.802. 103.803.604.806.312
93 JENSEN 002.502.914
94 JVC 607.204.321.508. 326.993.802.108.308.1
95 KAWASHO 002.502.801
96 KAYPANI 119
97 KEC 805
98 KENWOOD 002.502
99 KLH 023
100 KLOSS.NOVABEAM 408.019
101 KONKA 906.702.203j - 208.911.842.942.504.
102 KTV 906.003.703.805.608
103 KURAZAI701
104 LASONIC622.496
105 LG 002:606.502.102: 435.802.307.609.217
106 LIQUIDVIDEO 319.418.793
107 LODGENET
704.821.701.601
108 LOEWE 722.807
109 LOGIK 704.701.601
110 LUCE 107
111 LUXMAN 002.502
112 LXI 704.002.502.506.
807.312.512.601.324.103
113 MAGNASONIC 706
114 MAGNAVOX 807.002. 502.919.224.430.247. 402.408.109.715
115 MAJESTIC 704.601.701
116 MARANTZ
807.719.002.502
117 MEDION -922.421.417
118 'MEGATRON
002.502.507
119 MEI 003
120 MEMOREX 002.502. 506.706.115.704.601. 428.632.701
121 MGA 002.102.502. 706.802.803.715.619
122 MIDLAND
704.713.007.312.103
123 MINUTZ 806
124 MITSUBISHI
102.716.706.002.502. 024.803.715..619.027
125 MONIVISION 205
126 MONTGOMERY.WARD 704.601.701
127 MOTEVA 506
128 MOTOROLA 603.901
129 MTC 002.102. 502.112.512.003
130 MULTITECH 906
131 MULTIVISION 010
132 MYRON&DAVIS 822
133 NAD 002.502.512.120
134 NEC 719.002.102.
502.901.602.111.715
135 NETTV 206.014
136 NEXXTECH 113.318
137 NIKEI 805
138 NIKKO 002.502.407
139 NORCENT 223.905.207
140 NTC 407
141 OLEVIA 040
142 ONCOMMAND 721
143 ONKING 805
144 ONWA 906.805
145 OPTIMUS
618.120.039.739
146 OPTOMA050
147 OPTONICA 603.111
148 ORION 713.115.105
149 PANASONIC
718.416.007.618.807.039. 739.345.696.901.608
150 PHILCO
807.002.102.502.919.408. 109.715.901.402
151 PHILIPS
807.022.020.422.122.222. 322.002.520.919.521.621. 430.247.901.402.408.109. 210.310.715
152 PHILIPS-MAGNAVOX
807.022.322.-919.224.430
153 PILOT 002
154 PIONEER
120.719.808.002. 502.610.519
155 PIVA 030
156 POLAROID 819.918.914
157 PORTLAND
002.102.502.415.614.407
158 PRECISION 218
159 PRICE.CLUB 112
160 PRIMA
056,118.213.318
161 PRINCETON.GRAPHICS 603.511
162 PRISM. 007
163 PROSCAN
704.312.601.817.917.103
164 PROTON
820.002.502.910.119.220
165 PROVIEW 017.031
166 PULSAR 713.002
167 QUASAR
718.416.007.618.807.039. 739.901.608
168 RADIO.SHACK
704.002.406.506.906.618. 502.324.835.601.802.705. 805.111
169 RCA 704.002.406. 007.011.611.811.312.514. 720.102.502.601.817.917. 835.901.103.803.211.912. 114.519.320.420
170 REALISTIC
704.002.406.506.906.618. 502.324.601.802.705.805. 111
171 RHAPSODY 003
172 RUNCO 713.719.712173 SAMPO
014.206.002.502.119.802
174 SAMSUNG
112.309.209.512.302.502. 002.102.110.818.895.437. 802.103.609.012.212
175 SAMSUX502
176 SAMTRON 112
177 SANSUI 115.632
178 SANTECA 021
179 SANYO
506.311.612.002.428.802. 412.619
180 SCOTCH 002.502
181 SCOTT
002.502.706.906.004.1 J3 805
182 SEARS
704.807.506.706.112. OCJ 502.312.512.612.520.6C1 812.509.041.247.802.1C 619
183 SELECTRON 101.069.079
184 SHARP
509.913.907.603.002.5C 224.228.202.111.813
185 SHOGUN 002
186 SIGNATURE
704.601.701.903
187 SIMPSON 402
188 SONIC 003
189 SONY
414.902.801.708.639
190 SOUNDESIGN
002.502.706.906.402.8C
191 SPECTRAVISIN 921
192 SQUAREVIEW 520
193 SSS 002.906.805
194 STARLITE 906
195 STARSIGHT 008
196 SUPRA 002.809
197 SUPERSCAN 812.509.24
198 SUPERSONIC 096
19.9 SUPREMACY 019
200 SUPREME 801
201 SVA 223
202 SYLVANIA
807.002.502.115.520.911 324.247.402.408/109.7H 717
203 SYMPHONIC
906.520.324.247.004
204 SYNTAX 040
205 TANDY 603
206 TATUNG 709.421.5
207 TECHNICS 007
208 TECHWOOD 002.502.007
209 TEKNIKA
704.002.102.502.706.906. 112.512.618.601.019.701. 402.802.805.407
210 TELECAPTION 313
211 TELERENT 704.601.701
212 TERA 002.220
213 TEVION 421
214 TMK 002.502
215 TOSHIBA
517.419.512.613.719.112. 506.111.618.627.437.041. 094.802.111.313.715
216 TRUTECH 057
217 UNIVERSAL 806.310
218 VICTOR 607
219 VIDTECH 002.102.502
220 VIEWSONIC 206.808
221 VIKING 019
222 VIZIO 709
223 WARDS
704.807.002.102.502.706. 601.408.109.310.111.513. 806.701.402.004
224 WESTINGHOUSE 915.013
225 WHITE.WESTINGHOUSE 611.614.415.215.324.529. 609
226 YAMAHA
618.002.102.502
227 ZENITH
713.502.606.409.710.507. 714.405.712.015.916.008. 002.115.415.224.324.326. 826.228.430.632.435.437. 903.407.505.701.126
Plasma,LCD&Panel TVs
1 AKAI 309
2 BENQ 709.909
3 CORNEA 606
4 DAEWOO 614
5 DELL 522.404.814
6 DUKANE 507.808
7 ELITE VIDEO 321
8 ENVISION 009
9 FUJITSU 321
10 GATEWAY 206
11 HAIER 709
12 HISENSE 908
13 HITACHI 507.808
14 INSIGNIA 911
15 INTEGRA 719
16 JVC 204.321
17 LG 606
18 LUCE 107
19 MARANTZ 719
20 MEGATRON 507
21 MITSUBISHI 102.716
22 MONIVISION 205
23 MYRON&DAVIS 822
24 NEC 719
25 NETTV 206.014
26 NORCENT 905.207
27 PANASONIC 618.718
28 PHILIPS 422
29 PHILIPS-MAGNAVOX 022
30 PIONEER 808.719
31 POLAROID 819.918
32 PRINCETONGRAHICS 511
33 RCA 704
34 RUNCO 719
35 SAMPO 014.206
36 SAMSUNG 309.302.209
37
38
39
40
41
42
43
44
45
46
47
48
49
SANYO SEARS SHARP SONY
311
812
907
902.414
SUPERSCAN 812 TATUNG 709.421 TEVION 421 TOSHIBA 618.719 VIEWSONIC 206.808 VIZIO 709 WHITE WESTINGHOUSE 215
YAMAHA 618 ZENITH 606.409.714.507
10
11
12
13
GOVIDEOHDT100
662
Hitachi 61HDX98B
864
Hughes HTL-HD
362.864.765
Hughes HIRD-E8
362.864.765
LGLSS-3200A
362.864.765
LG HTL-HD
362.864.765
Mitsubishi SR-HD5
864
Mitsubishi SRHD400
864
Mitsubishi SRHD500
864
MOTOROLAHDT10
463
Philips DSHD800R 864
Pioneer SH-D505 062
Proscan PSHD
105 265
14 RCAHD65W20 4671
15 RCAPSHD105 265J
16 RCADTC-100 265
17 RCADTC-210 265
18 Samsung SIR-T165 959
19 Samsung SIR-T351 959
20 Samsung SIR-TS160 563
21 Samsung SIR-TS360 563
22 SonySATHDlOO 963
23 SonySATHD200 963
24 SonySATHDSOO 963
25 SYLVANIA6900DTD 759
26 Toshiba DST3000 362.765
27 Toshiba DST3100 362.765
28 Toshiba DW65X91 362.765
29 Zenith HDSAT420 065
30 Zenith HDSAT520 065
31 Zenith DTV1080 065
AUX<laserdisc>
1 DENON 132
2 PIONEER 132
3 PROSCAN 432
4 RCA 432
5 SANYO 824
6 SONY 933
7 ZENITH 824
AUX<Home Automatic
1 GEHOMEMINDER
2 HOME AUTOMATION
• VCR
1 ACCELE 037 31
2 ADMIRAL 224 32
3 ADVENTURA 726 33
4 AIKO 826 34
5 AIWA 126.324.528.726 35
6 AKAI 36 324.524.424.624.724.027. 37 931.335 38
7 ALLEGRO 326.534.925
8 AMERICAN HIGH 830
9 APEX 596
10 ASHA 037
11 AT&T 938
12 AUDIO DYNAMICS
239.339.025 39
13 AUDIOVOX 126
14 ****&HOWELL 428
15 BEAUMARK 037 40
16 BROKSONIC 41 227.626.327.632.041.398. 42 325.530 43
17 CALIX 126
18 CANDLE
625.126.037.025.825.026 44
19 CANON 124.830.535
20 CAPEHART 534 45
21 CARVER 30 46
22 CCE 826.237
23 CINEVISION 126
24 CITIZEN 47 625.126.826.037.025.825. 48 026
25 COLORTYME 025 49
26 COLT 237 50
27 CRAIG 126.037.237.426 51
28 CURTISMATHES
124.330.324.035.037.437. 52 025.526.830 53
29 CYBERNEX 037 54
30 DAEWOO 55 529.625.626.826.035.825. 56
026.726.798
DBX 239.339.025
DIAMOND VISION 291
DIMENSIA 124
DURABRAND 126
DYNATECH 324.726
ELECTROHOME 126.027
ELECTROPHONIC126
EMERSON
626.126.826.227.327.630.
632.134.037.625.924.324.
128.228.428.528.247.447.
724.325.526.726.027.527.
827.927.628.530.830.731.
634.735
FISHER
032.428.328.330.025.426
928.029
FUJI 524.830
FUNAI 324.247.447.726
GARRARD 726
GE
124.732.135.835.037.429.
830
GOLDSTAR
324.126.435.534.236.025
GRADIENTE 726
GO-VIDEO
037.139.342.244.147.798.
438
HARLEYDACIDSON 726
HARMANKARDON
025.027
HARWOOD 237
HEADQUARTER 428
HITACHI
538.324.336.931.834
HI-Q 426.
INFINITY 430
INSIGNIA 126
INSTANT REPLAY 324.830
INTEQ 126
57 JCPENNEY
124.126.428.037.538.239. 339.830.931.834.935.025
58 JCL 830
59 JENSEN 538.931
60 JVC
239.339.428.326.443.025. 931.691
61 KENWOOD
428.239.339.025.931
62 KLH 237
63 KODAK 126.830
64 LG 324.534.435.392
65 LITEON 068
66 LLOYD 324.726
67 LOGIK 237
68 LXI 324.126
69 MAGNAVOX
330.430.534.224.124.247. 230.125.324.093.598.830
70 MAGNIN 037
71 MARANTZ
330.428.239.339.530.830. 535.025
72 MARTA 126
73 MATSU****A 830
74 MEDION 291
75 MEI 830
76 MEMOREX
330.126.428.032.632.534. 037.224.324.335.426.726. 830
77 MGA 630.027
78 MGN TECHNOLOGY 037
79 MIDLAND 429
80 MINOLTA 538.834
81 MITSUBISHI
630.431.538.239.339.027. 131
82 MONTGOMERY WARD 224.631
83 MOTOROLA 224.830
84 MTC 324.037.
85 MULTITECH
324.037.726.429.237
86 NEC
428.239.339.530.731.81 931.025.526
87 NIKKO 126
88 NOBLEX 037
89 OLYMPUS 830
90 OPTIMUS
525.037.937.126.737.C 739.224
91 OPTONICA 037.631
92 ORION 227.632
93 PANASONIC
937.739.039.938.124.-830
94 PENTAX 538.025.8S
95 PHILCO 330.124.125
96 PHILIPS
330.430.036.136.738.•< 939.247.230.830
97 PHILIPS-MGNAVOX 330.430.224
98 PILOT 126
99 PIONEER
132.538.239.339.935.£
100 POLAROID 596
101 PORTLAND 825.0261
102 PROSCAN 124.432
103 PROTEC 237
104 PULSAR 534
105 QUARTER 428
106 QUARTZ 428
107 QUASAR
937.039.124.739.830
108 RADIO SHACK
124.224.324.525.126 835.037.737.937.426 027.029.830.631.335
109 RADIX 126
110 RANDEX 126
111 RCA
124.126.432.532.732.832. 932.033.133.233.135.835. 037.538.424.429.830.834
112 REALISTIC
124.224.324.126.428.037. 737.937.426.726.027.029. 830.631.335
113 REPLAYTV 938
114 RICOH 936
115 RIO 126.142
116 RUNCO 534
117 SAMSUNG
037.437.625.538.147.895. 997.624.335
118 SANKY 224.534
119 SANSUI
632.239.339.041.227.931
120 SANYO
032.328.428.037.426
121 SCOTT
625.626.327.630.735.325. 927
122 SEARS
937.126.428.330.538.041. 247.426.928.029.830.834. 935
123 SHARP
637.737.224.324.228.825. 027.631
124 SHINTOM
524.936.538.237.337
125 SHOGUN 037
126 SIGNATURE 324
127 SINGER 830.237
128 SONIC BLUE 938
129 SONY
539.034.524.933.936.540. 838.038.138.238.639
130 STS 538.830.834
131 SUPERSCAN 247
132 SYLVAN IA
324.330.630.124.225.247. 447.726.830.
133 SYMPHONIC
324.225.247.726
134 TANDY 324.428
135 TASHIKO 126
136 TATUNG 931
137 TEAC 324.726.931
138 TECHNICS 830
139 TEKNIKA
324.126.134.726.830
140 TiVo 738.838
141 TMK 037.526.731
142 TOSHIBA
625.727.627.330.630.437. 538.094.029.735
143 TOTEVISION 126.037
144 UNITECH 037
145 VECTOR RESEARCH 625.239.339.025
146 VICTOR 239.339
147 VIDEO CONCEPTS 625.239.339.025.027
148 VIDEOSONIC 037
149 WARDS
124.224.324.625.126.037. 538.426.726.027.830.631. 234.834.735.237
150 WHITE WESTINGHOUSE 324.529
151 XR-1000 726.830.237
152 YAMAHA
239.339.025.931
153 ZENITH
534.326.826.228.430,224. 324.435.336.936.437.126. 524.632.824.239.339.529. 438.925
AUX<audio>
AIWA 585.885.786.687
1
31
2 APEX 245
3 APPLE IPOD 190
4 BOSE 868
5 CARVER 184 32
6 CENTRIOS 028.087 33
7 CITIZEN 284 34
8 CRITERION 446 35
9 DENON 981.383.886 36
10 DELPHI 472 37
11 FISHER 083.783 38
12 GOLDSTAR 278 39
13 HARMAN KARDON 082.483
14 IPOD 0090 40
15 JVC 680.982.583 41
16 KENWOOD
969.482.283.484.884.588
17 KOSS 143
18 MAGNAVOX 42 281.083.193.277 43
19 MARANTZ 470.084
20 MITSUBISHI 389 44,
21 NAD 773.575.975
22 NEC 174 45
23 NEXXTECH 46 028.679.879.480.580.584. 47 087.787 48
24 NORCENT 392
25 ONKYO 182.782.882.890.
26 OPTIMUS 49 368.376.476.576.776.876. 077.980
27 PANASONIC
780.682.183.983.987.088. 790.696
28 PHILIPS
177.083.983.084.184
29 PIONEER
385.288.388.489.990
30 RADIO SHACK
272.077.980.282.188.2J
388.488.189.489.589
RCA
373.274.878.779.181.38
186.288.388.688.788.8£
189.489.589.546.191
REALISTIC 883
RIO 142
SABA 091
SAMSUNG 047
SANYO 172
SCOTT 478
SHARP 768.070.5£
SHERWOOD
272.282.487.587
SKYFI 174
SONY
933.479.579.180.381.48
581.984.085.185.285.5
592
TAO 174
TEAC
672.382.187.287.387
TECHNICS
780.682.183.983.987.C
TEVION 446
VINTURER 176
XMRADIO 472.174
YAMAHA
781.881.485.685.785.2!
386.486.586
ZENITH
269.674.576.577.178.21
080.083.380.686.142
thanx goes to the writer
How to for PVR for CW800
How to use feature:
1.) TO Timeshift press PAUSE button and give it a few seconds to get ahead of real time then press PLAY when you want to watch. Press INFO button to remove the info bar at bottom. You can also FF and RW in timeshift mode. Both RW and FF have a delay to start working about 2 seconds. To return to Play from FF or RW press PLAY again. To End Timeshifting press STOP then it will return you to live play.
2.) To Record Press RECORD button and you will see a popup window that will ask do you want to RECORD CURRENT CHANNEL? If you answer YES then it will start record with a 2 second delay or if you answer NO it will give you a choice to record another channel on same TP, very nice feature, you can record another channel on same TP and watch the one you are on. All this with one tuner, impressive. When Recording starts you will see info bar at bottom giving name of show and time of recording and size of file as well as playtime. You will notice playtime is about 4 seconds behind. When you want to end recording press STOP.
3.) To Playback press USB button and it will take you to the USB menus were you could find your recording. Scroll down to recording and press OK. If you press INFO button you can see progress bar. Now you have choices on playback. You can FF different speeds 2x, 4x or 8x, RW you also have the same. To stop FF or RW you need to press PLAY if you press FF or RW button again it advances to the next speed.
4.) Sizes of files save on recording is much better than CW100-R. It will record a file as large as 4g and the will start another file. 4g is plenty to record a show or movie or football game. I recorded a football game and it was under 3g.
5.) To delete recordings of any file on USB drive enter the USB menu and Highlight the file you want to delete and press SAT button and it will confirm you really want to delete it. Say YES and it is gone.
6.) Setting timer for recording from EPG is done the same way as in the CW600sp. Find the show you want to record then press the GREEN button and a timer will be setup for you. That is all you need to do.
7 To get rid of record Message press info
How To Load Bins On CW800S Using NULL Cable.
1. Power STB OFF using the back switch.
2. Connect NULL cable to computer and STB.
3. Open CW800S loader.
3. Turn power back ON (Let the STB boot up completely).
4. Press power button on the front panel to put the STB on "Standby Mode" -- -- -- --
5. Browse and select the latest bin file and press "Start"
NOTE: Do not interrupt the loading process, wait until the front display shows "END".
6. Turn power OFF and ON again, let the STB boot up until it shows 0000 on the display.
7. Factory default the CW (menu > installation > factory default), set the antenna settings, autoscan (red button) . Enable the patch (F1 then press 000).Wait for box to autoroll.
8. Sort channels by "SID" (menu > System Setting > scroll down to channel and change it from "Normal" to "SID" and exit.
9. Turning autoroll ON/OFF if needed for manually keys entry (Menu > System setting > System > OSD > Scroll down to autoroll.
Home > Message Board > Home Video > Satellite TV > Archive through August 28, 2008 > Help with CW 600S Premium [ « Previous ] [ Next » ]
