Thread: 65" Mitsubishi Rear Projection won't turn on. Help!! |
New member Username: Ljboulet
Post Number: 2 Registered: Aug-08
| Posted on Friday, August 15, 2008 - 11:17 am: |
I really need some help please. My husband moved out. My TV worked fine until the day he moved. He unplugged most of the home theater equipment and took most of it (he bought it). I own the tv. When I went to plug the tv in - it literally will not turn on. Not with physically pushing the power button and not by using the remote. I have tried plugging it directly into the wall socket and into the back of the HD cable box. The light doesn't go on on the power button. The TV makes no sound like it used to - light electronic buzz while it warmed up, etc. I can't tell if the equipment is hooked back up correctly, because it literally seems like it has no power running to it. (Yes, I did check that the outlets, etc. work and no breakers are tripped.) Please help. Divorce, can't afford a repair rep! It's a house call, obviously |
New member Username: Warlock62301lock62301
Post Number: 5 Registered: Aug-08
| Posted on Sunday, August 17, 2008 - 04:51 am: |
Have you tried to take a small nail or a pin and push in the reset button on the front panel that should fix your problum also check all the connections |
