Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > Setting dish
Author Thread: Setting dish
Username: Sssmith
Post Number: 8
how should i get the right angle for the international channel. i am using sattelite finder but it's allway goes on.
please help.
thank you
Username: Popol_vuh
Post Number: 64
A common newbie mistake with an analog sat finder is to boost the sensitivity too much. It will then appear as if the alignment is OK while it's not. Once you get a signal reduce nthe sensitivity until the beep/meter goes down then readjust your dish for max signal. Reduce it again and you should get the best alignment.
Hope I'm clear enough and that it helps. Good Luck!
Username: Mucho
Post Number: 487
smith
What type of sattelite finder are you using?
Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > Setting dish [ « Previous ] [ Next » ]
