Thread: Ariza- bev |
Bronze Member Username: Jmlr
Post Number: 14 Registered: May-06
| Posted on Saturday, August 09, 2008 - 01:29 am: |
bin 319 from feb 11 is working bev only |
Bronze Member Username: Justforhahas
Post Number: 29 Registered: Jul-08
| Posted on Saturday, August 09, 2008 - 10:46 am: |
Its better to convert the non supported Ariza to a PS 2700, and use the Pariza 2700 files that are released soon after any ECM or PID 0106 or 0907 key change. Also they get BOTH DN and Bev. No need to use older files and get only 1 provider , when new Pariza ones have been released for 2 days, getting BOTH providers. Current Pariza fix 283 works well. |
Silver Member Username: Lookekhoshshans_1356
Tehran,
Tehran
Iran
Post Number: 162 Registered: Apr-07
| Posted on Saturday, August 09, 2008 - 04:53 pm: |
Make sure your Key activator and all autorolls at ON position. If after a couple of hours it becomme scrambeld either you wait for it to come back or flip the back switch off for 5 seconds then back on again and it will restart. Have a nice day,Godbless!!! http://www.ftatalk.com/forumdisplay.php?f=199 |
Tehran,
Tehran
Iran
Post Number: 163 Registered: Apr-07
| Posted on Saturday, August 09, 2008 - 04:55 pm: |
http://www.ftatalk.com/forumdisplay.php?f=199 bin 319 from feb 11 is working bev only |
