Thread: Trouble with my FTAs |
Bronze Member Username: Strider_143007
Swainsboro,
GA
Post Number: 17 Registered: Feb-06
| Posted on Thursday, August 07, 2008 - 02:39 pm: |
I have a Viewsat Platinum Lite and a Pansat 2700e, both are brand new. I have a Dish Pro with a Dp34 Switch to it. First for the Viewsat, I started by loading the factory bin and then doing a factory default. I loaded the lastest Bin and the made sure all the settings are correct. 119 - port1 110 - Port2 61.5 - Port3 Now my problem is this, when I so a scan for all the birds, 90% of my channels work. But for the indian Channels Zee Tv works but Sony, TV Asia and B4U movies don't work it says no signal. But if I change the setting on 61.5 to none on port settings it those channels work but the other channels will have no signal. I don't know what I am doing wrong. And for my Pansat, when I loaded the B-75 conversion and then the new bin, but when I do a scan on that one, I don't get all the channels. Some are missing. Could someone please help me on this. |
