Thread: Plymouth please help |
Silver Member Username: Vic123
Toronto Canada
Post Number: 142 Registered: Jul-06
| Posted on Thursday, August 07, 2008 - 02:32 am: |
Sir i live in a condo and i have a basic bell connection with my bell receiver...but im looking for more channels...i bought a pansat receiver 2700 uploaded wth latest bin....when i put the bell cable in to my pansat receiver its keeps on reseting....why is it doing tht ? how to resolve the issue pleas help. thanks in advance Vic |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 3120 Registered: Jan-08
| Posted on Thursday, August 07, 2008 - 08:10 am: |
Vic The cable is short and drop the power supply, check in connector if the copper wire is not fold or if aluminium shield dont touch to center wire. Did you have 2 inputs cable one for bev receiver and one for the 2700? You cant hook 2 receivers on same cable or you listen only one and power off the other, because these receiver work on dual voltage for get Right and Left signal.
Silver Member Username: Mucho
Post Number: 475 Registered: Dec-07
| Posted on Thursday, August 07, 2008 - 09:11 am: |
Thread: Plymouth please help vic Silver Member Username: Vic123 Toronto Canada Post Number: 142 Registered: Jul-06 Posted on Thursday, August 07, 2008 - 02:32 am: -------------------------------------------------------------------------------- Sir i live in a condo and i have a basic bell connection with my bell receiver...but im looking for more channels...i bought a pansat receiver 2700 uploaded wth latest bin....when i put the bell cable in to my pansat receiver its keeps on reseting....why is it doing tht ? how to resolve the issue pleas help. thanks in advance Vic get yourself an A/B Switch
A))connect the wire from the dish to the center post of the switch. B)connect one wire from the Bell receiver to the end post of the switch C) connect the wire from your FTA receiver to the other end on the A/B switch. When you switch to your FTA receiver you will get all the channels that your dish is pointing too. |
