Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > Why so many ppv on eco 61.5
Author Thread: Why so many ppv on eco 61.5
Username: Adave
Post Number: 189
just scan the 61.5 i got 15 ppv what's going on i have sv 8000hd. any clue.
Username: Adave
Post Number: 190
no picture or audio any information pls update
thax
Username: Thoronto
Post Number: 52
61.5 does not have that many ppv, you probably scanned the wrong bird. Check the ports, sometimes you are on the right sat configuration but on the wrong port and scanning a different bird.
Username: Laxey34
Miami, FL
United States
Post Number: 37
Dish up load these channels yestreday to 61.5W
502 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
505 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
507 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
510 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
512 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
513 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
516 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
518 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
521 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
524 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
525 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
526 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
527 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
530 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
531 - HDPPV [MPEG4 HD] added to Echostar6 72.7W TP 17 ConUS beam (A)
532 - PPV [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
534 - HDPPV [MPEG4 HD] added to Echostar6 72.7W TP 17 ConUS beam (A)
538 - $1.99 [MPEG4 SD] added to Echostar12 61.5W TP 23 ConUS beam (NA)
539 - HDPPV [MPEG4 HD] added to Echostar6 72.7W TP 17 ConUS beam (NA)
Username: Adave
Post Number: 191
just added same channel from 110 119. nothing new what about 1080p on dish u heard any thing
thax
Username: Malik500
I have viewsat hd 9000 and I have echo3 61.5 bird, yesterday when i rescanned I got new 17 hd channels with no video for example channels numbers 502,505,507,510,512,513,516,518,521,524,525,527 etc.
I have all in one 8psk card installed.
below is the setting on TP it got scanned with no video.
[B]TP:12545 S/R:20000 Pol:V FEC:5/6 MOD:DVB[/B].
I tried to change it to
[B]TP:12545 S/R:21500 Pol:V FEC:2/3 MOD:TURBO8[/B].
but still no video.
I know hd 9000 supports 1080i and 720p, and these channels are comming in 1080p.
My question is, Does it still possible to get these channels in 1080i with some settings as I tried to do above or will there be new bin comming with this support?
Does any body testing this?
Username: Plymouth
Quebec city, Quebec
Post Number: 3157
Guy these channels are on N3
Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > Why so many ppv on eco 61.5 [ « Previous ] [ Next » ]
