Thread: How do I set-up Winegrad 31" dish with the s2100 motor |
Bronze Member Username: Viewsat_ultra
Post Number: 47 Registered: Nov-07
| Posted on Tuesday, August 05, 2008 - 09:53 pm: |
Hi, I'm currently using my dn equipment with my VS ultra. I would like to use my Winegrad 31" dish with the s2100 motor, But I can't find anyone in Fort Lauderdale FL to aim it. I have the Winegrad 31" dish with the s2100 motor mounted next to my DN, if I adjust the elevation and skew to the same settings as the 500 will that point me in the right direction or are these settings different for this type of dish? I believe the LNB in Invacom but I'm not sure. After I get this dish pointed properly what are the settings that should be used? (i.e. LNB type Freq...) Thanks |
Post Number: 48 Registered: Nov-07
| Posted on Tuesday, August 05, 2008 - 10:06 pm: |
B.T.W. I believe that I have Invacom QPH-031 lnb. |
Post Number: 51 Registered: Nov-07
| Posted on Tuesday, August 05, 2008 - 10:43 pm: |
Is there any reason to load keys manually ? |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 3091 Registered: Jan-08
| Posted on Tuesday, August 05, 2008 - 10:49 pm: |
Rob you must be a very good tuner for aligned a motorized dish, but i can try to help you. I have Vs Ultra with 33" motorized dish and a Invacom QPH-031 Universal linear/circular LNB |
Quebec city,
Quebec
Post Number: 3093 Registered: Jan-08
| Posted on Tuesday, August 05, 2008 - 11:08 pm: |
No need to load keys manually, autoroll do this work for you. |
