Thread: Bin files on macs???? |
Bronze Member Username: Chilli
Post Number: 97 Registered: Jan-07
| Posted on Tuesday, August 05, 2008 - 09:43 pm: |
Is it possible to download files using a mac and how do you go about doig it????? |
Gold Member Username: Asharfi
Post Number: 2071 Registered: Aug-06
| Posted on Tuesday, August 05, 2008 - 10:12 pm: |
Well, if you have some kind of USB Flash Drive, then it's possible. But, if you are talking about running a loader and loading a bin file using that, then it's not possible because I do not think that MAC computers can run .EXE programs. But there are some programs, designed for MACs that you can use to open those .EXE programs. Search GOOGLE for more help. |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 3094 Registered: Jan-08
| Posted on Tuesday, August 05, 2008 - 11:09 pm: |
babies12 Yes you can run the program on new MAC not old |
