Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > How Do I Transfer Satellite and Chann...
Author Thread: How Do I Transfer Satellite and Channel Info??
Username: Anonymouse
Post Number: 15
Hey guys,
I have 2 Viewsat Ultras. I wanted to take the Satellite and Channel information from one and transfer it to the other. Is there any way to do that using the USB ??
I know I did it once before, but I completely forgot how.
Any help is much appreciated.
Username: Saqeeb9000
Post Number: 3622
i don't know about viewsat ultra, but i can tell u about kbox.. (should be similar).
if u go to menu and find tranfer data, or usb etc..
and it will say transfer channel data to usb, (this option will come up after u enter ur usb)..
and then save it (u can rename it , whatever u wanna call it)..
and then go to other viewsat ultra and now this time plug in usb and move the right arrow until u see save channel data..
and u can save it that way.. i think it should be similar to viewsat ultra..
Username: Plymouth
Quebec city, Quebec
Post Number: 3069
Anony Mouse and Sada
On Viewsat Ultra we cannot transfert data to USB but on Serial port thats possible.
Anony go to http://www.viewsatusa.com/support.htm and download "General Satellite Info File (compatible with Platinum, Lite, Xtreme, Ultra only !)
Unzip it and load it in receiver.
If you think you miss some channel, just do a blind scan on sats and all TPs coming
Post Number: 3625
oh i thought viewsat ultra had slot for usb...
if they do then why the heck manafactures didn't add this option......
Username: Plymouth
Quebec city, Quebec
Post Number: 3072
Sada
I dont know why, but support on Viewsat is very good and its very rare we need to do a manual TP search.
But i agree with you that can be considered.
We are only User not Fabricant.
Username: Plymouth
Quebec city, Quebec
Post Number: 3073
Thanks Tooter but thats not work on USB and you need to unhook one receiver.
Username: Plymouth
Quebec city, Quebec
Post Number: 3074
Tooter post is disappeared
I think he read the first Anony post.
Username: Dimwitt
Post Number: 828
Flymoth you should disappear-
Username: Plymouth
Quebec city, Quebec
Post Number: 3079
Big tooth should disappear too
Post Number: 16
Thanks guys for all the help.
Just decided to do everything manually.
I know I transfered the channels and satellites to a USB before. Just don't remember how.
Maybe it was a programming glitch that let me do it, but I remember going to "Receiver Upgrade" and hitting the "F" keys to load channel and satellite data onto my USB. Not working now though. Strange.
Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > How Do I Transfer Satellite and Chann... [ « Previous ] [ Next » ]
