Thread: PUFF installation issue |
Silver Member Username: Imnycusa
Post Number: 139 Registered: Jun-06
| Posted on Sunday, August 03, 2008 - 12:25 pm: |
I have problems installing new 282 PUFF bin. Nothing happens when loader tries to load the bin. I had the same issue with the last PUFF 279. However, i was able to resolve it by installing boot60, bin294 and then new PUFF. But now I even can’t even do that. The receiver does not respond to loaders. When the receiver is on, CS loader is unable to load bin 60. Any suggestions? |
Platinum Member Username: Nydas
Post Number: 11299 Registered: Jun-06
| Posted on Sunday, August 03, 2008 - 04:23 pm: |
"When the receiver is on, CS loader is unable to load bin 60. Any suggestions?" This is pretty serious. Try to FORCE the b60 BOOT using CS revert to 2500 loader and/or BL Updater 1.4. The forcing is done by switching ON and clicking immediately or clicking and switching on immediately. You may have to try several times. |
Post Number: 140 Registered: Jun-06
| Posted on Sunday, August 03, 2008 - 11:09 pm: |
Thanks buddy, i'll try this. hope this works. |
Post Number: 141 Registered: Jun-06
| Posted on Tuesday, August 05, 2008 - 10:16 am: |
None of this worked. However, when I hooked up the receiver to the serial port of my old and obsolete computer, there was no problem to install new PUFF. It appears to be that USB to Serial arrangement on my latest laptop stopped working. |
Post Number: 11322 Registered: Jun-06
| Posted on Tuesday, August 05, 2008 - 05:06 pm: |
If you have done some new software installations on your computer, you may have inadvertently changed the port settings. Worth going into your computer's device manage and check the settings for your USB to serial controller. |
Silver Member Username: Rekman
Mntl-Quebec-...
Post Number: 398 Registered: Jun-06
| Posted on Tuesday, August 05, 2008 - 06:33 pm: |
Hi Nalin. PLEASE advice me which receiver should I buy. Bcoz my cools*T 5000 has always been the LAAAAAAASSSSSSSSTTT to release Bin. advice me please. thanks |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 3076 Registered: Jan-08
| Posted on Tuesday, August 05, 2008 - 06:55 pm: |
Salut my friend MKM, how are you? You can buy a new model Viewsat Ultra LITE or Standard Ultra or a CaptiveWorks 650S or 700S best support since 8 months, easy to found in Montreal |
Mntl-Quebec-...
Post Number: 399 Registered: Jun-06
| Posted on Tuesday, August 05, 2008 - 10:18 pm: |
Yes my friend PLYMOUTH. I have a friend who has CAPTIVE WORK. my god!!!! his receiver is alwaysssss... ON.. Thanks plymouth me too was thinking abou CAPTIVE ...BUT wanted advice from reliable friend like You...... |
Quebec city,
Quebec
Post Number: 3089 Registered: Jan-08
| Posted on Tuesday, August 05, 2008 - 10:34 pm: |
I have CW600S premium but i prefer my Viewsat Ultra which have better interface and better support. I vote for viewsat Ultra and Captiveworks 700S in second |
Post Number: 11323 Registered: Jun-06
| Posted on Wednesday, August 06, 2008 - 09:11 am: |
My views are more or less the same as Plymouth's |
