Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > Viewsat extreme 2000
Author Thread: Viewsat extreme 2000
Username: Jen_123
Toronto, ON
Post Number: 19
Hi,
Just got a Viewsat extreme 2000 and I have no idea where to find the loader and the files.Tried searching,but no success.I have no experience with this receivver at all.
Please help.
Jenna
Username: Tapeman
New York City in-HD, NY
Post Number: 3118
Yo can find loader-2 and latest bin on:
www.ftabins.com
But the fastest realease of new bins on ftahq.com
Username: Tapeman
Post Number: 3119
ftabins.net yo must sign up to be able to load anything
If yo don't want to sign up
yo can go to dsscentral..net to get loader2
Then go to ftahq.com and get latest bin
bin for Xtreme is
DBPSW-080730X.zip
Always ends with-X
Don't forget to unzip it
Username: Jen_123
Toronto, ON
Post Number: 20
Thanks - I went to the first one and got lost.lol
The second link gives me several files, but I am not sure which one I need. And I don't see a loader either.
I guess I am very new at this....
Jenna
These are the files on the second website:
Filename Size in Bytes Last Modified
PFTAUSW-080730U.zip 1.273.043 31.Jul.2008 ·
PVRSW-080731A-II.zip 1.250.237 31.Jul.2008 ·
VSPRO-080731A-II.zip 1.551.762 31.Jul.2008 ·
DBPSW-080730P.zip 978.645 31.Jul.2008 ·
PFTAHDSW-080730H.zip 3.545.414 31.Jul.2008 ·
PFTAHDSW-080730H_NewGUI.zip 3.542.452 31.Jul.2008 ·
VSPRO-080731A.zip 1.624.816 31.Jul.2008 ·
PFTAUSW-080730UL.zip 1.688.591 31.Jul.2008 ·
DBPSW-080730X.zip 972.411 31.Jul.2008 ·
Username: Tapeman
Post Number: 3121
Loader2 is the 3rd file on this site:
http://www.dsscentral.us/cgi-bin/fileshare/fileshare.cgi?command=viewupload&data base=viewsat%2edb
Latest File for Xtreme is: DBPSW-080730X.zip
Last file on ftahq.com
Username: Plymouth
Quebec city, Quebec
Post Number: 3015
Jenna
You can find loader on:
http://viewsatusa.com/support.htm
Username: Tapeman
Post Number: 3122
That's loader-1
She'll need loader-2
Username: Jen_123
Toronto, ON
Post Number: 21
Thank you King. :-) I got both the loader2 and the file.After I unzip them and connect the Viewsat and the laptop with the cable do I just follow the instructions from the loader?
Anything I should know before loading this bin?
Thanks
Jenna
Username: Tapeman
Post Number: 3123
This is the direct link to get both from FTABINS.NET
http://ftabins.net/forumdisplay.php?f=115
However yo must sign up as a registered member
The 2 links I gave yo above yo don't have to signup anywhere
Username: Plymouth
Quebec city, Quebec
Post Number: 3016
In your package box with receiver is furnish a cable RS-232 you must download bin with the cable from your computer .
Go to: <http://viewsatusa.com/support.htm>
download and unzip this file:
Loader 1 - Firmware Updater (Plat and Xtreme)you install this one on computer
Download and unzip bin from ftahq.com
close rear switch on receiver
open program take file bin
clic to download in receiver and a second after
switch on
the transfert take 5-10 mins
you must see 0000
Good luck
Username: Tapeman
Post Number: 3124
Procedure:
- Yo need a 9 pin Null cable which usually comes with receiver
- Receiver must be off from back switch
- Open Loader2 in yor Laptop
- Select latest unzipped bin
- Select PC to STB
- Turn on reciver
- It will start loading and updating
- get a cup of coffee while it's loading let it complete its entire PGM
That's it
Username: Plymouth
Quebec city, Quebec
Post Number: 3017
King
Loader 1 on viewsatusa is same as Loader 2 from dsscentral
Username: Jen_123
Toronto, ON
Post Number: 22
You guys are the best :-) I will have to go and find a cable now, since the receiver was given to me without a cable.
Jenna
Username: Tapeman
Post Number: 3125
I never tried loader-1
Have yo tried loader-1?
I don't think they are the same
I can try it only if yo do first
As far as I know it supposed to have a slight modification
Everywhere it's posted Loader2 is what's required
Username: Plymouth
Quebec city, Quebec
Post Number: 3018
King i tried it for recover a friend died receiver and it work fine
Username: Jen_123
Toronto, ON
Post Number: 23
I found a 9 pin null cable, but my laptop has only the male connector same as the receiver.It has another female connector but not 9 pin one.I wonder if I can use 9 pin male to male cable or maybe have to find a special cable.
Jenna
Username: Plymouth
Quebec city, Quebec
Post Number: 3022
Jen
Your cable need to have 2 female connector.
The female connector on laptop is VGA monitor out.
I think you can buy it at RadioShack or any satellite seller
Username: Tapeman
Post Number: 3126
Try e-bay
Type null cable
It should be #3 to $5
F/F cable is what yo need
Yo should ask whoever sold it to yo why couldn't supply cable that usually comes with
And make sure it's not a VU-sat clone
Username: Jen_123
Toronto, ON
Post Number: 24
Ok guys I got the cable /female to female/ Selected port 1 on the loader app and started to load the file /turned the receiver on/ The % stays 0 for the last 10 min.No change....
I tried the other ports - port 2 and 3 - same thing....Is it just slow or am I doing something wrong? Please advise.
Thanks
Jenna
Username: Plymouth
Quebec city, Quebec
Post Number: 3032
Jen
Try it: Power off on back panel, push and hold front power and power on on back panel, release front power button and load the factory bin with loader1 from Viewsat
Username: Jen_123
Toronto, ON
Post Number: 25
Tried Plym, It doesn't work.
What port should I be selecting?
Jenna
Username: Plymouth
Quebec city, Quebec
Post Number: 3033
Uninstall all loader and reboot laptop and install loader 1 from viesat and select port1
If you have loader from another trade receiver uninstall it too
Username: Gregraf
Post Number: 998
Her laptop probably wont do it. Mine won't. My inlaws will but theres is better.
Username: Plymouth
Quebec city, Quebec
Post Number: 3035
Greg
i have 2 laptop and it work on 2
But if i install 2 different loader sometime i need to uninstal 1 of 2, because port1 is assigned by another program.
Jenna it work now?
Username: Doreenakadj
Ontario
Post Number: 1737
Jenna you may need to use a USB cable along with your RS-232 cable ... try all ports, usualy port 3 ( on my laptop ) anyway... if you want me to send you a video on how to use the VS loader PM me and I will send you info and files etc...
Username: Plymouth
Quebec city, Quebec
Post Number: 3036
Doreen
Why dont use Ecoustic Forum and give to all members your info.
Jenna laptop is equiped of a serial out, i dont see why she will not use this one.
Use USB port to serial need to use a program for nothing.
Thanks
Username: Polachelliot
Eddyville, KY
United States
If anyone were to be looking to buy a Viewsat or other FTA Receiver in US or Canada they should go to www.extremefta.com I do not work for t hem and I am not getting any prize for them for posting this but I ordered a Extreme from them and let me just tell you: Words cannot describe how pleasent and nice they are to work with. Noone I have EVER bought anything from, including in the local supermarket, was that nice. I sent a money order and I called about twice to three times wondering if it got there yet or not. The man on the line says "You can call every day if that makes you feel better" in a kind voice. "It will be there before you know it". I love this company and urge anyone to buy from it.
Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > Viewsat extreme 2000 [ « Previous ] [ Next » ]
