Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > Signal 75% but no quality & no indian...
Author Thread: Signal 75% but no quality & no indian channels
Username: Pal33
hi guys,
i have vs2000 ultra i have only dish 61.5 connected with it but i get nothing, my dish is few years old now & i have big tree in front of it
please suggest something
thx
paul
Username: Gregraf
Post Number: 992
Hmm geez is this like a trick question.
Username: Gregraf
Post Number: 993
I think if you pick every other leaf off the tree you can watch satellite and save the tree.
Username: Pal33
Post Number: 7
hey greg be serious please help - thx
Username: Plymouth
Quebec city, Quebec
Post Number: 3006
Paul
If you have three between dish an satellite you need to cut the head of three or relocated the dish.
In summer the leafs grow and you lost signal.
On Viewsat Ultra you need to have 70/100 signal for get sattelite.
Buy a cheap sat finder for realigned your dish.
I hope that help you
Note Greg like doing jokes
Paul name is use by another member here replace it for Pal(suggest)
Username: Pal33
Post Number: 8
thx plymouth, i will try to relocate the dish, it's neighbor's tree.
thx
Username: Pal33
Post Number: 9
pls anyone, can i have direct connect from LNB to reciever or i do need switch - thx
Username: Plymouth
Quebec city, Quebec
Post Number: 3009
Pal (Paul)
Good move for the name
If you have only one LNB no need switch, for more you need a switch.
On satellite setup you select the port which you connect on the Diseq switch.
For your dish if it is on the roof you can buy a 10' Mat and replaced the 4' Tripod, if it is on the Wall install it on the Roof.
Username: Pal33
Post Number: 10
dish is on the roof but why q is 0 - thx
Username: Plymouth
Quebec city, Quebec
Post Number: 3011
Pal
You need to have a clear signal for Quality
You may have signal if you aimed the ground by reflexion but no Quality.
Signal is not a reference but the Quality for get sats.
Username: Plymouth
Quebec city, Quebec
Post Number: 3013
Pal
Try to do a factory default and rescan sat
Try bin on ftahq.com out today
Dont take file for Ultra Lite(UL)but (U)
Username: Pal33
Post Number: 11
plymouth,
i tried factory & rescan but didn't work - thx
Username: Nydas
Post Number: 11266
Also see:
http://forum.ecoustics.com/bbs/messages/2/505707.html
Username: Plymouth
Quebec city, Quebec
Post Number: 3014
Pal
Your problem com from three between dish and sat or your dish turn with strong wind
Username: Nadxia
Dayton, OH
Post Number: 24
Nalin , please help. I have Pansat2700A I downloaded new bin file 282 but still no Indian Channels.I tried everything that I know but still No Indian Channels.
Please Help!!!!!!!!!!!!!!!!
Username: Nydas
Post Number: 11316
The latest 2700 BINs have two sets of DiseqC switch settings.
1.0 - port 1,2,3,and 4
1.1 - port 1,2,3,4,5,6,7
Supposing you were using switch port 3 for Indian channels try 1.0 - port 3 or 1.1 - port 3.
One of these should work.
Username: Nadxia
Dayton, OH
Post Number: 25
Nalin,U R Great!!!!!!! it worked 1.0 port 3 worked thanks alot...
Username: Nadxia
Dayton, OH
Post Number: 27
Nalin, Where I can find ABN the sports channel??Please help
Username: Nydas
Post Number: 11320
I do not know where you can find ABN sports.
Username: Plymouth
Quebec city, Quebec
Post Number: 3065
Nadeem
I do some research on ABN and it's a preach channel nothing to do with Sport.
Username: Pal33
Post Number: 13
thanks everyone,
i moved my dish now eveything is fine
thx again
pal
Username: Plymouth
Quebec city, Quebec
Post Number: 3098
Good news Pal
Enjoy
Username: Sameeralam
Post Number: 21
B4U Movies is still up for you to enjoy.
http://desichannels.awardspace.com
100% working.
Check out other channels if you like too.
Username: Mucho
Post Number: 472
Nadeem
ABN African Broadcasting Network America
Sports from African
http://www.abnamerica.com/
Echo 9 @ 121.o*W
(tp18)Freq. 11972 H channel 749
Home > Message Board > Home Video > Satellite TV > Archive through August 12, 2008 > Signal 75% but no quality & no indian... [ « Previous ] [ Next » ]
