Thread: Anyone ever see one of these |
Silver Member Username: Bill984
Post Number: 276 Registered: Oct-05
| Posted on Monday, July 14, 2008 - 08:04 pm: |
http://www.startech.com/item-applications/CPNTA2HDMI-Component-Video-and-Audio-t o-HDMI-Converter.aspx if so, would it work on a cable tv signal from the wall? |
Gold Member Username: Samijubal
Post Number: 3881 Registered: Jul-04
| Posted on Monday, July 14, 2008 - 08:42 pm: |
That's made for component inputs, it won't work with coax. |
Post Number: 278 Registered: Oct-05
| Posted on Tuesday, July 15, 2008 - 07:08 am: |
""Connect your YPbPr/YCbCr source to an HDMI display. Great for use with HDTV's (LCD/PLASMA/DLP). • Connect standard and high definition devices to an HDTV through and HDMI port. "" THEN WHY IS THERE A COAX IN ADND A HDMI OUT? YPbPr/YCbCr is for both component and digital (hdmi) right? |
Post Number: 3882 Registered: Jul-04
| Posted on Tuesday, July 15, 2008 - 02:10 pm: |
The coax in is for digital audio the components for video. |
Bronze Member Username: Levelzero
Post Number: 48 Registered: Aug-07
| Posted on Tuesday, July 15, 2008 - 05:06 pm: |
I see what Bill was thinking. The Coax In line looks like a port for the cable line. However, if you take a closer look the silver connector is smooth, and doesn't have the rigid lines to screw the cable line onto. |
