Thread: Viewsat weird situation need ur help |
Bronze Member Username: Chris7777
Post Number: 97 Registered: May-06
| Posted on Wednesday, June 18, 2008 - 11:32 am: |
ok so ive got 1 satellite outside and im running a viewsat lite cause im cheap as fu*k ...when bell went out last night i moved my dish over to dn and tried to scan channels ...it locked on to the transponders but did not download any channels ....so i thought no problem went and found a channel list and downloaded it think it should be all good cause the signal and quality were both there but no luck all it says it no audio or video ...i moved it back to bell and all was working fine this morning ..this also happened to my buddy who is running the same setup ..any 1 got any soloutions ???as to why this is happening or what i can do to fix it ??? |
Relevant Product Info
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 2635 Registered: Jan-08
| Posted on Wednesday, June 18, 2008 - 11:57 am: |
Which satellite you want scan? |
Post Number: 98 Registered: May-06
| Posted on Wednesday, June 18, 2008 - 12:10 pm: |
was trying to get echo 8 ,10 no dice though happening just as mentioned above for now 3 of us |
Post Number: 99 Registered: May-06
| Posted on Wednesday, June 18, 2008 - 12:11 pm: |
2 more post till silver |
Post Number: 100 Registered: May-06
| Posted on Wednesday, June 18, 2008 - 12:12 pm: |
only took me 2 years but im here now anyway i still need help |
Quebec city,
Quebec
Post Number: 2637 Registered: Jan-08
Which city? Which dish size? |
Silver Member Username: Chris7777
Post Number: 101 Registered: May-06
| Posted on Wednesday, June 18, 2008 - 01:11 pm: |
im in ontario canada we use a regular 18 inch dish my buddy has a 33 inch dish ...thats not the problem we find the signal no problem as you realy only need to move it six inches right and left to pick up the signals ....the quality is there too its locking on to the trtansponders and stays locked likes its downloading channels but when its done scanning there are no channels ..like i said i used channel master to input lists but it came up as no audio no video ..i also tried installing the factory file and downloading the latest file but still no luck ive never seen this before im just wondering if dn changed it transponders ??? or are up to any other kind of bs ???? |
Bronze Member Username: Kingofbeers
Post Number: 26 Registered: Sep-07
| Posted on Wednesday, June 18, 2008 - 01:51 pm: |
did you hit the sat button on your remote and pick the right one |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 2868 Registered: Oct-06
| Posted on Wednesday, June 18, 2008 - 02:05 pm: |
Look chris Yor problem is so simple: - Write down yor antenna setup - Do factory default - Select yor new desired sat - Do auto Scan one sat at a time - Do not do blind scan - I repeat do not do blind scan These symptoms are nothing but back engineered by nagra against VU-Sat receivers in general they got dead TP that actually shuts down signal Do what I told yo up there Yo'll be up and runing in few seconds No need to reload bin Come back and tell me how it worked Just stay away from Jimmy the retard He's got no clue about FTA |
Silver Member Username: Themangod
Post Number: 467 Registered: Oct-06
| Posted on Wednesday, June 18, 2008 - 02:27 pm: |
this happens to me on the ultra it does not always keep the right keys for both dish and bev. unplug your receiver from the wall for a few mins then back in on dish and let it try to find the keys for a while it will do it. but i have had the same problem switching from one to the other in the cheap way like that. |
Quebec city,
Quebec
Post Number: 2639 Registered: Jan-08
| Posted on Wednesday, June 18, 2008 - 02:41 pm: |
try it: All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote "NEW" do same thing with all provider on Bev provider 09 07 00 09 06 00 09 05 00 09 01 00 08 01 00 no need to delete keys load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll, freeze and search signal "Dont load factory bin" Thats erase bad data in the box For box who lost channel and sat setup ENJOY TV TESTED and work fine New issue for problem on Viewsat Thanks Reply if it work Please |
NY
Post Number: 2870 Registered: Oct-06
| Posted on Wednesday, June 18, 2008 - 03:05 pm: |
Kate those are different issues with keys The specific problem with Chris is Blind Scan issue There are some TPs as yo blind scan it kills Q signal on many VU-Sat receivers |
Quebec city,
Quebec
Post Number: 2640 Registered: Jan-08
| Posted on Wednesday, June 18, 2008 - 05:20 pm: |
King i dont have any problem since i have deleted provider in keys menu, my VS work very fine, autoroll do what it supposed to do.Never i lost signal or channels. Kate you can try it too. |
Quebec city,
Quebec
Post Number: 2642 Registered: Jan-08
| Posted on Wednesday, June 18, 2008 - 05:25 pm: |
King Blind scan work fine for me |
Silver Member Username: Kingsatman
James McPhuck
Post Number: 356 Registered: Nov-07
| Posted on Wednesday, June 18, 2008 - 08:44 pm: |
My VS works fine without deleting provider The provider code section is nothing but a manual data hex-key input Nagra was morphing (changing) keys virtually which may have caused strange behaviour or bugs Newer bins eliminated all those bugs But yo gonna have to trust me on this Most VS receivers as yo do blind scan they pickup some test channels created by DN/Nagra As yo scan them they shut Q signal Yo wanna believe me that's fine Yo don't many others disagreed with me Nagra tried so hard to make FTA receivers don't detect signal I have been noticing that for more than a year |
Quebec city,
Quebec
Post Number: 2646 Registered: Jan-08
| Posted on Wednesday, June 18, 2008 - 11:19 pm: |
King i do it manytime and no need to factory default or rescan all sats, that take only two minutes and it clear Ram. I experiment many problem on viewsat receiver in past with time delay bog. Now, never i load factory bin, which i think it was corrupted. I use it only for Night rider. You can try it, you have nothing to lose. Thanks
Post Number: 102 Registered: May-06
| Posted on Friday, June 20, 2008 - 02:16 am: |
none of these have worked any 1 got any other ideas ??? |
Quebec city,
Quebec
Post Number: 2662 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 07:03 am: |
Try bin from ftahq.com |
Silver Member Username: Mucho
Post Number: 342 Registered: Dec-07
| Posted on Friday, June 20, 2008 - 10:09 am: |
I have tried all the types of Scans many times.Never had a problem with Power or Blind Scan. Sometimes Satellite or Auto Scan would not pickup all the TPs. In my experience , Blind Scan is the way to go. |
Quebec city,
Quebec
Post Number: 2666 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 11:32 am: |
White Hawk Youre right, when Provider change Tp that recreated new one and thats stay stored in Satellites config. |
NY
Post Number: 2880 Registered: Oct-06
| Posted on Friday, June 20, 2008 - 12:02 pm: |
Blind scan vary from one receiver to another Blind scan can be also different in scan patterns based on number of manual TP edited Blind scan can sensor TP different based on Internal clock frequency and LNB preset selection Blind scan can pick and update various symbol rates based on frequency spacing selection for example if set to 5, 6, ... 12 There are so many variables involved in choosing blind scan To me blind scan is the only option if yo don't know what yor picking |
Silver Member Username: King_of_sats
Post Number: 378 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 01:08 pm: |
I CHALLENGE YOU FAKEMAN TO PRODUCE A STREAM DUMB PROVING YOU DUMBAZZ RANTS ONCE AND FOR ALL PROVE IT... YOU SAY SAME STUPID CHIT OVER AND OVER BUT CAN'T PROVE IT YOU HAVE NO FACTUAL DATA TO BACK UP YOUR LUNTICIAN CLAIMS POST A LINK FROM ANY SITE PROVING IT YOU SO FULL OF CHIT YOU DAMN LOSER NAGRA HAS NO CONTROL OVER STREAM... I CAN PROVE YOU WRONG IT'S SIMPLE !!!! FACT IS!!!!!! YOU CAN SCAN IN ALL ECHO'S WITH A FACTORY BIN!!!!!!!!!! BUILD A COMPLETE CHANNEL LIST... YOU CAN'T VIEW THEM BECAUSE OF THE ENCRYPTION OF THE VIDEO AND AUDIO BUT YOU WILL HAVE A SIGNAL ON ALL CHANNEL..... FACT!!!!!!!!!!!! FAKEMAN YOUR A LOOOOOOOOOOOOSER!!!! YOU KNOW NOTHING ABOUT STREAM OR HOW THE ENCRYPTION WORKS... YOU JUST A LITTLE BIN GOBBLER WANNABEEE TEST..
NY
Post Number: 2882 Registered: Oct-06
| Posted on Friday, June 20, 2008 - 01:17 pm: |
I provide proofs to people with brains Retards like yo are excluded Consider yorself ignored Sukka  |
Post Number: 379 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 01:21 pm: |
Post Number: 380 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 01:22 pm: |
PUT UP OR SHUT UP EVERYONE IS WAITING PUT UP OR SHUT UP EVERYONE IS WAITING PUT UP OR SHUT UP EVERYONE IS WAITING PUT UP OR SHUT UP EVERYONE IS WAITING PUT UP OR SHUT UP EVERYONE IS WAITING PUT UP OR SHUT UP EVERYONE IS WAITING PUT UP OR SHUT UP EVERYONE IS WAITING PUT UP OR SHUT UP EVERYONE IS WAITING
Post Number: 381 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 01:24 pm: |
JUST LIKE YOUR CLAIMS HERE !!!
FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER FAKEMAN IS A LOOOOOOOOOOOOOOOOOOOOOOSER |
Post Number: 382 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 01:26 pm: |
Post Number: 383 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 01:30 pm: |
GO DEGAUSS A EPROM LMFAO
YOU HAVE NO CLUESS GO MOP A FLOOR King RETARD degauss  |
Post Number: 104 Registered: May-06
| Posted on Friday, June 20, 2008 - 01:51 pm: |
dam why you guys have to hijack my thread for your personal issues with each other ...help me first then continue |
NY
Post Number: 2884 Registered: Oct-06
| Posted on Friday, June 20, 2008 - 04:51 pm: |
My apology Jimmy the T.F.R. (Total Freaking Retard) Hijacks all threads not just yors He's a senior member here hates all satellite members So on behalf of his missing brain please accept my apology I usually ignore his non-sense Pictionary So I encourage all satellite members to simply do the same and ignore eventually he'll give up |
Post Number: 384 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 05:15 pm: |
I CHALLENGE YOU FAKEMAN TO PRODUCE A STREAM DUMB PROVING YOU DUMBAZZ RANTS ONCE AND FOR ALL PROVE IT... YOU SAY SAME STUPID CHIT OVER AND OVER BUT CAN'T PROVE IT YOU HAVE NO FACTUAL DATA TO BACK UP YOUR LUNTICIAN CLAIMS POST A LINK FROM ANY SITE PROVING IT YOU SO FULL OF CHIT YOU DAMN LOSER NAGRA HAS NO CONTROL OVER STREAM... I CAN PROVE YOU WRONG IT'S SIMPLE !!!! FACT IS!!!!!! YOU CAN SCAN IN ALL ECHO'S WITH A FACTORY BIN!!!!!!!!!! BUILD A COMPLETE CHANNEL LIST... YOU CAN'T VIEW THEM BECAUSE OF THE ENCRYPTION OF THE VIDEO AND AUDIO BUT YOU WILL HAVE A SIGNAL ON ALL CHANNELS..... FACT!!!!!!!!!!!! FAKEMAN YOUR A LOOOOOOOOOOOOSER!!!! YOU KNOW NOTHING ABOUT STREAM OR HOW THE ENCRYPTION WORKS... YOU JUST A LITTLE BIN GOBBLER WANNABEEE TEST.. Gobble Gobble FAKEMAN |
Gold Member Username: Runnerguy
Pluto
Post Number: 1444 Registered: Sep-06
| Posted on Friday, June 20, 2008 - 05:59 pm: |
NY
Post Number: 2885 Registered: Oct-06
| Posted on Friday, June 20, 2008 - 06:21 pm: |
Yo challenge me!!! Do yo actually think yor normal?
Silver Member Username: Thechiz2
The south,
Ur anis
Mine
Post Number: 432 Registered: Apr-05
| Posted on Friday, June 20, 2008 - 06:57 pm: |
lol i've always wanted to do this
Post Number: 385 Registered: Jan-08
| Posted on Friday, June 20, 2008 - 09:25 pm: |
Bronze Member Username: Master_lee
Post Number: 94 Registered: Oct-07
| Posted on Saturday, June 21, 2008 - 07:02 am: |
Do yo all actually think I am normal? King Tapeman THANKS  |
