Thread: Installing PCI O/I card |
Bronze Member Username: Leines
Post Number: 90 Registered: Apr-07
| Posted on Saturday, June 14, 2008 - 08:29 am: |
Anyone ever had to install a PCI O/I card into a windows vista system... as soon as i add the hardware.. my system wont even boot inless its into safe mode... any ideas? |
Relevant Product Info
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 2596 Registered: Jan-08
| Posted on Saturday, June 14, 2008 - 09:21 am: |
Reinstall Vista Disk and do a repair |
Silver Member Username: King_of_sats
Post Number: 365 Registered: Jan-08
| Posted on Saturday, June 14, 2008 - 09:41 am: |
uninstall it it in safe mode and search the net for a updated driver. Its obviously a driver issue. Beause when you boot in save mode only the basic drivers are loaded. |
Post Number: 92 Registered: Apr-07
| Posted on Saturday, June 14, 2008 - 10:03 am: |
Ok here are what im using.. I have a HP pavillion running windows vista home . the card im trying to install is a SYBA PCI Multi I/O Controller SD-PCI-2S... When i remove the card from the PCI slot and boot..the computer will boot normally... If I put the card back into the computer, it wont boot in regular mode, i get bluescreen.. but it will boot into safe mode.. In both cases, the card isnt showing up in device manager under com cards.. Now when i first put the card into the system and install the driver in the box, it seemed to be working, but it was assigned to com port 8 and 9 and my loader for CW only had selections for up to com 6... Should I remove the card, then boot the PC and remove the drivers... or should i just boot into safe mode and remove the driver?? Thanks for the help guys.. |
Quebec city,
Quebec
Post Number: 2600 Registered: Jan-08
| Posted on Saturday, June 14, 2008 - 10:34 am: |
Remove the card and uninstall driver, reboot and install driver first, off comput and install card and boot. On XP and Vista : install driver first and card. If that not work do a search on site of card or forum on Yahoo or Google |
Post Number: 93 Registered: Apr-07
| Posted on Saturday, June 14, 2008 - 10:52 am: |
ok i got the card installed..and the driver going.. and vista is saying its working and ready to use.. but its working on COM 8 and COM 9... and my loader doesnt have a selection beyond COM 6.... how do i switch it... |
Quebec city,
Quebec
Post Number: 2602 Registered: Jan-08
| Posted on Saturday, June 14, 2008 - 08:21 pm: |
Sorry leines i'm come back go in your driver and change it. It's very difficult to help you without comput in face of me. Do a search on site of card. The site for your : http://www.syba.com/Product/Info/Id/42 and manuel: http://www.adeltek.com/Product%20Manual/PCI%20IO%20CONTROLLER/SD-PCI-2S.jpg Maybe you can ghange it on upper slot on main board good luck |
