Home > Message Board > Home Video > Rear Projection TVs > Archive through June 27, 2008 > Samsung dlp bulb how to get to it?
Author Thread: Samsung dlp bulb how to get to it?
Username: Monkeyonalimb
Lewisville, Texas
Usa
Can someone who has replaced this bulb give me a walk through? I have never had a problem to really speak of w/my samsung and it seems its time to replace my bulb.....i guess i am going to order it off this site...unless someone here says not too for a good reason....http://www.bluestar-online.com/BP96_00826A_Samsung_Replacement_DLP_Lamp_p/bp96-0 0826a.htm?gclid=CNyYlpD205MCFRcOIgodxiKgjA
any input is appreciated, NO man in this house and i am not a electronic wizard, as i am very capable....thanks
Username: Drrich
Just open the door on the back of the TV. Two screws I think. Look in and you will see a tray with the bulb. There might be a couple more screws, I don't remember. Then slide the tray out. Then you can see how to change bulbs. It's a no-brainer. I did it.
Home > Message Board > Home Video > Rear Projection TVs > Archive through June 27, 2008 > Samsung dlp bulb how to get to it? [ « Previous ] [ Next » ]
