Home > Message Board > Home Video > DVD Players > Archive through January 30, 2004 > Sony sava-d900 5 dvd changer problem
Author Thread: Sony sava-d900 5 dvd changer problem
I bought this Sony Sava-D900 dvd entertainment unit and the dvd player would hang in the middle of the movie and sometime, most often than not, starts the movie over again or it plays back to the beginning. some of my movies doesn't do this but most of my dvd s keeps hangning. I know it's not the dvd itself because the ones I have problems with does not happen when I play it in my playstation 2. Can anyone give me any ideas on the cause of this or a fix? Thanks in advance.
i have the same system and mine doesnt do that...something simple, but have you tried using a cd rom cleaning disk in it?...just checking
also if i may ask a question of you, if you have the remote control for this unit...could you email me the model number off of it pleeeeaaase ..
id like to try and find one on ebay or some where...i cant afford the one from sony.com
becool@centurytel.net
Thanks
I HAVE A SONY SAVA-D900 MY CD HAS BEEN PLAYING FINE MY MOVIE DVD PLAYER HAS BEEN PLAYING FINE.
TONIGHT IT WAS PLAYING DIC ONE JUST FINE I PUT CD'S IN THE OTHER PLAYER'S AND IT WILL NOT PLAY NOR WILL IT EJECT THE CD'S PLEASE HELP
Home > Message Board > Home Video > DVD Players > Archive through January 30, 2004 > Sony sava-d900 5 dvd changer problem [ « Previous ] [ Next » ]
