Home > Message Board > Home Video > Satellite TV > Archive through June 21, 2008 > NEW KEYS (Part-2 continuation thread) > Archive through May 06, 2008
Author Thread: Archive through May 06, 2008
Username: Rekman
Mntl-Quebec-...
Post Number: 368
hi friends wat is the actual BIN for cools*t 5000???
thanks
Relevant Product Info
Username: Dude123
Post Number: 2202
173 which came out on the 18th of April. Go here to download no registrations required http://www.tvkeyz.com/filez.html
Username: Nydas
Post Number: 10357
With the lastest BIN that is about 8-10 days old, there is a definite ECM on the autoroll portion and autoroll software switch, sUch that the keys may not roll in properly.
I suggest that people become familiar again with the manual entry of keys - just in case
DN Provider ID 0101 - Last update: Sat. Apr 26, 8:32 PM EDT
Key 00 (86):
C5 92 A7 F8 30 AE 8B A5 7D B0 AD 61 C6 CC A5 BF
Key 01 (96):
DD 82 E5 5A F5 30 B9 23 0D 7C 97 17 3B F2 6E 08
DN Provider ID 0106
Key 00 (86):
04 AD BD 42 87 73 73 64 1F 4A 1F 41 55 4C 4B 69
Key 01 (96):
FF 14 A5 BE DA 7B D9 99 73 E3 06 85 34 69 22 45
BEV Provider ID 0901 -- Last update: Fri. Apr 25, 8:28 AM EDT
Key 00 (86):
B2 4C 0E C4 64 3E 6B 46 96 36 BE 24 21 BE 88 48
Key 01 (96):
12 85 49 3C 9B EB CF CD 85 2E E3 FD 79 73 93 FF
BEV Provider ID 0907 ]
Key 00 (86):
37 17 CD 3A 94 91 3D 05 4F 0D BB 30 1F DD AD 72
Key 01 (96):
CD 13 C6 F3 0E C6 F8 E3 2E D8 4C 8D 5B F6 B0 E5 New
Globecast provider ID C101
Key 00 (86):
64 98 CF 47 51 64 4B C0 2B 46 2F 6E 34 CB EE 2C
Key 01 (96):
88 57 C2 D7 ED 0C 62 6E AD 44 41 77 2C 86 6A 4F
Username: Brucelee
Beverly Hills, California
United States
Post Number: 150
Is there a new key for DN? It's autorolling again?
Username: The_coders
Post Number: 1048
Dish Network (0101) [Last update: Sat. Apr 26, 10:32 PM CDT]
86: 5C BF 86 46 89 47 C4 CC 48 69 4A 4C 6E B1 02 02 New
96: DD 82 E5 5A F5 30 B9 23 0D 7C 97 17 3B F2 6E 08
Username: Nydss
Post :10419
As far as I know a USB 2.0 drive can accept data at lower speeds from your computer e.e. from USB 1.0 port.
then you take it to your viewsat ultra which will accept it anyway.
I am not quite sure what you are tyr to establish or deny yourself. A light bulb capable of 100 watts can always be used via a resister to give 50 watts (dimmer switch), and yet it be taken to an ordinary circuit and shine at 100watts.
I hope you understand the analogy.
A light bulb designed to withstand 220Volts of England or India, can be used in North America under 110V - if you can get the right fitting.
Username: Lupefiasco
Mississauga, Ontario
new keys at www.ftadoctor.blogspot.com
Username: Zunna
Post Number: 217
wats goin on. i have pansat 2500 and the chanells come for 2 min and disseapear again can somebody tell me wat should i do. and btw i have the old bin which was out on april 10 i think
Username: Rekman
Mntl-Quebec-...
Post Number: 369
hi nalin .
i bought a laptop and i downloaded COOLS*T PRO LOADER version 2.4.
but when i am trying to download actual BIN by clockin on ""connect"" i am receiving a message which says ""NO AVAILABLE COM PORT""....
wat must b done Nalin.?? please help..
thank you...
Username: Nydas
Post Number: 10378
MKM:
USB to serial convertors are notorious for problems and for slowness.
Buy only the type with its own installation CD.
Do not allow windows XP to install it.
Manually install using CD
Select COM1, or COM2, or COM3 or COM 4 port.
Use device manager in your computer to check and select the right port.
Username: Nydas
Post Number: 10380
Zunna: I have answered you in another thread a few minutes ago.
Username: Rockman169
Post Number: 28
thank nalin that what im going to do get a adaptor. and a sv 360 elite .
Post Number: 1057
Current Keys
Dish Network New Provider ID (0106) [Last update: Thu. Mar 27, 10:58 AM CDT]
86: 04 AD BD 42 87 73 73 64 1F 4A 1F 41 55 4C 4B 69 New
96: FF 14 A5 BE DA 7B D9 99 73 E3 06 85 34 69 22 45
Username: Rekman
Mntl-Quebec-...
Post Number: 370
WHICH CD NALIN ???
where would i get this CD??
Username: Nydas
Post Number: 10385
Your laptop does not have a serial adaptor.
I take it you want to use your laptop to Upload BIN to your receiver.
You need a USB to serial adaptor and the cable.
These adaptors are very tricky and often give problems with the connection.
The store where you buy the adaptor should be able to sell you the adaptor with the software CD.
Post Number: 1072
I recommend U all stay away from DssCommunity.con site...they have no files nor educational purposes...its a site of 95% troublemakers who are using the nicks of some real respected DSS personnel.... their sole intent is to character assasinate the well known respected members of the Dss community and to KILL FTA...its also been rumored that these "troublemakers" are actually employees of Dishnet and Bev...the site and its admins allow this type of bashing and use of other people's nicks, so thats self explanatory regarding the intentions of this "DssCommunity" site...I don't believe it to be safe there or of any FTA value..
DssCommunity allows posting of live links too...so every scammer in the world is posting there many times a day...Mostly these are Pay sites, with fine print selling memberships to public files, and scamming all the newbies who don't know any better... satscams has identified many of these scam sites posting at DssCommunity..use the sponsors posted at Reputable sites not live links from a site like DssCommunity...I highly recommend U stay away from DssCommunity..
__________________
Username: Dude123
Post Number: 2209
Please copy this and save it in your computer for future.
C/P
USB to Serial Cable Help
There have been a number of posted regarding USB to Serial Cable's.. and troubles regarding those cables.. I decided to give some tips for those people who are having troubles..
Hopefully I did not miss anything in writing this, if I did, please post or correct me.
STEPS
#1. Make sure your USB to Serial Cable is compatible with your operating system.
#2. Connect your cable, install your drivers FROM a provided CD or from the manufacturer website and then make sure you have your drivers properly installed by checking the device manager.
#3.
- Go to Start - Control Panel - System - Hardware
- Go to Device Manager and Ports and see what Com your USB cable is set to.
- The Advance button will allow you to change the port. Change it to 1, 2, 3 or 4.
- Also be sure to change the Baud (Bits per second) to 115200.
#4. When using a loader from your specific reciever, make sure the COM port selected on the loader corresponds to the com port you changed in the previous step.
#5. Load your file.
Issues/Solutions
- If your having trouble installing drivers for your USB to Serial Cable, try to refer to any websites of the manufacture of your specific cable for any new drivers or any help with your issue.
- If you did all the required steps and your loader sticks at 0% OR doesn't even make any connection to your receiver, your cable has not been installed properly. Please try running through all the steps again or try cleaning out any old drivers and putting them in again.
- If you still can't get it to work, try a different USB port.
- If still you cannot get anything to work, look for any hardware conflicts with your USB to Serial Cable in your device manager.
- If still you are having issues, try the cable on a different operating system or different computer.
- If you are still having issues, try different drivers instead of the ones provided.
- IF YOU CANNOT DO ANY OF THE ABOVE, GET A REGULAR COMPUTER WITH A SERIAL CABLE PORT AND SERIAL CABLE!
ADDED NOTE: MANY USB to Serial cable adapters our there will not work with null modem receivers.
How To Guide: USB 2 Serial adapter to function properly
I Found this on another site hope it helps someone here
There are essentially only four basic steps required to get an USB to(2) Serial adapter to function properly:
1. Physically plug the USB2Serial adapter into an available USB port
2. Install the driver for the adapter (recommend that you use the one that was actually supplied with the adapter; universal drivers are "iffy")
3. Connect the correct cable (null or straight-through) between the adapter and your FTA receiver; in the case of the Coo*lsat, it is straight-through
4. Synchronize the COM port assignment of the USB2Serial adapter with a COM port supported by the Loader program (they MUST be the same).
The above four basic steps are relatively simple but a lot of things can go wrong along the way. For example, communications will fail if:
1. You don’t use the correct type of serial cable (null modem or a straight-through) between the adapter and your FTA receiver.
2. The COM port assignment of the USB2Serial adapter and the COM port setting in the loader/software program do not match.
3. You use the wrong loader program or bin file for your particular brand/model of receiver or the bin file was not extracted and is still in zipped or compressed format
For experienced computer users, the above constitutes all the instruction you will probably require. For computer neophytes, here's a simple step by step procedure for troubleshooting your USB2Serial adapter:
1. RIGHT-click on [My Computer] » [Properties] » [Hardware] » [Device Manager]
2. Scroll down the list of devices to [Ports] and click on the [+] sign on the left of [Ports]
3. Locate your USB2Serial device under [Ports] and RIGHT-click on it; select [Properties]
4. Under the [General] tab, the [Device Status] window will indicate whether it is functioning properly. If not, you should uninstall the device, reboot, and let Windows auto-detect the device. If it cannot locate the driver, you will be prompted to insert a driver disc
5. Click on the [Port Settings] tab and bump the port speed to the max (115200 or 128000 bps).
6. If you need to change the COM port assignment of the USB2Serial adapter to match one that your Loader program will support, click on the [Advanced] button (under the [Port Settings] tab) and change the [COM Port] value.
7. Be sure to sync or match the adapter's COM port assignment with one that the Loader program supports.
One final note: Coo*lsat receivers have an [Auto Detect] feature for locating and synchronizing the Loader program with the PC. You do not have to modify the COM port assignment (step 6) if you have a Coo*lsat receiver (just click on [Auto Detect].
Keep in mind that if you disconnect the USB2Serial adapter and plug it into a DIFFERENT USB port the next time you go to use it, Windows will automatically assign a different COM port value to the adapter. To eliminate configuration issues, always plug the USB2Serial adapter into the same USB port each time.
Ottawa, Ontario
latest dish keys at www.ftadoctor.blogspot.com
Username: Ariana_70
Sorel-Tracy, Quebec
Post Number: 150
can someone tell me if buying a captivework 800s is a good buy or not?
Username: Ariana_70
Sorel-Tracy, Quebec
Post Number: 153
can someone tell me please what is the latest bin for a captivework 800s thkx!!
Username: Dude123
Post Number: 2215
CW800SV1.60_2008_04_16
Get it from http://www.tvkeyz.com/filez.html
Username: Brucelee
United States
Post Number: 151
Is BEV down or are there new keys? I have VS Platinum.
Username: Dude123
Post Number: 2216
Bell ExpressVu (0901) [Last update: Mon. Apr 28, 10:57 AM CDT]
86: B2 4C 0E C4 64 3E 6B 46 96 36 BE 24 21 BE 88 48
96: 9A 2C D4 5A 12 A6 5D DE AD 83 E9 CF 55 AE 28 AD New
Username: Zunna
Post Number: 221
ARE THERE NEW KEYS HERE??
Username: Dude123
Post Number: 2219
Dish Network (0101) [Last update: Wed. Apr 30, 3:35 PM CDT]
86: 02 BA 6B 74 E5 8E 8F 63 EE BC 1B F1 3D 60 CC 94 New
96: 8E 8D BC FB A2 8D 3D 70 F8 58 A0 37 E8 07 0F 62
Bell ExpressVu (0901) [Last update: Wed. Apr 30, 10:16 AM CDT]
86: F7 08 7E F1 14 AC C5 36 C9 CF D3 89 B4 07 FB BD
96: C8 AD B2 00 96 5C 06 D4 94 58 1E 1B 26 14 17 CF New
Bell ExpressVu PB (0905) [Last update: Thurs. Mar 15, 2:01 AM CDT]
86: B7 2F 03 35 70 4A CD B0 6D 43 33 59 92 E2 1D F3
96: D5 51 BA FE 58 50 BE 61 A4 BD 09 F3 54 4F C5 FC
Bell ExpressVu HD (0906) [Last update: Thurs. Mar 15, 6:17 PM CDT]
86: 8D 1A 1C F4 2C B9 7F 85 38 65 D6 7A 5D 59 5D 88
96: 11 FE 27 1D 89 9E D3 B4 DB 8E CB C8 10 D3 E7 F7
Bell ExpressVu New PID (0907) [Last update: Sun. Mar 30, 3:51 PM CDT]
86: 37 17 CD 3A 94 91 3D 05 4F 0D BB 30 1F DD AD 72
96: CD 13 C6 F3 0E C6 F8 E3 2E D8 4C 8D 5B F6 B0 E5 New
Globecast (C101) [Last update: Tues. Jan 15, 8:32 PM CST]
86: 64 98 CF 47 51 64 4B C0 2B 46 2F 6E 34 CB EE 2C
96: 88 57 C2 D7 ED 0C 62 6E AD 44 41 77 2C 86 6A 4F New
Username: Halo
Toronto, Ontario
Post Number: 486
All new keys and info at www.dishkeys.co.nr!
Username: Sidthekid
Post Number: 96
check out www.ftakeys4u.blogspot.com for latest keys!
Username: Dude123
Post Number: 2222
The best site for latest keys, files and D!DH/B3V status is: http://www.tvkeyz.com/ You don't need to be registered and the files are easily available and the site is fast so always check there first for latest files/keys/status.
Username: Halo
Toronto, Ontario
Post Number: 487
NW....at www.dishkeys.co.nr u dont need to be registered either.
Username: Dude123
Post Number: 2227
I see that now....hopefully the update time and the speed of the site is like the one I posted too. Lets see it for a while.
Username: Nydas
Post Number: 10447
The difference between
www.tvkeyz.com and
www.dishkeys.co.nr
is the difference between a cadilac and a bicycle.
so Andrea Bargnani, please stop bragging about your site.
Username: Illspamu
Post Number: 7
hi, I just JTaged my pansat 3500 back to life after loading a bin (375) a couple of weeks back, does anyone know where I can download a clean bin?
Username: Dude123
Post Number: 2228
Always visit pansat home site www.future-fta.info for genuine pansat files.
Username: Dude123
Post Number: 2230
Cannot input these keys....wait for new fixes to be released.
Dish Network New Provider ID (0106) [Last update: Thu. May 1, 11:38 AM CDT]
96: 4E B1 A8 DA 2D 92 90 D9 E6 3C 5E CE E4 FE E3 86 New
Bell ExpressVu New PID (0907) [Last update: Thu. May 1, 9:52 AM CDT]
96: 7C 33 3F C3 82 1C 64 93 3A 85 28 8D DA D2 86 AE New
Username: Skeptik
Artica
Post Number: 55
down down down down...
Username: Halo
Toronto, Ontario
Post Number: 489
Keep checking www.dishkeys.co.nr for new files to be released!
Username: Realdio
Monterrey, Nuevo Leon
Mexico
Post Number: 103
Hi guys, I just arrived to the city, is pansat down?
Username: Dude123
Post Number: 2231
Yes B3V and D!SH both down on all receivers!
Username: Halo
Toronto, Ontario
Post Number: 492
the newest bins for Viewsat will be posted at www.dishkeys.co.nr as soon as they get released...so keep checking for updates!
Username: Charly_d
Montreal, Quebec
Post Number: 40
Hi every one i just turned my tv on and every channel is working on my viewsat ultra there is no new bin and every thing is on just whatch tv.
Username: Dude123
Post Number: 2254
Yep D!SH network came back up on the last bin. B3V still down!
Username: Halo
Toronto, Ontario
Post Number: 493
New update at www.dishkeys.co.nr....so make sure to check it out!
Username: Jainivas
Post Number: 16
D!sh is back up and running...CONFIRMED...no new bin file needed....just do a hard boot and enjoy....
Thanks NW for informing us
Username: Trinity
Post Number: 39
I am getting a message saying scrambled/bad channel. I switched the switch off my Panset2700 E off which is on the back of the receiver and then turned it on after some time yet I still keep on getting the same message.
Someone please help!!!
Username: Vicb
Post Number: 59
turn your auto roll off for all pansats 2700
Username: Dude123
Post Number: 2255
yeah turn the autoroll off and close captions off and see if it works. If that doesnt work turn OFF/ON from the back then "set default key" and let the keys roll itself (at this time make sure the autoroll is ON)
Username: Trinity
Post Number: 40
Thanks Guys!!
Username: Zunna
Post Number: 224
dn is down again. is it a key change?
Username: Kirankumar
NO Bashing
Post Number: 2672
Zunna
dn is down
you don't need keys
you will have to wait for new bin
keep looking in forum for updates
Username: Eelo
Post Number: 10
this time star plus and star one also not working on dn but thats the first time it happened any clue wat is going on actually plzzz help
Username: Dude123
Post Number: 2258
yes...all the international channels are down on Bev and DN wait for the new fixes to be released
Username: Halo
Toronto, Ontario
Post Number: 496
