hey all, About a week ago my trusty pansat 2500 started losing the 119 sat single. it started small BUT then all 119 has no signal the sat 110 started doing the same thing. I am down to like 10 channels on 110 LOL. When I do A blind scan I get " no transpounders found" Before every thing went dead. before It all died I had 70-80 on my lock on sat 119 and 110. I have not had any storms to mess with the sat and it's screwed down tight. I hate to mess with it.any idea's?
If it is a software problem, it will fix it self if you do a full set up from scratch. Note down your antenna settings 1. b60 boot 2. 294T Bin 3. PUFF BOOT/BIN_253 - make sure it is a 640K 4. Latest PUFF BIN - 266 5. Reset 6. User setup 7. antenna setup and scan.
