Thread: "Tooter, Bruce 1 need help on CW-800." |
Bronze Member Username: Xpehbam
China,
NC
Post Number: 85 Registered: Jun-05
| Posted on Thursday, May 15, 2008 - 05:18 pm: |
Hi! When I click PIP button on Captiveworks 800, it's showin me only emty blue screen , nothing in it.. I did hard reboot, but stil they same.. Thank you for all your help. |
Relevant Product Info
Silver Member Username: Dimwitt
Post Number: 693 Registered: Aug-06
| Posted on Thursday, May 15, 2008 - 06:45 pm: |
sorry , i do not know anything about the PIP function on the 800. |
China,
NC
Post Number: 86 Registered: Jun-05
| Posted on Thursday, May 15, 2008 - 06:58 pm: |
Thank you! |
Gold Member Username: Brucester
Post Number: 1507 Registered: Jul-06
| Posted on Sunday, May 18, 2008 - 09:52 am: |
its not true pip it will bee no good to try to watch a move on but its ok if you want to keep scoor on a nother game the pitcure dos not run smoth when you hit pip go to real pip and click on that one then hit ok on the remot it should give you a list of ch you can watch all chopy hope this helps sorry i did not see you thread till today ben working a lot |
China,
NC
Post Number: 90 Registered: Jun-05
| Posted on Sunday, May 18, 2008 - 12:11 pm: |
Thank you bruce1 , but I tried that and it's just showing emty blue screen.. |
Post Number: 1508 Registered: Jul-06
| Posted on Sunday, May 18, 2008 - 04:03 pm: |
if its that importint to you put in the factory bin then put turn the box on give it 3 mins then turn it off put in the new bin then try it let me no thanks |
China,
NC
Post Number: 91 Registered: Jun-05
| Posted on Monday, May 19, 2008 - 09:25 am: |
Thank you bruce 1 . I will try this afternoon and let you know.. |
