Thread: Dan's apology-B75_266. New file |
Platinum Member Username: Nydas
Post Number: 10709 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 10:15 am: |
Dan's apology: dans_new_266_b75 Sorry for inconvenience I zipped it and unzipped good to go This is for those still using b75 files this is clone safe. This is not for LZMA or PUFF Use At Your Own Risk!! Set Default Key and let it A/R. Turn A/R OFF (except Key Code) if experiencing rebooting issues. No need to do a factory setting in main menu if your not having problems. Do one if you are experiencing problems. Attached Files dans_new_266.zip (435.4 KB) The file is available at: http://www.ftatalk.com/showthread.php?t=174908 http://public.box.net/2500_full_kit |
Relevant Product Info
Silver Member Username: Jwl1
Post Number: 302 Registered: May-06
| Posted on Thursday, May 15, 2008 - 01:53 pm: |
Okay, I guess this explains it then and answers my earlier question. It's (Dan's bin) also posted at ftatalk. |
Bronze Member Username: Elvirm
Post Number: 33 Registered: Sep-07
| Posted on Thursday, May 15, 2008 - 08:57 pm: |
I alreadyput new post about this. My bad. Is this bin okay for converted FLU to Pansat or not. Thanks. |
Post Number: 10716 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 09:37 pm: |
If youwant to continue using b75 BINs, Dans or Saif BINs are avaialble |
Platinum Member Username: Lklives
Post Number: 15684 Registered: Jan-06
| Posted on Thursday, May 15, 2008 - 10:35 pm: |
I can tell U all, thats a BOGUS post an apology!!..which doesn't surprise me comimg from Nalin and ftatalk! Dans original B75 266 bin was a hoax, ONLY because it was the old 265 file, NOT the 266...some azzhole, probably Nalin herself, the DN mole and RAT, simply renamed the file from to 265 to 266..thats why I don't suggest ftatalk...or Nalin!! |
Silver Member Username: Gregraf
Post Number: 567 Registered: Dec-07
| Posted on Thursday, May 15, 2008 - 10:51 pm: |
Ya we all know that Nalin Nyda is a LOSER. BUT WE
Post Number: 10718 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 11:07 pm: |
LK: You are in the wrong thread. If you want to continue using b75 BINs, Dans new BIN or Saif BINs are available http://public.box.net/2500_full_kit |
Post Number: 571 Registered: Dec-07
| Posted on Thursday, May 15, 2008 - 11:15 pm: |
WARNING Nalins box will fry your box |
Post Number: 10722 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 11:17 pm: |
Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 or PUFF http://public.box.net/2500_full_kit You must select whether you want to have the old b75 files or PUFF files. If you have b75 boot, you must convert to PUFF boot to use PUFF BINs Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Post Number: 572 Registered: Dec-07
| Posted on Thursday, May 15, 2008 - 11:24 pm: |
Post Number: 10724 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 11:27 pm: |
Post Number: 573 Registered: Dec-07
| Posted on Thursday, May 15, 2008 - 11:36 pm: |
Bronze Member Username: Master_lee
Post Number: 46 Registered: Oct-07
| Posted on Friday, May 16, 2008 - 05:54 am: |
Nalin should apologize not Dan. |
Post Number: 10729 Registered: Jun-06
| Posted on Friday, May 16, 2008 - 10:29 am: |
I do not have to apologise for somebody else's mistake. I did not post or recommend the file that was bad. It was file posted at ftatalk, and I noticed it after a few comments of its uselessness, I came to Ecoustics, saw bad comments here. When dans apologised on the ftatalk site that he had made a mistake and posted a new file, a pointed only to the new file. |
Post Number: 15702 Registered: Jan-06
| Posted on Friday, May 16, 2008 - 11:08 am: |
Dsscommunity Forums and LIVE Help Present current Forums and SAFE REPUTABLE ESTABLISHED site...latest files within seconds of release...no bad files ever...FREE..ALWAYS open! http://www.dsscommunity.c*om/forums2007updatednewurl/index.php BTW..we have another brand NEW Forums and a new look and features, now just opening also..in transition from old to new forums ...ALL FREE!...feel free to join and contribute..all are welcome!.. http://dsscommunity.c*om/bbs/index.php BTW...both have LIVE HELP always available too!...FREE! Just the remove the * in the links above...copy/paste into browser..register free like ya did here.. |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 2423 Registered: Jan-08
| Posted on Friday, May 16, 2008 - 11:21 am: |
Go to dsscommunity sh1t and Lk sold your IP and E-Mail and make good money with you |
Post Number: 15717 Registered: Jan-06
| Posted on Friday, May 16, 2008 - 11:30 am: |
Post Number: 10759 Registered: Jun-06
| Posted on Friday, May 16, 2008 - 11:31 am: |
http://forum.ecoustics.com/bbs/messages/2/471481.html A typical FTA site has a lot of thread with files, instructions, etc. There are many good sites. Always go to "home site of your receiver" first. The sites in BOLD offer direct downloads without registration. http://www.future-fta.info – PANSATS http://www.ftahq.com - VIEWSATS and ?Sonicview http://www.f2atv.com - C00LSATS http://www.completefta.com - CaptiveWorks. http://www.ftatalk.com - Ariza and Pansat Conversions http://www.dssrookie.com - Pansat 2700 clones http://www.nfusionforum.com - Nfusion The following is an example of a very small part of a site http://www.ftatalk.com As you can see, it is loaded with informations DISH FAQ AND HOWTO 118.7, Anik F3, Ecxostar 6... 118.7 Anik-F3, How do I get it? RG6 Cable length & signal quality Best dish for 82,91,110,119 Why is my signal bouncing around? DP34 Switch Help sick of all the ECM !! options available!! DishPro and Legacy Info! How to setup your Dish1000.2 with a FTA Receiver How to Setup your Dish500 Dpp/Superdish Dp with a HD Receiver Peaking your dish with a Satellite Finder(TIPS) Laser Alignment Laptop no com port question How to start your motor dish setup, first things first. How a diseqc switch works DISHPRO 1000 ~ Official Document & Specs. Aspen eagle Broken arm on the dish A discussion of signal strength and quality... Nees Help Please!!!Super Dish The "best" Dishpro Document FTA Faq and How To's How To Post Files & Photos Handy utility for dish effeciency How to reaim your BEV dish to get DN ( 1 2) How To Use The Search Features and many more FAQs. |
Quebec city,
Quebec
Post Number: 2429 Registered: Jan-08
LK is the worse spammer on Ecoustic as we can see Go to dsscommunity sh1t and Lk sold your IP and E-Mail and make good money with you |
Silver Member Username: Psychmonster
Rhodium Member higher
Post Number: 808 Registered: Jul-06
| Posted on Friday, May 16, 2008 - 07:59 pm: |
LK...you are better than this...don't be sucked into the spam crap thats a plaque on this site... |
Post Number: 15723 Registered: Jan-06
| Posted on Friday, May 16, 2008 - 09:38 pm: |
I am simply letting people know that Dsscommunity is changing to new forums with a new web address..and any comtributions they may want to make in terms of good guides, manuals how to's, info, etc to share is always more than welcome.. I personally don't care if people don't use the site or Not...but do want them aware of this change to a NEW Forums and addy...its their loss if they don;t use dsscommunity...cause I know we have MORE info than most all other sites..and a GREAT LIVE Help chat with many members active.. |
Gold Member Username: The_coders
Post Number: 1212 Registered: Jan-08
| Posted on Friday, May 16, 2008 - 09:45 pm: |
If you thought ecoustics was the bottom of the heap , dsscommunity will take you a step lower , bottom-feeders that steal info from your pc everytime you click on anything there , a DN owned snakepit . |
Post Number: 580 Registered: Dec-07
| Posted on Friday, May 16, 2008 - 10:05 pm: |
You know all about Dishnet eh Coders |
Silver Member Username: North_of_ontario
Post Number: 876 Registered: Sep-07
| Posted on Friday, May 16, 2008 - 10:54 pm: |
Post Number: 809 Registered: Jul-06
| Posted on Friday, May 16, 2008 - 11:03 pm: |
all this conspiracy crap is all BS...Nalin is not a nark...LK is not a mole ... plymouth is not a dick....ok...that one may be a fact so omit that one.. |
Post Number: 581 Registered: Dec-07
| Posted on Friday, May 16, 2008 - 11:04 pm: |
Silver Member Username: King_of_sats
Post Number: 129 Registered: Jan-08
| Posted on Saturday, May 17, 2008 - 09:34 am: |
Post Number: 587 Registered: Dec-07
| Posted on Saturday, May 17, 2008 - 01:10 pm: |
Post Number: 136 Registered: Jan-08
| Posted on Saturday, May 17, 2008 - 01:23 pm: |
Post Number: 596 Registered: Dec-07
| Posted on Saturday, May 17, 2008 - 01:33 pm: |
Post Number: 810 Registered: Jul-06
| Posted on Saturday, May 17, 2008 - 03:58 pm: |
...this is so boring...like a valium enem_a |
Post Number: 155 Registered: Jan-08
| Posted on Saturday, May 17, 2008 - 05:21 pm: |
psychmonster Might be fine and dandy in your brain of denial which is feeding feelings of it's about me residing in the zit u call a brain but here no one cares about your opinion.. Call mommy if you haves needs of being wanted 1800-who-care |
Post Number: 811 Registered: Jul-06
| Posted on Saturday, May 17, 2008 - 06:04 pm: |
King...you are a master of double speak and ultmately saying nothing...you lack imagination and knowledge so the more you speak, the less you say...so say nothing and then you are a genius |
Post Number: 599 Registered: Dec-07
| Posted on Saturday, May 17, 2008 - 06:13 pm: |
King of Sats = King of Losers
Post Number: 158 Registered: Jan-08
| Posted on Saturday, May 17, 2008 - 07:22 pm: |
Oh greg!! you words are so profoundly Imagenitive when ranked against chimps in a cage... Boo Hoo for you.. Your love of looooooooosers is a meer pea brain Fallacy your gaynation obession is just plain wrong.. Your love of D!cks is sick.. Please for the sake of your fellow man seek help ASAP |
Post Number: 600 Registered: Dec-07
| Posted on Saturday, May 17, 2008 - 08:17 pm: |
