Home > Message Board > Home Video > Satellite TV > Archive through May 21, 2008 > Viewsat ultra -satellite echostar 3 -...
Author Thread: Viewsat ultra -satellite echostar 3 -lost american channels
Username: Rzkaps
Toronto, Ontario
Post Number: 10
After the new bin, I have lost the american channels. tried autoscan. please help.
Relevant Product Info
Username: Plymouth
Quebec city, Quebec
Post Number: 2401
Try blind scan
Username: Rzkaps
Toronto, Ontario
Post Number: 11
tried blind scan too, did not work. Anybody else having this problem. I do not know if I have to change any settings.
Viewsat Ultra users, please help.
Username: Nqarni
Post Number: 35
I have lost some Desi channels, like TV Asia, Sat USA, ARY Digital, PTV Global and Max, to name a few. Only few Desi channels are up on my VS Ultra. HELP
Username: Plymouth
Quebec city, Quebec
Post Number: 2438
Delete sat in channel menu and rescan it.
Check your satellite setup if LNB freq is good
Username: Nqarni
Post Number: 36
And how can I do that? Sorry I have not done this before. Please guide.
Username: Plymouth
Quebec city, Quebec
Post Number: 2439
Go to menu
Installation "ok"
0000 pin code
Channel scan "ok"
up arrow
left arrow and "ok"
Exit and save
Now return to Antenna setup "ok"
left arrow and select echostar 3 "ok"
LNB Power "on"
LNB Type Standard
LNB "11250"
Tp Freq. "12326"
Port: if you have a switch choose good port if not "none"
Motor "none"
Legacy switch "none"
Now check if your signal is good, if yes exit and save
go to autoscan "ok"
select scan start "ok"
save and exit
check if channels work
Good luck
Home > Message Board > Home Video > Satellite TV > Archive through May 21, 2008 > Viewsat ultra -satellite echostar 3 -... [ « Previous ] [ Next » ]
