Home > Message Board > Home Video > Satellite TV > Archive through May 15, 2008 > Black Tyger PUFF Bin 266 - [May 14th]
Author Thread: Black Tyger PUFF Bin 266 - [May 14th]
Username: Asharfi
Post Number: 1954
Hello,
Here's the latest PUFF bin for the converted FLU/Pansat 2500 to PUFF receivers. All DN & BEV channels are working good. This attached file has the latest PUFF bin and the PUFF loader which you can use to load the latest PUFF bin.
Download: Black Tyger PUFF Bin 266.zip
Note: This is the first place where I am releasing my PUFF bin. Now I'll post this on my sites and later on FTABins.NET. I know that my speed is kinda slow, and I am sorry about that. I am learning this, so I have to do everything step-by-step and then I have to test. You'll notice that when you load this bin and to the SYSTEM INFORMATION option, you'll see my name as a credit. Have Fun!
Relevant Product Info
Username: Batjc
Post Number: 130
Good Job AV!...
you have always serve GREAT
and I thank you cause of that...
now do the same for b-75 jejeje... just playin keep up the excellent work
Username: Asharfi
Post Number: 1955
No problem, Jeancarlos!
I'll be releasing a new channel list for Echostar 3, 7, and 8.10 soon.
Username: Leo_here
Post Number: 86
Hey AV. I am experiencing Freezes when using remote !
Whats wrong with your bin?
Username: Kulit
Post Number: 12
Yeah whenever I press menu or change channels it reboots
Username: Asharfi
Post Number: 1956
Leave the unit aside for 1 minute and then it'll fix the problem.
Username: Leo_here
Post Number: 87
What do you mean? Leave the unit ON for one minute? or leave the unit OFF for few minutes before start using it again??
Username: Asharfi
Post Number: 1957
Turn OFF your receiver. Leave it aside for 30 seconds. Then turn it back ON. If you're still having problems, then you can use other PUFF bins.
Username: Leo_here
Post Number: 88
Piece of $hit...they are all the same you copied the file from D$$W0rld and bragging here you are the one writing codes..gtfouttahere
Username: Locnoir
Post Number: 72
AV, it does not work! cannot use the remote!!! any solution, anyone?
Username: Ak2011
Post Number: 45
Yeah. I have the same problem. As soon as it starts, it freezes and reboots. Where are the other Puff Bins??
Username: Leo_here
Post Number: 89
Download Tronics Bin 266 from ftabins.com
Username: Asharfi
Post Number: 1958
File Fixed!
New File: http://www.hostclip.com/dl/85c46070504b3f9aa3b358cd754f3340
Username: Leo_here
Post Number: 91
FFUUCCKK him !!!
Alyaws go to trusted sites to download bins for your reeiver !
Username: Leo_here
Post Number: 92
I have tried Tronics bin 266 which was posted 17 hours ago !!!!!
No complaints so far !!! If you want to try AVs bin. DO IT ON YOUR RISK !
Username: Dawood1022
AV it's working great after the latest fix you posted .... Thank you
You are great
Home > Message Board > Home Video > Satellite TV > Archive through May 15, 2008 > Black Tyger PUFF Bin 266 - [May 14th] [ « Previous ] [ Next » ]
